Welcome to the North American Subaru Impreza Owners Club Monday June 16, 2025
Old 09-23-2022, 11:37 PM   #1
quicklol
Member#: 525135
Default Fuel pump isn’t priming
I bought my car two weeks ago, it had no issues because everything was rebuilt to stock on it. It starts up with one too two clicks. But it does have a intake down pipe and exhaust it has a check engine light because of the o2 sensor from the down pipe. No tune as of now. But three days ago I go to start my car. But it doesn’t start. I noticed my fuel pump isn’t priming. I was looking all threw the forms and did everything other people has said, I checked all my fuses none of them are blown. I checked to see if I was getting power too the fuel pump relay. And then I checked if I was getting power underneath the passenger side in the back that goes straight to the fuel pump with a 12v circuit tester. And I’m getting power. I have checked all my grounds and there all secure. The owner recently replaced it with an oem one. It randomly started working yesterday out of nowhere so I took it for a drive the parked it then it stopped working again. I’m am very confused on what is going on. The car has a brand new wiring harness and brand new ecu. This car was put back to stock before he sold it to me. I don’t know what could be the issue.
Sent from my iPhone using NASIOC
quicklol is offline   Reply With Quote
Old 11-02-2022, 08:45 PM   #2
HarryGibson
Member#: 531990
How to Make Sure Your Visual Content Drives Traffic
How to Create and Attribute Lead Source in Microsoft Dynamics
https://bmmagazine.co.uk/business/ho...your-business/
HarryGibson is offline   Reply With Quote
Old 11-30-2022, 09:21 AM   #3
Baldwinw
Member#: 531720
If you checked your fuse and relay I would try looking at your fuel pressure regulator and maybe try changing the fuel filter. But it sounds like a burnt pump.
Baldwinw is offline   Reply With Quote
Old 01-27-2023, 09:54 PM   #4
Boosted_Rexi
Member#: 532487
i have a similar problem where after i put gas in my 2007 Subaru WRX the car cranks but won’t start. so i turn it off than on, and crank it again and she sputters than eventually after i turn the key on, and crank it enough (3-4 times) it’ll start. but she misfires for a few minutes till i rev it or start driving and the misfire goes away. would that be also fuel pump not priming ?
Sent from my iPhone using Tapatalk
Boosted_Rexi is offline   Reply With Quote
Old 01-27-2023, 09:59 PM   #5
Boosted_Rexi
Member#: 532487
i have a similar problem where after i put gas in my 2007 Subaru WRX the car cranks but won’t start. so i turn it off than on, and crank it again and she sputters than eventually after i turn the key on, and crank it enough (3-4 times) it’ll start. but she misfires for a few minutes till i rev it or start driving and the misfire goes away. would that be also fuel pump not priming ? the entire fuel system is aftermarket (braided lines, perrin rails, id1050x injectors, and aem high flow pump)
Old 01-28-2023, 03:08 PM   #6
LAS04subie
Member#: 379520
2005 Wrx
I recently had a similar problem. I do have an aftermarket pump and it’s hardwired so different from stock setup. But my wiring near the pump was bad. I would pull out the pump and check the connections from the actual pump make sure those are fine. I could wiggle mine and it would work and stop working as well. Check the wires right under the fuel pump cover as well. I guess I should mention my car is an 05 WRX I’m not sure what year your car is.
LAS04subie is offline   Reply With Quote
Old 03-07-2023, 07:31 PM   #7
Elrod660
Member#: 533409
Have to agree, sounds like the fuel pump burned out.
Elrod660 is offline   Reply With Quote
Old 03-10-2023, 10:48 AM   #8
Jerrby
Member#: 533488
I would also assume a bad fuel pressure regulator possibly. I've heard many times about the oem subaru fpr are flawed and deteriorate.
Jerrby is offline   Reply With Quote
Old 04-02-2023, 01:07 PM   #9
MattSiebers
Member#: 525823
I have an 02 wrx with a similar issue. Two things I looked at that might help you was putting direct power to the fuel pump with a battery or jump pack and a wire to see if it even accepts power, and I am not 100%sure about this one but there is a second relay in the same location as the fuel pump relay, I believe it is a dark orange color. From what I could find it is related to powering the fuel pump as well as some other things. Hope this helps!
MattSiebers is offline   Reply With Quote
