Welcome to the North American Subaru Impreza Owners Club Friday June 22, 2018
Old 07-11-2017, 12:47 PM   #1
surferjohnhawaii
Member#: 396194
Default Full frame build for sti go kart
I have built the Honey Badger Subaru ( http://imgur.com/a/au2BV ). It's all custom and really awesome (minus the understeer in issue). Feel free to ask any questions or send advice!
The motor is the 2004 forester XT turbo (300hp, 300ftlbs) mated to a 2008 WRX transmission (yes it's AWD!) using the forester xt cv joints and hubs/brakes. the car weighs about 1500lbs and I want to have more oversteer when on the power. Currently it has power understeer, which is neither fast or cool.
Overall it's super fun on the track and street, super light and the power to weight makes the acceleration insane. I highly recommend it to anyone who has time to do it.
Thanks for any suggestions or links to parts!
John
surferjohnhawaii is offline   Reply With Quote
Old 07-11-2017, 04:24 PM   #2
rtv900
Member#: 428511
2016 STI
pretty awesome
I guess it's completely limited to asphalt though as it looks like it has virtually no ground clearance and that front end overhang would make for a nasty day if you tried to approach a steep hill on dirt going fast
You don't want to lift that a bit and take it off road?
Old 07-11-2017, 04:31 PM   #3
JonnyWachter
Member#: 313468
2010 Sti
Red
interesting, you put the intake over the hottest part of the engine, yet had no restriction on where you could have actually routed it.
JonnyWachter is offline   Reply With Quote
Old 07-11-2017, 04:46 PM   #4
isotopesope
Member#: 265783
2017 Forester XT
Niner ROS 9
what are your current alignment specs? front and rear spring rates? front and rear tire pressures? does this thing have swaybars? if so, what sizes?
isotopesope is offline   Reply With Quote
Old 07-12-2017, 12:05 PM   #5
surferjohnhawaii
Member#: 396194
Originally Posted by rtv900 View Post
pretty awesome
Typically yes it will be for on road track use and spirited drives once it's street legal. But, I have a set of mud tires in mind and the suspension is fully adjustable and I can get at least 6inchs of ground clearance for flatish forest roads. It's mostly for street and track fun, I wanted an awd go kart...
Old 07-12-2017, 12:07 PM   #6
surferjohnhawaii
Member#: 396194
I wanted to keep the stock routing, I likes the top mount look. In addition the engine is wrapped in thermal blankets and vents the engine heat away from the intake and intercooler.
Old 07-12-2017, 12:20 PM   #7
surferjohnhawaii
Member#: 396194
Currently it has -2.5 degree camber front, -1.5 degree in the rear. No Tow in front and 1/16inch toe out in the rear. Spring rate is 56lb/inch with adjustable preload, rebound and compression. No sway bars as it doesn't really roll due to the high spring rate and low weight. Tires were at 29psi hot.
Old 07-12-2017, 12:50 PM   #8
isotopesope
Member#: 265783
2017 Forester XT
Niner ROS 9
a higher rear spring rate and higher front tire pressure can help decrease understeer. have you tried preloading the rear further? i'd also try bumping up the front tire pressure 2lb at a time to see if it helps.
does raising the suspension make any difference?
have you considered a LSD?
I am by no means a suspension expert, but i know these little changes can make a difference. your build is impressive though; looks like a lot of fun!
also, again, not an expert, but wouldn't rear toe-IN be better to decrease understeer?
Old 07-12-2017, 11:09 PM   #9
surferjohnhawaii
Member#: 396194
You may not be a suspension expert, but you got it dead right. We have a higher spring preload in the rear. We softened up the front and it made it better but not gone. We have rear toe out as well. When we bumped up the front tire pressure it had the opposite effect and made understeer pushing worse.
We shall see where the lsd gets me when I add it.
