#1 |
Member#: 97683
Vehicle:2005 WRX STi CGM/Gold - Element GT52 |
![]() I just got a new turbo + APS inlet and other **** installed.
I just noticed yesterday that i found a un-connected lead.. I thut tht I am missing a sensor. I compared it with a friends sti and voila... its missing.. What is this sensor.. and what could be the reason that i dont have it in my car after the install ? My friends Setup with stock turbo stock inlet hose stock boost control solenoid ![]() ![]() My setup with GT52 and samco inlet hose, prodrive solenoid. Notice the missing grey sensor.. ![]() ![]() Why was it taken out ?
#2 |
Member#: 114566
TXIC
Vehicle:2005 STI aspen white |
![]() it is for the PCV system and to be honest with you it does not make a difference wether it is connected or not in fact i believe that if you install a Perrin type intake hose ,it is deleted. from what i can tell it alters the vacuum pulled on the top side of the PCV valve. i would not worry about it.
#3 |
Member#: 19221
South East
Vehicle:2005 Legacy GT (STi) UR35R/Rotated Intake Mani |
![]() Just wrap it up with electrical tape. They set it up the proper way so that the CEL doesnt come on. Just tape it up and tuck it under the manifold.
-Matt |
#4 |
Member#: 95840
NWIC
Vehicle:sold to a good bud awaiting next car |
![]() When I put my Crawford Air/Oil separator, I had to take it out. It's a blow-by sensor I believe. basically it was a pressure switch, I believe. I pulled the metal "spade" out of the sensor, and plugged into the connector to make the circuit. That way it won't turn on the CEL.
just tuck it away. as long as the CEL isn't on, you're probably ok. |
#5 |
Member#: 97683
![]() does this have anything to do with my boost gauge showing 25 psi at wot for a while when my car is boosting a mere 17psi ??
#6 |
Member#: 19221
South East
![]() No. You have something else wrong. A 25psi spike is enough to kill the motor.
#7 |
Member#: 95840
NWIC
#8 |
Member#: 133597
SCIC
![]() That doesn't make sense. If it says 25psi, what makes you think your car is only boosting 17psi? Did you install the boost gauge? Where are you getting this info (25psi) from? Do you have EM?
#9 |
Member#: 2539
![]() Curiously subscribed.
#10 |
Member#: 97683
![]() EM is telling me 17 psi, we checked it on the dyno too.. Rob @ automaster was also freaked out, as he had put a feul cut or something at 17psi.. its may be the senor is goin nuts... i dunno.
Car is fine.. doing excellent. Its definately NOT boosting to 25+psi.. Defi BF imperial boost gauge gone mad. The only thing that changed was this missing sensor. I somehow feel that this has something to do since it manipulates the pressure reading, and mebbe my boost gauge is tapped to this line. Nehow, i'll try and move the T joint elsewhere and see how it reacts. |
#11 |
Member#: 133597
SCIC
![]() I was hoping your boost gauge was elec. and not mech. That makes more sense then. Weird.
#12 |
Member#: 97683
![]() I have no idea. Appreciate any help on the boost gauge issue.
#13 |
Member#: 39652
Vehicle:2007 WRX TR (UGM) R.I.P d00m Wagon |
![]() another curious subscriber...
#14 |
Member#: 142707
NWIC
Vehicle:2002 wrx/sti/jdm... blue with custom paint |
![]() My defi boost gauge reads higher than my HYDRA!
#15 |
Member#: 99442
International
Vehicle:2006 SGM STI I'm on CORN YO! |
![]() You should ask the guy who installed it what happened???? Now you see it? Now you don't?
#16 |
Member#: 133597
SCIC
![]() Get a wiring diagram for the Defi's and check it.
#17 |
Member#: 67182
Vehicle:2004 Subaru STi 11.0 @ 128mph - 93/Meth |
![]() Thats easy. That sensor is just a connector that connects the breather to the stock turbo inlet hose. Looks like you have a aftermarket one on the car. So it gets eliminated. I thought the same thing until I got my FPRed kit from perrin and the directions told me the same thing.
#18 | |
Member#: 27108
Vehicle:2004 STi 2004 A4 |
![]() Quote:
Plugged in = no CEL, Unplugged = CEL. So, it just needs to be shorted out. |
#19 |
Member#: 27108
#20 |
Member#: 50582
![]() Try a different mechanical boost gauge with your current hookup first and see what it reads, easy enough to try if you can get your hands on one.
As for the sensor, does anyone know "why" the aftermarket inlet pipes don't make provision to keep the sensor? It may not matter running it unhooked, but why not bother to make provision in the aftermarket inlet pipes to allow it to run as designed? |
#21 | |
Member#: 23717
NESIC
Vehicle:2005 Big red |
![]() Quote:
There is nothing in that housing just a jumper. Those are just PCV breather lines wich get rerouted with the install of some inlet hoses. Get another boost gauge and check. Even a cheap autometer from autozone. TMS |
#22 |
Member#: 97683
![]() I will do that.. thanks.. As for the EM i'm running ECUTek.
#23 |
Member#: 48219
Vehicle:. Always drive the race line . |
#24 |
Member#: 95840
NWIC
![]() ^^^I believe it is a switch. for blowby "sensing". Too much pressure, and the switch trips.
but im just pulling that out of my azz... |
#25 |
Member#: 23717
NESIC
What is this thing? And why is it infront of a bolt I need to get to? | Soulofdarkness | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 01-10-2010 01:01 AM |
What is these sensors and why are they disconnected? | relliMmoT | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 13 | 10-19-2009 07:54 AM |
What is this for and why is it disconnected? ('05 STi) | WRBPHXSTI | Electrical & Lighting | 5 | 04-19-2009 10:44 PM |
what is this part and why is it broken?! | Lordhowe | Brakes, Steering & Suspension | 23 | 01-20-2009 12:51 PM |
What is this connector, and why is it unplugged?? | Kwyjibo | Electrical & Lighting | 7 | 09-24-2003 01:21 AM |
