05-11-2012, 07:20 PM | #3376 |
Member#: 268627
Vehicle:05 SpecC/FFR818 WRB |
V8/9 motors have the screens in the rear firewall side AVCS hard line bolts. Not in the bolts that go to the solendoid.
45% is the max, and standard, AVCS advance for v8/9 motors. Should also see about 11% at idle. From your log looks like your left is floating and your right polarity is backwards.
05-11-2012, 07:28 PM | #3377 |
Member#: 166324
NESIC
I know people reccomend changing a few things when buying a jdm motor. Mine was said to have 20k kilometers. The two belts outside the timing covers look MINT. Should I still take it apart and change the timing belt, timing belt guide, sparkplugs, water pump, oil pump ect????
05-12-2012, 06:09 AM | #3378 |
Member#: 46135
Vehicle:19 GLA45 AMG C63 AMG |
Nobody guarantees the mileage of these engines, so maybe it is true, but you never know..
You could change things in stages, depending on how the engine runs. The belt can also age, to an extent, so it's probably a safe bet to replace it and maybe the tensioner. Then do an oil change and maybe thermostat (which has often replacement intervals in the factory brochure and which sat exposed for who knows how long, instead of being marinated in corrosion inhibitors). Then run it and see and log how it responds. If need be, change the plugs after a while and then default into the normal routine. |
05-12-2012, 10:25 AM | #3379 |
Member#: 15822
Vehicle:1999 WRB GM6 2.34 LR destroker |
hey twin scrollers,
how does one fix a leak in the uppipe/headers connection? I don't believe thicker gaskets exist, and stock ones doesn't fix it |
05-12-2012, 10:54 AM | #3380 |
Member#: 82745
SCIC
Vehicle:2005 Subaru STI 2003 EJ207 S204 Wagon |
05-12-2012, 11:08 AM | #3381 |
Member#: 15822
the twist is actually visible, sanding it won't really work
I either need to shave that somehow or find a thicker gasket I think |
05-12-2012, 11:20 AM | #3382 |
Member#: 46135
Is this a bend in the mating surface, on one of the two flanges?
Then try to hammer it back to where the screw bore is perpendicular, then bring the unit to a machine shop and let them machine the mating surface plane. The pressure upstream of the turbo is quite high and a gasket with less than uniform mating pressure may leak, then you're back to square 1. |
05-12-2012, 02:01 PM | #3383 |
Member#: 166324
NESIC
Is this a good replacement list? Missing anything?
Timing Belt, aftermarket guide AC Belt, Alt Belt Water Pump Oil Pump Oil Cooler Idlers/Pulleys Thermostat (which should I get) 160? Daily driver in MA Spark Plugs (which should I get) NGK bkr7eix one step colder? And for the pumps and belts do I buy for wrx or 04-07 STi? |
05-12-2012, 02:19 PM | #3384 | |
Member#: 64511
SCIC
Vehicle:2003 WRX sedan |
05-12-2012, 02:24 PM | #3385 | |
Member#: 26568
NESIC
Vehicle:2003 Yellow Bugeye Version 8-Vf37 |
Btw, I'm running oem range thermostat. Also, plugs are the original ones that the motor came with and it runs great, not sure why you're considering swapping them. |
05-12-2012, 02:38 PM | #3386 |
Member#: 166324
NESIC
I'm just trying to cover all ranges. I don't need an alternator, mine came with one. :-)
From the looks of my engine from the outside and looking at the AC and ALT belts it doesnt even seem like I need to do anything, belts are mint, but I'm trying to be "safer than sorry". |
05-12-2012, 04:42 PM | #3387 | |
Member#: 224785
Vehicle:2005 wrx-jdm207 i went black... |
05-12-2012, 06:20 PM | #3388 | |
Member#: 161437
Vehicle:02 WRX Wagon EJ207 |
Replied above in red. |
05-12-2012, 08:06 PM | #3389 |
Member#: 166324
NESIC
What's the matter with the NGK? Why do you prefer Denso? If Denso, what's the part number?
05-12-2012, 10:38 PM | #3390 |
Member#: 290109
SCIC
Vehicle:2005 WRX PSM |
is there valve cover/frame clearance issues like with the 2.5L? if not, why use iridium?
05-12-2012, 10:56 PM | #3391 |
Member#: 50586
BAIC
Vehicle:64 Impala |
05-12-2012, 11:13 PM | #3392 |
Member#: 290109
SCIC
most people use iridium plugs because they last longer. especially Sti owners, due to the pain in the ass it is to swap plugs.
otherwise, copper burns great for turbo cars. iridium has such a really fine spark. IIRC, you have to run a closer gap and a few other things. not ideal for our cars. unless the 207 likes them for some reason? just asking. |
05-12-2012, 11:32 PM | #3393 |
Member#: 287434
My ej207 loves NGK bkr7eix iridiums. 22psi all day everyday.
05-12-2012, 11:36 PM | #3394 | |
Member#: 50586
BAIC
Vehicle:64 Impala |
05-12-2012, 11:39 PM | #3395 |
Member#: 290109
SCIC
05-12-2012, 11:41 PM | #3396 |
Member#: 50586
BAIC
Vehicle:64 Impala |
yea one step colder then stock USDM WRX/STI heat range, and it's not really that hard to change them, it took me about 35 mintues. Not sure what u mean by frame clearance....
05-12-2012, 11:48 PM | #3397 |
Member#: 290109
SCIC
i'm told the 2.5L engine doesn't have much room in between the valve covers and the frame, making it difficult to change plugs. as such, most people go with the iridium plugs so they don't have to go through it very often. there is a spark plug faq on this site that discusses all of it as well. i guess "difficult" is a relative term.
05-12-2012, 11:50 PM | #3398 | |
Member#: 50586
BAIC
Vehicle:64 Impala |
05-13-2012, 03:01 PM | #3399 | |
Member#: 166324
NESIC
The spark plugs in my motor are NGK R, PFR7G |
05-13-2012, 03:13 PM | #3400 |
Member#: 290109
SCIC
ej207 owner wants opinions | adbramsay | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 2 | 02-26-2011 07:29 PM |
Ej207 V6 | AndrewFD3 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 10 | 06-03-2010 04:53 PM |
JDM Sti EJ207 V9 crank 75mm or billet crank (K1, Manley) VENDORS ??? | L'frise | Private 'Wanted' Classifieds | 7 | 06-03-2010 09:24 AM |
08 ej207 JDM dual AVCS heads on a built v7 ej207 | icev7 | Built Motor Discussion | 17 | 02-21-2010 03:21 PM |
Ver 8 EJ207 Owners Check In | spoolinsuby | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 21 | 10-17-2005 01:56 AM |
