Welcome to the North American Subaru Impreza Owners Club Wednesday September 19, 2018
Old 09-08-2012, 05:56 PM   #26
HippieeSOOBIE
Member#: 320841
2003 wrx
blue
this problem that you corrected here was causing acceleration hesitation? because i have that problem but dont know if i should be spending the money on a new sensor
HippieeSOOBIE is offline   Reply With Quote
Old 09-08-2012, 06:04 PM   #27
turd_ferguson
Member#: 114609
I don't recall having any hesitation issues. Overall, it felt about the same, the CEL just annoyed me.
turd_ferguson is offline   Reply With Quote
Old 09-08-2012, 07:43 PM   #28
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
if your front o2 sensor is more than 100k miles old...replace it and be done
my car is at ~95k and im gonna just ****can it and get another one when i do the 100k service
Old 03-26-2013, 04:31 PM   #29
doubledribble
Member#: 42912
2003 Outback Sport
bird **** & door dings
replaced my front 02 sensor with an OEM bosch one. CEL cleared after a trip around the block. Less than a tank of gas later it is back on. Haven't pulled the code yet but I'm going to assume it is the same.
doubledribble is offline   Reply With Quote
Old 05-21-2013, 03:47 AM   #30
Tesh
Member#: 266270
Chapter/Region: HIIC
'11 GR.STI.SDN
Been doing all the research I and I have the same recurring code issue, P0031 heater control circuit bank 1 sensor 1, the oe sensor was measuring infinite resistance across the black heater wires so I picked up a bosch universal 4 wire sensor and wired it up today - cleared the code with Torque/BT OBD reader and no dice. I checked the relay under the dash (Brown relay is clicking) and also checked the plug in the bay (black wire heater circuit was showing 12v, the ground wire seemed grounding and don't know what I can do to check the signal wire).
The new sensor is showing 5.5ohm across the twin whir wires it uses for the heater so I don't see a problem there. .. any other suggestions?
Tesh is offline   Reply With Quote
Old 05-21-2013, 04:58 AM   #31
Uncle Scotty
OK buy Nates beans
oem is denso...NOT botch
Old 05-21-2013, 05:21 AM   #32
Uncle Scotty
OK buy Nates beans
throw it away and get a denso oem replacement one
or you will chase you ass with both hands...and never find it
NEVER use any 'universal' sensor...they just dont ever work right
using anything but a denso oem replacement sensor is a crapshoot...and ya gonna roll lotsa 7's
Old 07-16-2013, 07:44 PM   #33
Darth Sleader
Member#: 293322
2008 WRX Sedan
Dark Gray Metallic
Hey All,
I need help with P0031. I have gone through six of these sensors in the 2 years I've had this car! I did the diagnostic and found no resistance between the black wires of the sensor- sensor's heater circuit is dead. But why? What kills them? I kill one every few months! Wiring issue? Please help me solve if you can!
2008 WRX
VF52 turbo
Perrin headers/uppipe/turbo back exhaust
Grimmspeed boost control solenoid
*it might be important to note that the sensor in question is mounted in the uppipe, not the header. In the header, it was level. Factory sensors are mounted at an angle to allow moisture runoff. My mechanic thought this may be my problem and we moved it so it could be mounted at the factory angle.
Thanks guys.
Jer
Darth Sleader is offline   Reply With Quote
Old 07-31-2013, 03:33 PM   #34
Darth Sleader
Member#: 293322
2008 WRX Sedan
Dark Gray Metallic
One more detail- I'm reading no resistance at all in the heater circuit (same reading as when I touch the meter's probes together.). That means I have a bad o2 sensor, right?
Jer
Old 07-31-2013, 03:39 PM   #35
turd_ferguson
Member#: 114609
No resistance means a bad sensor (or at least the heater circuit in the sensor). I wish I knew what to tell you about why you're going through sensors so quickly, but I have no idea. Maybe changing the angle like you recently did will help in the future.
Old 07-31-2013, 03:58 PM   #36
rick-l
Member#: 33868
2003 wrx
srp
Jer
Did it give a code?
