Welcome to the North American Subaru Impreza Owners Club Sunday February 23, 2020
Old 02-10-2020, 04:23 AM   #1
SubieDude23
Member#: 456268
2006 WRX
Default IAG Street AOS, Puff of Oil Smoke on Cold Start
Hey guys,
Lately I've had this strange issue where my car puffs a cloud of what looks to be blue oil smoke. It smells like burnt oil and confirms my suspicions. I pulled my turbo the other day and say a pool of oil on the turbo compressor inlet and on the intake tube. The intercooler had a bit of pooling oil too. I assume this pooled oil in the turbo gets sucked through the turbo/engine and puffs oily smoke on cold starts.
I was wondering if anyone has experienced issue and if there was a fix.
I've been running the IAG AOS for a few years now and I've been noticing this has been happening more frequently lately. The car still runs awesome, but cranking it in public places can be a bit embarrassing. Thanks for the help.
SubieDude23 is offline   Reply With Quote
Old 02-10-2020, 09:58 AM   #2
Turpid Porpoise
Member#: 476573
2008 Impreza WRX STi
Sounds like valve seals to me.
Turpid Porpoise is offline   Reply With Quote
Old 02-11-2020, 03:18 AM   #3
SubieDude23
Member#: 456268
2006 WRX
I actually changed them when I built the engine about 20k miles ago
Old 02-11-2020, 07:53 AM   #4
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
If this has been happening more frequently lately, it sounds like something has happened internally.
As an example... a ring land failure can give occasional symptoms. One of which is occasional smoke on startup. PVC system, turbo oil seals, I would suspect as well. Some detective work and you can follow the oil. It is coming from PCV lanes into the inlet, or burping out of the compressor. If you can get eyes on the turbo inlet, you should be able to get a direction to go in.
KillerBMotorsport is offline   Reply With Quote
Old 02-11-2020, 08:55 AM   #5
Brother EddieJ.
Member#: 181617
2004 wrx
Dom3/IAG built hybrid
This happened to me. Exact same thing. Only go worse as the days went on. Piston ring failure. I had 330whp and 300wtq on my 2.0 for 147k miles. Try a leak down and compression test(both wet and dry). Could be valve seals or turbo slowly dying but who knows until those two tests are done. You might even be able to tell just looking at the spark plugs
Brother EddieJ. is offline   Reply With Quote
Old 02-11-2020, 11:08 AM   #6
Turpid Porpoise
Member#: 476573
Try running the engine with the oil cap off and check for smoke. Then get a compression and leak down test to properly diagnose your issue.
