#31876 | |
Member#: 507873
![]() Quote:
Did you get that TSB for extended cranking issues? I got that a while back, and I always turn the ignition on for 5 seconds or so while the fuel system primes, haven't had the issue in years even though I used to get it all the time.
#31877 |
Member#: 326345
Vehicle:2012 5-Door Premium Ice Metallic Silver |
![]() With 200,000 mi on my car, I couldn't justify paying Subaru $430 or a local mechanic $390 to change my spark plugs. Had always heard horror stories about the tight space that you have to work in on this boxer engine. Did a little bit of research, but two tools that I'll link below made all the difference and really got a lot of courage from a Mr. Subaru YouTube video. 90 minutes later, all four plugs changed and kicking butt.
Small and skinny 3/8" ratchet wrench: https://amzn.to/33hHnSm Kick ass 14mm rachet: https://kokenusa.com/products/z-series-3-8-sq-dr-spark-plug-socket-with-spring-clips-14mm Spark plugs: NGK 93482 Step by step video: https://youtu.be/nLet3J2KAT0 |
#31878 | |
Member#: 313575
Vehicle:2012 Impreza 2.0i HB |
![]() Quote:
[other live withs include: my PVC tape covered hatch release -- still keep meaning to spend $34 and replace the switch with a new one but the tape covering works just find over the decayed rubber of the button underneath; rattles that have developed over time] |
#31879 |
Member#: 254730
![]() does anyone know if i can fit an sti front sway bar on my 2012 subaru impreza 2.0 hatch? i see that the rear fits but i havent seen if the front fits. also, what other STI/WRX parts fit on our cars? thanks in advance.
#31880 |
Member#: 345444
Vehicle:2013 Impreza 5-door White |
![]() Hi, I have a 2012 Impreza 2.0i Sport Premium Hatchback with the OEM gray alluminum wheels. I want to get spacers so they can sit flush. Does anybody know how many mm I need for that?
The OEM wheels are: Size: 17x7" Offset: +48 Last edited by tspunk; 04-04-2023 at 05:52 PM. |
#31881 | |
Member#: 310435
Vehicle:'12 Sport Limited Black - 252,631 miles |
![]() Quote:
The front is 20414FJ010 Impreza / 20401SC100 STI and they are different shapes. What other parts fit? Go to a Subaru Online Parts page. Search for the STI part and look at the diagrams, press the number, select the link. Look for the tab that says WHAT THIS FITS and look for 2.0 Impreza's. |
#31882 | |
Member#: 310435
![]() Quote:
Your Sport Premium 5Dr - 16 x 6.5 My Sport Limited 5Dr - 17 x 7.0 |
#31883 |
Member#: 345444
#31884 |
Member#: 507873
![]() De-winterized my car yesterday. Summer tires on, brake fluid flushed (should have been done 2 years ago, oh well), and washed. The sun was down by the time I finished washing the car so I didn't clean the interior, but that's next up, probably later today.
#31885 |
Member#: 340456
Vehicle:2013 Impreza |
![]() Apparently my car's tail lights are cracking from UV exposure. Noticed from the sides first (red portion of lens) and now the clear portion is going. Never had that happen before.
#31886 |
Member#: 507873
![]() Does anyone know if there's any correlation, either direct or inverse, between people who changed their CVT fluid out at least a few times and people who have the valve body issue that seems to be popping up frequently now?
#31887 | |
Member#: 313575
![]() Quote:
i'm at almost 110k*, so far so good. i've changed with AMSoil at 60k and 90k. i noticed a measurable improvement in MPG at the 60k change. i did not, however note a similar increase at 90k. i plan to do it again at 120k (assuming i haven't bought a new Crosstrek or Forester before then) *i still continue to see my odometer under predict distance by a 2-3% amount so i think the reality is i have driven about 113k. but that should also be the case for others with 2012-2014 (?) vehicles. |
#31888 |
Member#: 507873
![]() I can't recall when I changed mine, I think it was maybe 10-20k ago and I'm at 95k mi right now. I changed it twice in a short time, the first time I dropped the pan, then after seeing that a relatively small extra amount comes out with the pan I just used the drain plug. I've been meaning to do it again, because I got a few cases of the Valvoline CVT fluid on a steep discount from amazon a year or two ago, but I don't have a good transfer pump and even when I did it was so slow and exhausting I've been trying to find a better way to refill it.
#31889 | |
Member#: 310435
![]() Quote:
If anyone does get this done, make sure they don't charge you for 13 quarts of CVTF. It doesn't require draining the fluid. I switched to Valvoline CVTF, which is amber. They charged me for Subaru CVTF, which is blue. When I went behind them and checked, my fluid was still amber. I called them, they confirmed they didn't change the fluid and refunded me $200+. Stealerships!(rolleyes) |
#31890 |
Member#: 507873
![]() Valvoline CVTF is amber for you? I think the stuff I had/have is red, definitely Valvoline CVTF though. I could be remembering wrong though.
#31891 | |
Member#: 310435
![]() Quote:
#31892 |
Member#: 507873
![]() Does anyone have any thoughts as to what exactly is the issue with the CVTs? I know it's a "valve body" issue, but what does that mean? Is there a solenoid that breaks in half because of a bad design, does something get clogged, something else? I'm very curious
#31893 |
Member#: 310435
![]() Supposedly, the valve body was suppose to be improved for 2012 to 2017 Impreza's and other models. So much for that.
Otherwise, its just a not so reliable switch (the solenoid). If the valves don't open or close properly, it triggers the light. As much as I have changed my CVTF, I know it's not because of dirty fluid or low level. Last edited by CLL_OBP; 05-20-2023 at 09:09 AM. |
#31894 |
Member#: 310435
![]() Delete
#31895 |
Member#: 90513
![]() I'm nearing 137,500 miles on my 15 Impreza. Should anything else coolant related be done when changing it out, hoses, thermostat or waterpump? Are there any common failure points? The hoses and clamps look like they are in good shape, from appearances it looks like a waste to change them out.
#31896 |
Member#: 507873
![]() I think in general it's not a bad idea to change the thermostat out since they're cheap and it's easy to do while changing the coolant. But not necessary by any means. I haven't heard of any widespread issues with the cooling system.
#31897 |
Member#: 326345
![]() All these years later, what is this plastic piece in the back of my hatch?
https://photos.app.goo.gl/GiAphx5S6mMEaoS86 |
#31898 | |
Cowabunga!
Super Moderator Member#: 185
South East
Vehicle:2014 Impreza Sport Ice Silver Metalic |
![]() Quote:
I use it to pinch buckles there. |
#31899 |
Member#: 326345
#31900 | |
Member#: 313575
![]() Quote:
Possibly looking into a 2011 or 2012 Impreza? | xenonk | Mid Atlantic Impreza Club -- MAIC | 2 | 03-08-2020 05:34 PM |
2012 Impreza STI concept art | khaki_man | Member's Car Gallery | 37 | 03-15-2011 02:02 AM |
Newsflash: 2012 Impreza looks like BigElm's Butt | WagonMonster | Off-Topic | 4 | 02-28-2011 07:11 PM |
2012 Impreza Concept | Zakster87 | General Community | 14 | 11-17-2010 04:09 PM |
