#226 |
Member#: 149890
NESIC
Vehicle:09 Forester Green |
![]() this looks so good. Great work so far. Can't wait to see the next update. You are building a very cool, fun car.
#227 |
Member#: 498642
Vehicle:'19 WRX Ltd 6M dgm '08 Mustang GT (the toy) |
![]() Can hardly wait for a track session video with overlaid datalogging . . . yeah, I expect there will be a bit of 'sorting' involved.
Norm |
#228 |
Member#: 190502
International
![]() Setting up the suspension is a big concern for me but it should come together eventually. I won't buy rear coilovers or build the front bellcranks until I know my corner weights though.
I'm really glad I made the inner control arm mounting points so adjustable, I've already moved the top inner mounts down a little to add some camber gain but I can see the lower mounts will probably need to be slid down a little too. I've got to measure everything again at some point and adjust it all to my original model I came up with in the software. |
#229 |
Member#: 190502
International
![]() I have been working on the front end, trying to make the panels fit over the new wheels by trimming away metal and plastic from the front fenders and bumper.
This photo shows how low the car is and also that I have extended the wheelbase by 35mm by moving the front wheels forward. //i.imgur.com/VBtOB2v.jpg?1 After some trimming I could get the panels back on, you can see I need to remake the panels with a new shape. //i.imgur.com/9pl4dXn.jpg?1 //i.imgur.com/3NS5dnU.jpg?1 I also had to seek some clarification on the rules as one section said I could cut away any metal necessary for bump clearance and another section said I could only make changes to the shock towers solely for suspension geometry changes. After getting the go-ahead from the technical director I did the minimum amount of trimming to the strut towers so the tyres would no longer make contact. //i.imgur.com/v3rpJ0v.jpg?1 //i.imgur.com/taJECoK.jpg?1 I have also been trimming away some metal around the wheel wells to help with air evacuation, I post some photos of that once its done. Last edited by JDwhiteWRX; 07-08-2021 at 05:41 AM. |
#230 |
Member#: 190502
International
![]() Looks like I have found a workaround for this strange thing that has been happening with my photos.
For some reason it kept going to some website http://dereferer.org/ |
#231 |
Member#: 190502
International
![]() I've been in lockdown the past few weeks and it probably won't end any time soon. Luckily this has given me plenty of extra time working on the car.
Most of the work has been around getting all the front end panels mounted onto the car. I bought some 16mm x 1.2mm 4130 chromoly tube and a very cheap manual bender from ebay. The bender snapped during the first bend but I was able to modify it to mount in my vice and now it works surprisingly well. The tube structure I'm building is very light and will be removable by taking out several bolts. First step was to make a rear mount on the chassis. //i.imgur.com/UOqCYKa.jpg?1 This is how all that turned out, one on each side. //i.imgur.com/yOgUiKk.jpg?1 Then it was just a matter of bending some tube and making some tabs to hold the fenders in place. //i.imgur.com/O21jXLg.jpg?1 The whole thing is rather basic but it is surprisingly sturdy. //i.imgur.com/7eHaKu7.jpg?1 This is it after finishing both fender mounts. More tube which I have already bent up will continue around the front and attach to the top of the bumper. I have left that bit off for now and started work on the main reinforcements to the front chassis rails. //i.imgur.com/MK26pXy.jpg?1 |
#232 |
Member#: 190502
International
![]() This is my proposed tube routing to reinforce the front frame rails. Lots of measuring and clearance checks to arrive at this point.
What do you guys think? https://www.instagram.com/p/CRdWRYCHCkW/ |
#233 |
Member#: 33782
Vehicle:96 3MI Racing search FIRST, then PM!!! |
![]() Looking really good now! I also didn't know you had an instagram. Following you now.
The front wheels being moved forward screams to have some proper pieces made to help get air out of the wheel wells! -Micah |
#234 |
Member#: 190502
International
![]() I was playing around with the bodywork today, nothing serious, just kicking around some ideas.
#235 |
Member#: 48377
Vehicle:1996 Gutted, built XP class Impreza L |
![]() Vents on the rear side of the fenders will help a great deal with evacuating air from the wheel wells.
#236 |
Member#: 33782
![]() I was thinking vents more like a 911 GT1 or the WRC style that roll into the wheel well itself.
The vanes like on the JGTC BRZ would be tricky copy in composite (for me) and a lot of CFD to optimally aim. Don't forget they also carry off the back of the fender like a shelf towards the mirror. |
#237 |
Member#: 190502
International
![]() I intend to leave the back of the fender completely open, I just made the mdf run all the way down so it sits level.
#238 |
Member#: 190502
International
![]() Work has begun on bringing the strength back into the front end, much more to come.
https://www.instagram.com/p/CRs-gwPH...dium=copy_link |
#239 |
Member#: 33782
![]() Yeah, saw that on my feed. Just as satisfying to see it again
#240 |
Member#: 149890
NESIC
![]() wow, I can agree, that is very satisfying to see. Great work. How do we coerce you to work faster
#241 |
Member#: 190502
International
![]() Here is a little update on the work I'm doing to stiffen up the front end, it's really coming together now!
