Welcome to the North American Subaru Impreza Owners Club Saturday April 29, 2017
Old 04-21-2017, 07:43 AM   #26
rtv900
Member#: 428511
2016 STI
Originally Posted by SoapBox View Post
That's assuming that he puts the car in neutral and steps off the clutch before quickly shifting into reverse, which would seemingly be rare.
More likely, he's got the clutch in, so the input shaft isn't seeing even idle RPM.
I'd say 90% of the time I go to reverse is from idling in a spot, clutch out in neutral, and then clutch in and throw it right in reverse. No grind which is why I know it is synchronized.
My truck has no reverse synchro. It grinds like hell if I do that (from a dead stop!!). I have to either clutch in and wait 4 or 5 seconds (annoying as hell), or simply flick the shifter in 3rd for a half second to use it's synchro to stop the shaft and then jump right over to reverse. Works perfectly.
Reverse being spur gears is totally irrelevant.
There's no way in hell he's going to damage a trans by dropping it in going a few mph
Old 04-21-2017, 08:26 AM   #27
SoapBox
Member#: 204578
S54 E46, N54 E82,
N55 E84, AKA REX8
I find thatodd. It seems most people would be using reverse in one of two ways:
1. Starting car; so clutch in, start, shift to reverse from whatever gear you parked in. So no neutral/clutch out time.
2. Pulling in somewhere, in gear; clutching in, braking to a stop, shifting to reverse. So again, no in neutral, clutch out time.
Edit: I suppose some portion of the time I'm starting the car and letting it warm up a bit, so then I'm in neutral with the clutch out. But certainly not anything close to 90% of the time.
SoapBox is offline   Reply With Quote
Old 04-21-2017, 08:29 AM   #28
SoapBox
Member#: 204578
S54 E46, N54 E82,
N55 E84, AKA REX8
Originally Posted by Charlie-III View Post
I can't say I have ever heard of a synchro'd reverse either.
I've never owned a car with one either.
Old 04-21-2017, 09:29 AM   #29
rtv900
Member#: 428511
2016 STI
you must have never driven one without, because the difference is night and day and is unmistakable.
I don't know why people assume there's no synchro yet never hear a grind no matter what.
Start your car today and let it idle for 5 seconds with the clutch out in neutral.
Clutch in and immediately put it in reverse.
Does it grind?
If not it's got a synchro.
Old 04-21-2017, 09:35 AM   #30
SoapBox
Member#: 204578
S54 E46, N54 E82,
N55 E84, AKA REX8
You know what...I think you're right. Looks like even WRX 5 speeds have a reverse synchro, even though everyone (self included) would have told you otherwise. Straight cut gear, so it's loud, but does have a cone synchro.
Old 04-21-2017, 01:12 PM   #31
jimbowrx
Member#: 365370
In the WRX and STIs, reverse is an idler gear, so you are physically slotting a gear between two gears, but you still have the synchronizer. The synchronizer is on the back of 5th gear in the 5MT gearbox and on the back of 6th gear on the 6MT gearbox.
Because reverse is an idler gear, the common misconception is that it's not synchronized. If it wasn't, you'd never be able to get it into reverse, because the input shaft doesn't stop spinning if the engine is running.
The WRX 5MT gearbox has a weak synchronizer, so many people wind up having to do the 'subaru shuffle' to get it into reverse...shift into first or fourth, blip the throttle, then into reverse.
jimbowrx is offline   Reply With Quote
Old 04-21-2017, 05:30 PM   #32
Abismo
Member#: 99707
2010 WRX (in spirit)
I remember this well haha.
Abismo is offline   Reply With Quote
Old 04-22-2017, 06:38 AM   #33
GDR
Member#: 34924
03 WRX Wagon
81 Scirocco S
The reverse drive gear is cut straight into the input shaft.
The reverse driven gear is cut into the 1st/2nd selector sleeve on the output(pinion)shaft. This selector sleeve is fixed to the output shaft by a splined hub.
The reverse idler gear slides over and connects the 2. There are no synchronizers as the 2 gears are FIXED to their shafts.
GDR is offline   Reply With Quote
Old 04-22-2017, 11:16 AM   #34
SoapBox
Member#: 204578
S54 E46, N54 E82,
N55 E84, AKA REX8
Read two posts up, there is a reverse synchro in both the 5 and 6 speed boxes. Part numbers and everything if you search for them.
Old 04-22-2017, 11:31 AM   #35
wrxlaunch
Member#: 181298
2015 WRX Limited
Lightning Red
Need help putting gas in your car too?
wrxlaunch is offline   Reply With Quote
Old 04-24-2017, 02:33 PM   #36
bagwell
Member#: 405467
NASIOC is a joke - guy is asking a serious question and a-holes pounce, LOL, I'm out.
bagwell is offline   Reply With Quote
Old 04-24-2017, 02:38 PM   #37
WRelaX
Member#: 447497
Originally Posted by bagwell View Post
NASIOC is pretty much a joke - guy is asking a serious question and a-holes pounce, LOL, I'm out.
Welcome to the forum
WRelaX is offline   Reply With Quote
Old 04-24-2017, 03:07 PM   #38
mishapopa
Member#: 393629
2015 WRX
he's willingly and knowingly bashing his head on the wall. we're telling him to stop.
mishapopa is offline   Reply With Quote
Old 04-24-2017, 04:21 PM   #39
Schoat333
Member#: 452248
2017 Base WRX
a-holes? This isn't bad at all
Schoat333 is offline   Reply With Quote
Old 04-24-2017, 05:49 PM   #40
f4phantomii
Member#: 58504
2004 STi w/o wing
Aspen White / Silver
Indeed. Probably shouldn't venture into Off Topic.
f4phantomii is offline   Reply With Quote
Old 04-24-2017, 07:20 PM   #41
Altephor
Member#: 429442
2016 WRX Limited
CWP
Hold on I'm still searching the OP for a serious question.
Altephor is offline   Reply With Quote
Old 04-25-2017, 08:09 AM   #42
rtv900
Member#: 428511
2016 STI
you mean an erroneous question is posed, and then a few people disagree and through discussion arrive at a an accurate conclusion?
wow, good thing you decided to bail
What a terrible outcome