Old 07-24-2017, 07:05 AM   #10
geef
Member#: 471598
1997 GF8 WRX
Red
Do you have figure of chassis?
geef is offline   Reply With Quote
Old 08-01-2017, 09:16 AM   #11
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
Toe out on the rear usually helps with rotation. As the chassis loads up in a turn and rolls, the outside/loaded rear tire pulls the rear around, helping to turn.
Old 08-06-2017, 06:18 PM   #12
Tdsigmon96
Member#: 461442
Just in case you have your toe terminology backwards (everyone's been there)
From a top down view
Toe in = /---\ (promotes understeer)
Toe out= \---/ (promotes oversteer)
Just throwing that out there to help future readers.
Tdsigmon96 is offline   Reply With Quote
Old 08-08-2017, 10:29 AM   #13
sackytar
Member#: 149262
03WR rallycarFXTleg
PrimerGrey
Post some more pics of the chassis. What did you use for the main parts?
Old 08-09-2017, 03:20 AM   #14
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
That must be a ton of fun to drive!
Have you driven it enough to see how evenly the tires wear? I'm just wondering if more camber up front would help them stick. More caster, too.
Old 08-09-2017, 03:55 PM   #15
the2017WRX
Member#: 449164
Wow. If you had to guess, how many hours have you spent on the project so far?
Regarding the understeer problem, what is your front-to-rear weight balance?
the2017WRX is offline   Reply With Quote
Old 08-10-2017, 02:38 AM   #16
NSFW
Member#: 140444
05 Stage Free LGT
...2008 WRX transmission [....] and I want to have more oversteer when on the power.
What's the front/rear torque split on that transmission?
The 04-05 Impreza STI 6-speed has a 35 front / 65 rear split...
Old 02-16-2018, 11:48 AM   #17
v2rocket_aka944
Member#: 408701
more work and plumbing but can you put the battery and radiator behind the driver?
that'll be ~50 lbs off the very front.
v2rocket_aka944 is offline   Reply With Quote
Old 02-20-2018, 09:48 AM   #18
surferjohnhawaii
Member#: 396194
Default More info
Hi all, sorry about the delay, works been a killer. This below is the mark 2 honey badger, due to blowing up mark 1 I went with a new frame... hope you like it.
All major components such as the fuel cell, fuel pumps, fuel cooler, dry sump tank, radiator, battery etc, are located behind the driver in the "trunk". There are aluminum tubes inside the bottom from rails to move the radiator fluid front to rear.
The main frame is all 1.75 in 0.95wall dom steel. And I've got about 80 hours build time at the moment, even with the major issues.
I was getting lots of understeer on the original car due to lack of lsd in the front allowing the car to push and no rear led to help bring it around, and the wrx 50/50 torque split did not help. With the 2005 sti trans and diffs it should rotate much nicer.
Due to no one in any state near me (wa) having an awd dyno that can fit a 76 in wheelbase I have to move my rear diff/ tires back to 88in total wheelbase to fit on dynos. I think it looks better this way, but not as deadly or twitchy which made it fun. But I can fit bigger mud tires on now and get 10 inches of ground clearance, so that's a plus?
https://i.imgur.com/8YPS79T.jpg
I went with a top mount intercooler because the piping for a front would not work for numerous reasons on this tiny car, and with the in-work heat shield and open hood style, my intercooler temps don't heat soak. And now i have a much larger intercooler.
Anyone have a spare set of sti r180 rear diff to 24 spline wrx hubs? $1100 from drive shaft shop is going to kill my budget!
Cheers
John
Last edited by surferjohnhawaii; 02-20-2018 at 09:50 AM. Reason: Forgot to mention...
Old 02-20-2018, 01:26 PM   #19
wrxhard
Member#: 108091
This thing is spectacular!!!!
wrxhard is offline   Reply With Quote
Old 03-28-2018, 12:19 PM   #20
ski.wrx
Member#: 254270
2002 Impreza WRX
Cheers
John
You could check this guy out. He still has them available and much more affordable than custom axles
http://wordpress.suberdave.com/?page_id=275
ski.wrx is offline   Reply With Quote
