05-17-2013, 02:34 PM | #2376 |
Member#: 350063
Vehicle:2013 Impreza sport White |
Looks nice, scored one from Macanudo here at work, sadly it's too short for the imp so it's now in my Cherokee.
05-19-2013, 08:46 PM | #2377 |
Member#: 89967
Vehicle:2020 Volvo S60 Gray |
Quick question to those who have installed Hella Supertones and used the Subimods wiring harness: how did you get it to plug into the factory harness?
It seems like our year has a different connector, as it won't fit the connection on the Subimods harness (factory connector below): http://i.imgur.com/uV6yTcZ.jpg It also seems that the Subimods harness isn't the best wire length for our cars either, as the good mounting point for the relay by the washer fluid resevoir ends up being too far away for the wires to be able to hook up to the horns themselves. Before I start ripping apart the harness, has anybody made the Subimods harness work? |
05-20-2013, 06:55 AM | #2378 |
Member#: 216040
Vehicle:2013 Impreza 2.0i5dr dark metallic grey |
I used the Subimods harness on my car. Yes the plug was bigger than the factory plug but I just trimmed it to fit and it worked fine. Then I wrapped it in electrical tape but I went to rewrap it and pulled the connector off so I just spliced it in before the factory connector and still works the same.
For the relay I zip tied it to a hole on the driver's side top part where there was a open hole and didn't seem to have any issues with length. |
05-20-2013, 08:03 AM | #2379 | |
Member#: 314216
Vehicle:2012 2.0i Sport 5MT DGM |
There is a thread "2012 2.0I supertones install" or something like that, I posted my pictures there |
05-20-2013, 03:37 PM | #2380 |
Member#: 89967
Thanks for the feedback, I'll probably look at it again this weekend see how to make it work the best. I have to figure out where to mount the relay - the harness is only long enough to mount it behind the bumper beam. I'd have to modify it to put it in either of your locations
05-20-2013, 04:00 PM | #2381 |
Member#: 314973
BAIC
Vehicle:2012 Impreza Sport Satin White |
05-21-2013, 08:24 PM | #2382 |
Member#: 345948
Cross-post from the 2012 Impreza Pictures thread:
05-21-2013, 09:56 PM | #2383 |
Member#: 322264
Vehicle:2012 Impreza Sp 5sp Obs Blk Prl/Drk Gray Mtl |
^^ Nice wheels.
05-22-2013, 09:13 AM | #2384 |
Member#: 342279
Vehicle:2012 Impreza Sport DGM |
Hey MjSub2.0, horns look awesome!! I actually like the extra spread.. Looking forward to seeing it with the grill on.
Btw, what did u use to plug ur old license plate holes?? |
05-22-2013, 11:17 AM | #2385 | |
Member#: 314973
BAIC
05-22-2013, 02:02 PM | #2386 | |
Member#: 338330
05-24-2013, 07:13 AM | #2387 |
Member#: 216040
MjSub2.0- Nice. Did u get a new grilletoo. I got the same ones but mounted them ib the middle with the Subimods bracket. I have a mesh grille and people are always looking at my car as the horns stick out and are very noticeable. I had someone ask if they were speakers.
05-24-2013, 08:35 AM | #2388 |
Member#: 323103
Vehicle:2018 WRX Pure der |
^Thats when you say "yea listen close" and blow the horn. lol
05-24-2013, 09:07 AM | #2389 | |
Member#: 353045
05-24-2013, 11:33 AM | #2390 |
Member#: 314973
BAIC
05-24-2013, 12:26 PM | #2391 |
Member#: 253849
Did you guys see that Tanabe is looking for an Impreza for R&D?
http://www.tanabe-usa.com/rnd/post/T...plicants!.aspx |
05-24-2013, 01:03 PM | #2392 |
Member#: 92967
SCIC
Vehicle:2007 Legacy gt Black |
I got a call from tein but they need the car for two weeks
05-24-2013, 01:05 PM | #2393 |
Member#: 92967
SCIC
I also got contacted by magnaflow
For a axle back And stromung |
05-24-2013, 01:12 PM | #2394 |
Member#: 323103
All these shops are in CA boooo
05-24-2013, 03:30 PM | #2395 |
Member#: 314973
BAIC
06-03-2013, 01:40 PM | #2396 |
Member#: 169194
SCIC
Vehicle:04 STI WRB |
Car is at tanabe for springs and "chasis parts" It was supposed to get an exhaust as well but when I showed him the rear bumper he said the R&D guys would have to see if they would even want to develop an exhaust that would need modification to the rear bumper |
06-03-2013, 07:02 PM | #2397 | |
Member#: 345948
Thanks man, I appreciate it.
Yeah, I didn't really want to slam it nor do I plan on doing so. But since I just got some 245's this weekend, I'll probably roll my fenders because I'm not sure if the fronts will clear. If I do roll the fenders, I might lower it a bit more to eliminate the wheel gap completely but we'll see. The current ride height is pretty functional. Quote:
06-03-2013, 09:37 PM | #2398 |
Member#: 337144
International
Vehicle:2012 Impreza Hatch Ice Silver |
finally have bought a set of coilovers for my hatch, from Cusco should have them in a couple weeks time, then i can finally put my wheels on
06-04-2013, 07:01 PM | #2399 |
Member#: 216040
Lucky u. Good luck and keep us updated.
06-06-2013, 04:15 PM | #2400 |
Member#: 1184
South East
Vehicle:2020 STi SeriesWhite Ceramic White |
The Subimods harness plugs into the horn on the passenger side, not the one in the front of the car with the ambient temp probe attached to it.
Similar Threads | ||||
Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? | somebody else | Southern California Impreza Club Forum -- SCIC | 3 | 12-23-2015 04:34 AM |
factory SS or aftermarket for 2012??? | Myth21 | Transmission (AT/MT) & Driveline | 8 | 01-07-2012 11:18 AM |
Has anyone test drive a 2012 Impreza yet? | pRiMe DiReCtIvE | General Community | 25 | 11-28-2011 10:03 PM |
Hybrid Impreza in the works for 2012? | rsholland | News & Rumors | 43 | 03-12-2010 10:58 PM |