//i.imgur.com/mSVDYSr.jpg?1 What I've done is bring tubes from the roll cage into the engine bay in a triangulated 3d structure that should prevent flex in any direction. //i.imgur.com/2VV7qNI.jpg?1 You can see the tubes are coming from the top and bottom of the A-pillar and then coming back to an additional mounting point in the center of the transmission tunnel. //i.imgur.com/TPF76W6.jpg?1 //i.imgur.com/LA1UeRe.jpg?1 close up of the notched junction //i.imgur.com/OtxxhBc.jpg?1 //i.imgur.com/8C4UOCb.jpg?2 There will be another brace across the front of the engine but first I am going to take the engine back out and weld everything I've done so far. I also need to make a bracket and mount the dry sump oil pump to the engine to make sure there will be no clearance issues with the brace at the front. |
#242 |
Member#: 190502
International
#243 |
Member#: 190502
International
![]() Lots of work has been happening but I've had trouble getting the photos to upload to Imgur off my phone so this update is a bit overdue.
The final pieces in the puzzle went in to the front end. These short lengths of tube join the new structure to the frame rails. //i.imgur.com/xhgfbVs.jpg?1 //i.imgur.com/Q8BCcES.jpg?1 //i.imgur.com/8HdZ8Cr.jpg?1 With that work done I needed to get my dry sump oil pump mounted onto the engine so that I could finish the bracing across the engine bay without any potential clearance issues. If you recall I bought the dry sump not as a kit so I have had to fabricate my own oil pan and mounting bracket for the oil pump, this saves lots of money. I started with a piece of scrap 6mm steel plate. //i.imgur.com/wTWOxiX.jpg?1 The alignment of the oil pump to the crank pulley is critical and there is a specific distance between the pulleys. //i.imgur.com/jXcBUiE.jpg I used different clamps to the one in the photo above, a large square and lots of measuring before getting the final position. Once I was happy I used transfer punches to mark the holes out for drilling. //i.imgur.com/SapQGoc.jpg?1 The final product had some attempt to reduce weight with a step drill and carbide burs. //i.imgur.com/lNVB27u.jpg?1 The end result was spot on. Below you can see me test fitting some of my accessories before returning the engine to the car. Of special note is the starter motor which was specifically designed for the Honda K-series by Carwood Brise. Compared to the OEM starter it is twice as powerful, 25% lighter and more compact. As an added bonus I was able to mount it with my BMW ZF320 5-speed without modification to the transmission as this starter runs a twin nose bearing design which means there is no large snout over the cog that would normally foul on a RWD trans configuration. https://brise.co.uk/honda-k-series.html //i.imgur.com/POFudj6.jpg?1 I got the engine back into the car and everything fits perfect, no clearance issues. //i.imgur.com/iqE38no.jpg?2 The steering rack is close but that's how I designed it. //i.imgur.com/AiSshfY.jpg?1 So that's where I'm up to for now. My electric water pump arrived yesterday so I will be looking at places to mount that. I am going to start building the final brace across the engine bay which incorporates extra bracing for the steering rack. I still need to order a turbo but I'm having trouble deciding which one to get. Turbo and steering column/shaft are the next two things that need to be ticked off as they both occupy the same space. Also the radiator/intercooler needs doing. //i.imgur.com/aO3GjLr.jpg?1 |
#244 |
Member#: 33782
![]() So continuing our discussion from yesterday and adding some content here.
Here is your 9174/9180 compressor map ![]() Here is an overlay of the 8374 and 8474 compressor maps. ![]() You can clearly see the 8474 made a huge mass flow gain over the 8374 and jumps to mass flow ranges of the 91xx compressor, albeit, lower efficiency. Now here's the 9180 and 9280 overlay. Again, not the large jump in mass flow but drop in efficiency. No doubt worth the trade off. ![]() Being a K24A2, making some shorter exhaust manifold for responsiveness over peak power, I think the larger frame turbo would grow on you for sure and leave you room for some 'unlimited' class power. You could simply run it at the low boost for shake down, get used to the lag, dial in ALS, etc... I do think a DCT/8HP70 would make it FAR easier to pilot and keep lag and recovery time from each shift to an absolute minimum. They do come with some weight and heat penalties though. Sticking with that old 5 speed, you might be better off with the mid-size frame of the 8474 and knowing you've left time and power on the table which you can always address later. |
#245 |
Member#: 190502
International
![]() Thanks for this info mate, the DCT is never going to happen, I'd purchase a real sequential before I'd ever purchase a DCT for this car.
Did you find anything on the 9174? I have looked through some comments from Geoff at Full Race and will summarise below:
Link to all these comments here https://www.sau.com.au/forums/topic/...v-20/page/131/ As I mentioned in our messages, there is a significant price advantage with the 9174 as also mentioned by Geoff's comments. The AUD is really weak against the USD right now so the price is important. |
#246 |
Member#: 33782
![]() I had not realized that the 9174 was about $150 cheaper than the 9180, which is about $150 cheaper than the 9280.
And as for DCT, I get it. I mean I too would go with a real sequential if money wasn't a factor. |
#247 |
Member#: 190502
International
![]() I'll just leave this here...
#248 |
Member#: 190502
International
![]() ok one more photo
#249 |
Member#: 179775
South East
Vehicle:03 WRX/15 FXT 14 BRZ/ 92 SVX |
![]() Awesome! This is great to follow.
#250 |
Member#: 149890
NESIC
![]() yes, yes, and more yes! That looks amazing
