Welcome to the North American Subaru Impreza Owners Club Monday September 24, 2018
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 10-07-2016, 04:31 PM   #576
Boxer4turbo2004
Member#: 106190
Phil you guys built my pro comp build 2 years ago .my fuel pumps prime on the ignition switch via output on hydra ..for some reason the pumps no longer come on I have tested pumps and wiring my laptop connects to the hydra. I am uncertain what is going on . I am in need of a final tune and I seen in previous post where you said you "travel the country tuning hydras" this would make the process much easier for me as I wouldnt have to trailer the car to jersey. I emailed element tuning a couple of times with no response and called not sure what else to do
Boxer4turbo2004 is offline   Reply With Quote
Old 07-19-2017, 10:59 PM   #577
Getnit206
Member#: 471359
Angry Hydra issues??
Hello i have an 04 wrx with the 2.0l turbo and i am trying to install an hydra stand alone out of an 05 sti i have already swaped the wiring harness from the o5 into the 04 and the ecu and i need a new map for a o4 wrx with a front mount ic and an under drive pully setup with a stock up pipe stock injectors and a 3" gready downpipe and exuast i have also installed all dccd sensores and the 6 speed out of the 05 along with all drive train componants. My main concern is the dbw is not installed so will it be possible to get a map for an 04 wrx 2.0l with an 05 sti hydra that had a 2.5l dbw setup ?
Getnit206 is offline   Reply With Quote
Old 11-23-2017, 07:17 AM   #578
francisco1971
Member#: 407601
Default need hydra ems 2.5 ems software
hy people and happy thanksgiving to all. ok i just finish my project. it is an impreza wagon 2002 with a full 2005 sti swap and im running a hydra ems 2.5. for some reason my computer is dead and i can't fine my cd to download it to anoteher lap top. and i need to tune it. can any one help? where can i find a site so i can download it or any guy tha work for hydra or element tunning. please
francisco1971 is offline   Reply With Quote
Old 11-23-2017, 06:51 PM   #579
Tap
Member#: 21893
2002 WRX w/STi swap
Tap is offline   Reply With Quote
Old 12-17-2017, 11:16 AM   #580
francisco1971
Member#: 407601
thank you for the link. but my problem is that i installed it on my windows 10 and but i cant find it or lunch it. i tried it a bunch of times and it doest work at all. can someone help me?
thank's to all an happy hollydays
Using the Hydra with the GM AIT Sensor.. sponaugle Other Engine Management 1 11-14-2008 01:24 PM
How does the antilag work on the Hydra? Crazykev Other Engine Management 2 10-15-2005 07:11 PM
How many people are using the Hydra on the STi? Quick Other Engine Management 10 10-03-2005 01:20 AM
The Second Official Unofficial Hydra Thread bboy Other Engine Management 2 06-06-2005 11:39 AM
Hydra Users: Anyone know the Hydra injector mapping? wgknestrick Other Engine Management 12 03-07-2005 04:12 PM
