Welcome to the North American Subaru Impreza Owners Club Wednesday May 18, 2022
Old 11-22-2021, 09:48 PM   #1
CoopsCustomz
Member#: 57625
2015 WRX
Ice Silver Metalic
Default Smash & grab destryed my rear quarter window - how to DIY install replacement?
2015 WRX
I had my rear driver's side quarter window smashed in last Friday night. I've found a replacement on eBay for like $38 but can't seem to find any tutorials on how to install it? Any help?
I replaced the rear hatch glass on my old 2005 wagon and it was pretty easy- just cleaned things up and used that glass epoxy glue stuff. Is it the same process for the rear quarter windows in a 2015?
Cheers!
CoopsCustomz is offline   Reply With Quote
Old 11-28-2021, 04:26 PM   #2
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
I looked in my Database
That fixed glass pays a tech .5hr (like $30)
That means it is easy
Database says adhesive needed(called mastic, do not use RTV, Home Depot type of thing)
So that is telling me that glass is just set into door frame
Possibly with clips as well(database does not show)
Biggest issue would be damaging the fixed glass seal while removing
But that part only $28.02 from Subaru
Unless this comes with the eBay glass
IMO
Sounds like something you can tackle
Especially if you installed a back glass
Same procedure, just 80% easier than a back glass
GL
Let us know what happens!
Old 11-29-2021, 09:15 PM   #3
CoopsCustomz
Member#: 57625
2015 WRX
Ice Silver Metalic
Ok so I decided to just jump in and figure out how to fix it. Turns out it was super easy. Here's a quick tutorial on how to replace the rear quarter window in the 2015-2019 WRX:
https://rumble.com/vpy8wa-rear-quart...uslgy&mc=artqa
Old 11-29-2021, 09:18 PM   #4
CoopsCustomz
Member#: 57625
2015 WRX
Ice Silver Metalic
IMO
GL
This is super helpful, thank you! I actually just jumped in and fixed it without seeing this yet, but you're correct- it was easy and the window basically just sits in the frame of the door arch and the little black pillar. Easily removable with hand tools and no adhesives needed
I made a quick tutorial just in case anyone else is curious. See previous comment
