Welcome to the North American Subaru Impreza Owners Club Friday June 18, 2021
Go Back   NASIOC > NASIOC Subaru Models > Outback Forum
Old 05-26-2016, 01:44 PM   #101
Elpoosy
Member#: 419441
[quote=Killuhkade;44404084]
Originally Posted by Duderotomy View Post
2003 Outback H6
DGR coilovers, 16x9 et13f/0r on 245/50R16's
IMG_6653 by Remington Lee,
Where do you get those fender flares? They look really good
Looks like universal JDM fender flare kit.
Elpoosy is offline   Reply With Quote
Old 05-30-2016, 04:33 AM   #102
Killuhkade
Member#: 447109
[quote=Elpoosy;44425865]
Thanks!
Killuhkade is offline   Reply With Quote
Old 06-25-2016, 12:57 AM   #103
GreenMarine
Member#: 36080
2020 Outback Touring
Autumn Green Metallic
wow, there are some sexy wagons in here :-p
GreenMarine is offline   Reply With Quote
Old 06-25-2016, 01:42 AM   #104
GreenMarine
Member#: 36080
Originally Posted by manik1770 View Post
Probably all the same folk that are on the LegacyGT forum have seen mine. Pretty much only suspension upgrades and wheels/tires for her.
Speaking as someone who can't stand what Subaru did to the 2010 - 2014 Outback, I've gotta say, this car is freaking HOT... It actually makes me look at the 10 - 14 legacy/outback in a new light!!
Old 06-28-2016, 04:13 AM   #105
CaleDeRoo
Member#: 242049
1999 Outback 5MT
CaleDeRoo is offline   Reply With Quote
Old 07-05-2016, 12:54 AM   #106
GreenMarine
Member#: 36080
Originally Posted by CaleDeRoo View Post
That sits nice! What's your setup??
Also, is that a different than stock rear wiper arm?? How did that work?? I have a 1998 LGT at the moment that could use a new wiper arm (rust)...
Old 07-05-2016, 07:35 AM   #107
CaleDeRoo
Member#: 242049
1999 Outback 5MT
It's on BG/BD specific coilovers (BC racing) with 17x7 +45 Speedlines which are temporary until I get my 5x100 BBS powdercoated.
YES! It's a Honda Pilot wiper arm, and it was a direct bolt on. I think I paid $15 for the arm and blade total from some parts warehouse. Part #76720-S9V-A01
Old 07-06-2016, 01:57 PM   #108
manik1770
Member#: 337460
2013 Outback ltd 3.6
GGM
Ha thanks man!
manik1770 is offline   Reply With Quote
Old 07-18-2016, 01:02 AM   #109
CaleDeRoo
Member#: 242049
1999 Outback 5MT
Old 08-12-2016, 09:17 PM   #110
cmpequeno
Member#: 87036
2002 Impreza Outback
Red
2003 Outback H6
More pics please.
cmpequeno is offline   Reply With Quote
Old 11-17-2016, 03:16 PM   #111
manik1770
Member#: 337460
GGM
Mark Ocampo, on Flickr
Old 11-25-2016, 11:27 AM   #112
Benjamin M
Member#: 349494
LGT suspension swap
RCE coilovers
18x8.5et45 with 245/45/18
Benjamin M is offline   Reply With Quote
Old 01-25-2017, 02:07 AM   #113
Virtue95
Member#: 461875
Default Wheel/ coilover fitmeny
[quote=thebigd1973;40179535]Hey folks. Here are a couple of recent pictures of my ride.
SUSPENSION
- K-Sport AR Spec. Coilovers
- Whiteline Front Sway bar
- Whiteline Front end links
- Whiteline Rear Sway bar
- Whiteline Rear end links
- Whiteline Front tower strut bar
WHEELS & TIRES
- XXR 527's 18x8.75" 5x100 (Matte black)
- BF Goodrich Comp T/A 245/45-18
- NRG Lug nuts 471 Series in Pink c/w locks
Did the wheels and coilovers fit perfectly? Or did you have to add spacers of something also what's the offset?
Virtue95 is offline   Reply With Quote
Old 02-20-2017, 01:58 AM   #114
Mike des
Member#: 463268
Default 2005 outback xt
New to the forum. I just bought a 2005 outback xt manual.
It's lowered on Godspeed mono max coilovers. But for some reason the rears are raised all the way up and it rides like crap. It hits the bump stock on every bump. I'm not sure where to start with them. I checked preload on them. I feel like the shock doesn't actually have much travel. Is there a way to lower it down on the bottom and redo the preload so that it extends the whole shock?
Mike des is offline   Reply With Quote
Old 02-20-2017, 09:48 AM   #115
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
I wonder if they are sedan springs on a wagon. For many MY's, front Legacy springs were all the same rating for sedan and wagons, rears were stiffer for wagons, or, you did a spacer on the top mount (IIRC, Saggy Butt is one brand).
Old 02-20-2017, 12:51 PM   #116
Mike des
Member#: 463268
I don't think there from a sedan I called god speed directly and they said there for the outback. I just don't know if there adjusted wrong or what. Im trying to figure out a way to lower the shock down into the body and then reset the preload up higher on the threads.
Old 02-20-2017, 02:11 PM   #117
Mike des
Member#: 463268
Do you know what I should have the shock damper settings at on top of the shock? Should I have it more stiff?
Old 05-08-2017, 05:33 PM   #118
cmpequeno
Member#: 87036
Red
05 legacy struts and tein stech springs
Old 04-14-2020, 03:57 PM   #119
BigJulz
Member#: 513705
Default Still alive??
anyone still active? im in need of some help, ive got an 05 OBXT limited, lowered on LGT coilovers, im assuming adjustable lca's are what i need but ive got too much camber in the rear...
BigJulz is offline   Reply With Quote
Old 04-14-2020, 08:05 PM   #120
joe_r
Member#: 421445
We were just talking about this over on LegacyGT.com forums:
This thread:
https://legacygt.com/forums/showpost...&postcount=356
and this older thread:
https://legacygt.com/forums/showthread.php/official-lowered-outback-thread-v2-265116p24.html
TL;DR
Most of us will tell you to grab LGT upper control arms and bump stops, a Whiteline Camber Correction Kit (KCA399), or some Whiteline adjustable arms (KTA124).
joe_r is offline   Reply With Quote
