Welcome to the North American Subaru Impreza Owners Club Tuesday October 20, 2020
Go Back   NASIOC > NASIOC Technical > Pre-2002 Factory Turbo Powertrain
Old 10-11-2013, 10:19 PM   #51
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Ej20k heads converted to solid buckets with supertech valves and dual springs. Chambers are also modded to ej257 design by Larry's Power in Connecticut. Sorry for the pic whoring, I'm just so relieved to be driving it again.
2slofouru is offline   Reply With Quote
Old 10-14-2013, 09:58 AM   #52
kheff46
Member#: 66739
2002 WRX wagon
Sweet! Glad to see it coming together nicely
kheff46 is offline   Reply With Quote
Old 10-14-2013, 10:28 PM   #53
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Been driving it over a week now, no problems so far. Just have to lower the oil pump size.
Old 06-17-2014, 01:00 PM   #54
4man
Member#: 373295
so someone wrote off my 96 gf8 and now imm shopping for a new car. looking at a 95 sti and a 95 sti ra. am I right in saying that both of these have ej20g with a closed deck and cast internals? and despite what everyone says about the ej20k, would it be worth jumping up to a 97 for the forged internals?
4man is offline   Reply With Quote
Old 06-17-2014, 09:08 PM   #55
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
The ej20k engines with forged internals are more rare, I believe they have to be sti. Someone correct me if I'm wrong.
Update: My ej257k hybrid is still running strong. I've been running on the powerfc untuned on the ej20k untuned map since assembly. I also installed a Perring AOS to catch blow by oil and it does a great job. I am waiting on a Steamspeed Stx 20g r turbo and also for my Killer B header to arrive, then I can install my larger injectors and FINALLY go get tuned
Old 07-10-2014, 12:40 PM   #56
SubaruDood
Member#: 340058
I totally want to hear how the tune goes with your Steamspeed STX 20g-r. I heard that Harvey at TheBoostCreep was really impressed with the turbo even though he had to perform a dialed-back tune because the customer's engine wasn't built. Still, at something like a mile high in elevation, it pulled 375whp with a nice torque curve.
I hope you'll let us know how the tune turns out for you! It sounds like its going to be a beast with that Killer B header. When do you think you'll have it all put together and tuned?
SubaruDood is offline   Reply With Quote
Old 07-10-2014, 08:39 PM   #57
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Me too, now I'm just waiting on the Killer B header which is taking longer than expected. I've been driving around with header and up pipe leaks and it sounds and runs weak. I'm at sea level and have 93 octane everywhere so I'm hoping for 400whp but who knows. Corr Performance in New Orleans is tuning it, they are the only ones within a reasonable distance that aren't afraid to tune my Power FC. They also travel back and forth to P.R. a lot to tune vehicles.
Old 07-22-2014, 04:29 PM   #58
SJOGUN
Member#: 358689
I'm having the same issue with tuners not willing to tune my power FC. I'm about to order an FC datalogit though! Any one else bought their own datalogit? Looks way to install, and it should be able to be tuned by anyone
Sent from my DROID BIONIC using NASIOC mobile app
SJOGUN is offline   Reply With Quote
Old 07-22-2014, 09:46 PM   #59
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
'13 BRZ
I do. It's a fairly easy program to use once you figure out what everything does.
Cbgrandtheftauto is offline   Reply With Quote
Old 11-22-2017, 12:44 AM   #60
clubspectom
Member#: 478096
Does anyone know the latency values for the EJ20k OR15 Yellow top 480cc injectors? I have put a set in my EJ20G but don't have this data for tuning purposes. They replaced the grey top 380cc P1 injectors.
clubspectom is offline   Reply With Quote
Old 11-23-2017, 02:12 PM   #61
i10scooby
Member#: 459133
2004 Forester
I looked around but the only thing I could find was this post here:
https://forums.nasioc.com/forums/sho....php?t=2523792
2Slo4U suggested the best place to find the values would be backtracking information in the Power FC for that model year.'
For this reason it might be best to just go with with phase 2 side feeds and get adapters (robtune sells some nice ones for $100).
I recently flow tested my EJ20K yellow tops at Injector RX and they flowed 515 cc... different than anything I have read, but I have never seen anyone who actually flow tested them either.
i10scooby is offline   Reply With Quote
Old 11-23-2017, 02:47 PM   #62
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Marnix is a very knowledgeable dude, he's such a value to the forums and has contributed so much to this and other forums.
I still have the side feed adapters for mine, would be a good idea to get new o rings for safety if anyone needs them. The 1000cc injectors I ran can be sold with them as well of course. Don't forget I have a powerfc too! lol
But yeah, finding the latency values was tough. Hopefully any helpful information I found was shared, lots of times we all forget to post it for posterity. A lot of it is on the UK forums and it's really spotty at best, just like here where people post some of it and the threads die with few to no responses.
Old 04-01-2018, 07:26 PM   #63
clubspectom
Member#: 478096
I ended up getting a response from the supplier and the injectors worked well after the tune.
Dead time - 0.57ms @ 14v / 3.05 bar
Flow (manufacturer spec)
470cc @ 2.55bar
505cc @ 3.05 Bar
540cc @ 3.55 Bar
Old 06-02-2018, 01:09 PM   #64
smoothbagel
Member#: 486698
You are right. The WRX didn't have forged internals and neither did the"ej20g" that was really a ej20k offered in the forester. Also good to hear!
smoothbagel is offline   Reply With Quote
Old 12-14-2018, 05:27 PM   #65
thehumanflag
Member#: 357453
So excited to see early GC GM GFs soon to be available for import
thehumanflag is offline   Reply With Quote
EJ20G vs EJ20G Old vs Late w/Pictures bape-ape Pre-2002 Factory Turbo Powertrain 10 04-14-2017 04:46 AM
Late ej20g cams Cbgrandtheftauto 1993 - 2001 Impreza Specific Parts 4 03-11-2010 02:49 PM
EJ20K vs EJ20G Maf Scaling? JDMFLCL Pre-2002 Factory Turbo Powertrain 7 03-02-2010 09:14 AM
late ej20g (20k) engine timing rs182 Pre-2002 Factory Turbo Powertrain 28 01-10-2010 03:48 PM
ok. who actually knows ej20K electronics and ej20G electronics well? swapstar Subaru Conversions 24 12-21-2005 03:48 AM
