Welcome to the North American Subaru Impreza Owners Club Saturday October 24, 2020
Old 05-27-2020, 09:29 PM   #701
ej20kurabus
Member#: 515146
anyone know is there is a difference between the ej20k (1996) valvesprings and retainers and the 2002 wrx OR know a website i can get aftermarket springs and retainers for an ej20k, as the closest option they ever have for a 2.0l turbo is the 2002 wrx. tia
ej20kurabus is offline   Reply With Quote
Old 05-27-2020, 09:43 PM   #702
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Yes, the 2002-2005 wrx springs are shorter and I think the valves are different length as well.
The springs in the 96-98 dohc 2.5 and the ej20k are longer than the 02-05 wrx springs. I got a set of shims by ferrea that allowed the shorter ej205 size springs to work in my ej20k heads but ferrea doesn't have them anymore. The ones they sent me sucked anyway and I had to send them back because their sizes weren't accurate. Finally they returned in the correct size and I installed the dual supertech springs. The ej25d n/a heads have the same spring and valve setup as the ej20k, just different spring pressure and some had sodium filled valves.
From what I remember, the shims ferrea made were 6.40mm thick, which made the ej205 spec supertech dual springs fit correctly. They replaced the oem spring seats. I also had supertech valves for the n/a ej25d in my ej20k heads.
If you contact user 2pot, he may be able to share the specs of some shims he had made for his setup. I think a machine shop made his, they looked to be of better quality than the ferrea.
2slofouru is offline   Reply With Quote
Old 07-21-2020, 08:27 PM   #703
awdonry
Member#: 397454
1997 GC8 STi
Originally Posted by mrgf8sti View Post
Hey guys i have a rhd ver4 98 sti, with no dccd. Looking for help with the front axles.
Are they the same as a usdm 98 impreza?
Hey have you had any luck with a usdm axle? I have a GC verIII 1997 STi and I need to replace both front axles.
awdonry is offline   Reply With Quote
Old 07-21-2020, 08:47 PM   #704
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
93-01 Impreza (GC and GM) axles are same length in front. You just need to confirm if your old axle is male or female on the inner end and if you need an axle with the abs ring on the outer. I've bought aftermarket axles and they came with pressed on abs rings, which I tapped off with a mallet and punch because my knuckles had no room for the ring. The 02-07 Impreza(GD) wagon axles are also the correct splines inner and outer and have the correct length.
Old 07-21-2020, 09:32 PM   #705
awdonry
Member#: 397454
1997 GC8 STi
Thank you kindly!!! When you say male and female I guess the male has rod going into the transmission? So my car will either have either male or female, not mix of both? For the GD wagon axles, it has splines inner and outer, I would get that if mine are male?
Male:
Old 07-22-2020, 07:50 AM   #706
2slofouru
Member#: 90539
My BOV goes
COVFEFE!
Yes. Also pay attention to whether your car has abs. If not, you will need to remove the abs rings from the axles.
Old 07-23-2020, 09:22 PM   #707
awdonry
Member#: 397454
1997 GC8 STi
awesome thank you so much!
EJ20G & EJ20K Parts awdeclipseguy 1993 - 2001 Impreza Specific Parts 17 06-15-2009 07:04 PM
EJ20G Gasket Part Numbers... scoobydorift Subaru Conversions 13 02-14-2005 10:43 PM
Official XT Oil Filter Part Number thread BrysImpreza Forester Forum 8 10-29-2003 11:23 PM
NAPA Part numbers- can we have a nice thread with numbers listed? Tex-WReX2 Service & Maintenance 5 12-15-2001 09:21 AM
