12-15-2017, 10:52 AM | #51 | |
Member#: 25837
South East
Vehicle:1996 SVX L AWD Laguna Blue Pearl |
The AX-SUB28SWC-6V has the correct rear camera wiring for cars with the OEM 6.2" HUs. You'll need to cut off the integrated 12-pin plug intended for an ASWC-1, and connect the 3 SWC wires from the 28-pin to the Maestro's harness. The Maestro will also need 12V power and ground from the 70-1761. However, since you got the Maestro RR, you won't need the 6V power converter in the AX-SUB28SWC-6V either. If you can return that, there is an alternate 28-pin harness without the ASWC portion or 6V converter, and which doesn't have the problem with the terminals being too long (that many people have complained about -- search for the numerous posts on NASIOC about that).
12-15-2017, 12:56 PM | #52 | |
Member#: 418049
01-01-2018, 02:22 AM | #53 | |
Member#: 479939
01-05-2018, 08:07 PM | #54 |
Member#: 480180
Vehicle:2015 WRX black |
im looking for something like this, my stock nav unit has too many bluetooth compatibility issues on android 8.1. ive never done an install trying to retain steering controls, daunting isnt a encouraging word lol
01-24-2018, 12:19 PM | #55 |
Member#: 418049
01-25-2018, 11:03 AM | #56 |
Member#: 432497
Vehicle:18 Sti ISM |
should be within a week or two
01-25-2018, 03:04 PM | #57 |
Member#: 479979
Vehicle:2016 STi WRB |
01-25-2018, 08:18 PM | #58 |
Member#: 418049
02-12-2018, 03:33 AM | #59 |
Member#: 457782
Vehicle:2016 WRX Limited Ice Silver Metallic |
02-13-2018, 11:04 PM | #60 | |
Member#: 438216
I will note that this harness is handy if you're installing a Pioneer. It has the Pioneer connector already wired in for you: https://www.amazon.com/dp/B078GBDRVX (It worked great for my Pioneer AVIC-5200NEX) |
02-14-2018, 10:30 AM | #61 | |
Member#: 479979
02-14-2018, 11:56 PM | #62 |
Member#: 438216
I used the AutoHarnessHouse.com 28-pin harness which includes wires for the steering wheel buttons, the backup camera setup, and a couple other things. You'll also need a separate USB adapter and AM/FM adapter.
You can connect the Maestro SW directly to the wires on the 28-pin harness and to the power wires on the harness from my link above. |
04-22-2018, 06:37 AM | #63 |
Member#: 484988
Great information here. I just got a 2016 OB and the Starlink is just terrible. Appreciate you posting this.
05-27-2018, 01:55 AM | #64 | |
Member#: 486466
I have a 2018 Forester Premium with 7" screen with Starlink, Model of HU is FF679UM. My replacement unit is Pioneer AVIC 8200NEX . I tried to install the Maestro SW with all the parts that shook187 has, and it came up with 2 issues: 1 - There is no backup camera signal (OEM Camera) 2 - No front speakers sound You mentioned "If you have one of the 7" OEM HUs, you'll need a separate 5-pin harness to retain your OEM rear camera." Where does this harness connect to? Do you think AutoHarnessHouse has it? Regarding the sound issue, Do you think the harness is defective? Is the Blue loop wire the culprit? Please advise. Thank you so much. Last edited by traiviet; 05-27-2018 at 10:57 AM. |
05-29-2018, 11:04 PM | #65 |
Member#: 459433
This is an amazing post,
I did the Apex V2 Headunit, and juiced it up with an Alpine Power Pack 445u. Polk Audio DB Components front, JBL GTO Rears JL Audio 10 inch ported sub. |
05-30-2018, 11:30 AM | #66 |
Member#: 481712
12-30-2018, 05:09 PM | #67 |
Member#: 129370
Vehicle:2016 WRX |
2016 WRX Headunit Upgrade
I just upgraded my speakers and was disappointed with the sound. Mind you the HU is factory. I don’t have the first clue how to do all of this so my question is, who would I take my car to to have all this done? And any idea how much this would cost?
01-01-2019, 09:53 AM | #68 |
Member#: 436552
Vehicle:2015 Levorg Ice blue |
Any stereo shop could do it. OEM HU cannot even run the factory speakers let alone aftermarket speakers.
01-01-2019, 10:42 AM | #69 |
Member#: 129370
Vehicle:2016 WRX |
What would a amp do for me? I’m a noob with stereo stuff
01-02-2019, 09:15 PM | #70 |
Member#: 495952
an amp would help, because the stock HU is so lacking in power output. However, the cost of having a shop add an amp would be comparable to you just having them upgrade the HU alone. With you already having upgrading the speakers, a new HU would make it sound fantatsic. Add some sound foam to the inside of your door panels and BOOM...fantatsic sound.
BTW i had autoharnesshouse do my harness for my Sony AX3000 unit and everything was plug and play. All I had to do was unplug the old and plug in the new. Very easy |
09-13-2019, 06:35 PM | #71 |
Member#: 463766
Vehicle:2016 WRX DGM |
Just wanted to add that I followed your guide to install a Pioneer 2330 in my 2016 WRX, everything worked great. Thank you!
