Welcome to the North American Subaru Impreza Owners Club Friday December 13, 2019
Old 11-07-2019, 06:09 PM   #1
Krieger88
Member#: 277043
2015 WRX
WR Blue
Default Remote start on cold mornings causes CEL
So on my 2015 WRX if the morning is colder than 50 degrees it will only start the accessory power but not the engine and itíll cause a temporary Check Engine light. I can physically start the car no problem with the key right after but itís weird to me that it only does it when itís colder than 50. The code it throws is U0073 which is the control module communication bus. Not sure what to try before bringing it somewhere.
Krieger88 is offline   Reply With Quote
Old 11-11-2019, 10:43 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
I suspect you may have a faulty comm bus connection. The bus uses two wires to send signals between modules. The colder temperatures are just enough to possibly break the connection. Just moving the proper connections may fix the trouble. Here is a link that may help you understand things better.
https://www.obd-codes.com/u0073
Cougar4 is offline   Reply With Quote
