Welcome to the North American Subaru Impreza Owners Club Tuesday September 26, 2023
Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 04-19-2023, 11:27 AM   #1
WYSubaru
Member#: 154884
2005 Baja turbo
Default Replace lower control arms while replacing struts?
I'm planning on replacing the struts on our 05' Baja turbo. The vehicle has 170k miles and was curious if I should replace the LCA's while I was at it?
WYSubaru is offline   Reply With Quote
Old 04-21-2023, 08:42 AM   #2
Elbert Bass
Member#: 283429
2016 Fuji Sunfire 03
Might as well - the bushings can't be in that great a shape and the ball joints may have seen better days. If it were mine, if the vehicle isn't a rust bucket, and you plan on keeping it for a few more years then yes, replace the LCAs. While your at it might as well replace the upper strut mounts as well, You will eventually have to anyway, might as well do it all at once. That way you only have to pay for an alignment once. At least until an inner/outer tie rod end goes out...
Elbert Bass is offline   Reply With Quote
Old 04-21-2023, 09:21 AM   #3
WYSubaru
Member#: 154884
2005 Baja turbo
Thanks. I was planning on replacing all the mounts while I had it apart. I'll check the tie rod ends as well.