What scale is your meter set to? Is it low enough to measure 2-5 ohms?
rick-l is offline   Reply With Quote
Old 07-31-2013, 04:46 PM   #37
Darth Sleader
Member#: 293322
2008 WRX Sedan
Dark Gray Metallic
Originally Posted by rick-l View Post
Did it give a code?
Yes, it's throwing the P0031 code (heater output low). My meter is the garden-variety cheapie, but the scale on the needle starts out very slow so you can read accurately under 10ohms, then gets steeper and jumps by 10s- so I should be able to read accurately any resistance under 10.
Thanks.
Old 02-13-2014, 12:07 AM   #38
Panterag82
Member#: 277974
2008 STI
Lightning Red
I'm that guy reviving a dead thread!! Just got the P0031 code and my idle is now fluctuating when stopped. It goes from 1000 to 500 and keeps dropping until it almost stalls out.
My question is did anyone else experience these symptoms?? Before I grab a sensor I want to make sure it's not the sign of bigger issues.
My car is an 08 STI with 55k on it.
Panterag82 is offline   Reply With Quote
Old 02-13-2014, 12:21 AM   #39
Charlesyang55
Member#: 259505
2004 sti
black
that sounds about right i was having the same symptoms. after you replace it it should be back to normal. when i took out my o2 sensor is was pretty much gone. I did notice i got better mpg after installing new sensor
Charlesyang55 is offline   Reply With Quote
Old 02-13-2014, 01:17 AM   #40
rick-l
Member#: 33868
2003 wrx
srp
I noticed no effects aside from the light being on.
P0031 just means the oxygen sensor heater is open and it takes longer for the sensor to heat up and go into closed loop control.
Old 02-13-2014, 01:28 AM   #41
Panterag82
Member#: 277974
2008 STI
Lightning Red
Awesome. Thanks Charles, grabbing a new sensor now. Hoping this will make the code stay away.
Old 10-07-2014, 06:29 PM   #42
Heanzley
Member#: 334467
2002 Impreza Wrx Sti
I have encountered the same code, I am trying to find denso 22641-AA090 in the US
Heanzley is offline   Reply With Quote
Old 06-22-2015, 09:43 PM   #43
ryderx
Member#: 186044
2000 2.5rs w/ej205
Having a similar issue, different setup if anyone knowledgeable cares to chime in
http://forums.nasioc.com/forums/show...6#post43544056
ryderx is offline   Reply With Quote
Old 06-28-2015, 04:24 PM   #44
kc-55vtsubie
Member#: 351773
Default code 0031 bank 1
Bank 1 is the passenger side right?
kc-55vtsubie is offline   Reply With Quote
Old 01-09-2017, 10:51 AM   #45
Jesse002100
Member#: 460484
Bringing it back alive... Thanks OP I'm starting a head gasket replacement and transfer swap on a new to me 03 wrx. I'm going to use this info to check everything first, but I assume I need a new sensor.
Thanks, Jesse
Jesse002100 is offline   Reply With Quote
Old 02-20-2018, 10:14 PM   #46
hart.auto527
Member#: 478879
2003 Impreza WRX
World rally
Default Bringing it back alive
I am having the same issue with my 2003 I will
Be doing the diagnostic procedure tomorrow but can anyone take a picture of the main relay that the o2 sensor harness goes to so I can find it and correct the issue also?
hart.auto527 is offline   Reply With Quote
fresh swap p0031 after new o2 installation? help! elsanto Subaru Conversions 8 03-24-2012 02:24 PM
So my iPod and new puter didn't screw up like I expected MattSEG Off-Topic 2 09-29-2005 08:15 AM
o2 sensor... mechanical fix didn't work turboscooby13 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 06-18-2005 01:36 AM
Another question about my dead comp. New hardrive didn't fix it garface Off-Topic 11 12-01-2003 12:32 AM
Help! My SAFC installtion didn't work. DeusExMachina Electrical & Lighting 3 02-02-2003 06:33 PM
