Welcome to the North American Subaru Impreza Owners Club Friday December 13, 2019
Old 11-14-2019, 11:54 AM   #1
deadstockpomp
Member#: 292520
13 WRX STI limited
Default Question about wiring
I recently redid my wideband gauge connection with some shrink connectors. The power is spliced in near the ignition. Up by the harness there is less than an inch of wire left. What happens if Say I needed to do the connection again down the road and there is no more wire how would I fix that. Iím not sure how to upload photos anymore here so I will include the iwsti post
https://www.iwsti.com/#/topics/321710
deadstockpomp is offline   Reply With Quote
Old 11-16-2019, 03:42 PM   #2
moby4dick
Member#: 51901
'04 WRX
That link doesnít bring me directly to your post.
At any rate, as I canít picture your exact scenario, Iím guessing when you say harness you mean the connector going into the wideband gauge. Even if thereís only an inch, you could still solder a connection and heat shrink.
For something cleaner, can you get a replacement harness? Or contact the manufacturer and see if you can replace the pin and crimp another wire to it.
moby4dick is offline   Reply With Quote
