05-09-2016, 09:02 PM | #276 |
Member#: 323755
https://www.youtube.com/watch?v=4sID5DWP3Tk
I made a quick video on how I broke those cam sprocket bolts loose with extractor kit. at first i tried impact gun, then tried breaker bar, then used extractor, and all 4 came out!!!
07-11-2016, 01:13 PM | #277 |
Member#: 134872
Vehicle:2005 LGT Ltd Wagon Mods, Mods, Mods! |
Here's one more technique for y'all. Take a tube of plumbers epoxy, the play-doh type stuff that's grey in the middle and green around the outside. Roll it in your hands to activate it, then form it into a triangle about 1" wide. While it's still malleable, feed it in between the intake and exhaust gears and roll the gears in opposite directions to pull the epoxy in towards the middle of the motor. This will form your triangle into a wedge with teeth mirroring the cam gear profile. Once you've got it formed nicely, roll the gears the opposite way to remove the wedge. Let it fully cure/harden. It helps to put saran wrap or a little oil on the gear so the epoxy doesn't stick to it. Once your wedge is hardened, put it back in and now the gears will lock against each other and you can crack on the bolts. This has worked great for me. Cost about $2.
11-27-2016, 12:37 PM | #278 | |
Member#: 265628
I used this method but the belt kept slipping so I used two vise grips, wrapped the belt all the way around the crank pulley and clamped, then pulled the belt tight on the side it would be pulling and wrapped all the way around the cam pulley and clamped. (I actually used third vise grip on this side after the first one just to get it a little tighter... between the second vise grip and the cam pulley) It took a 2' breaker bar w a jack handle on the end (over a 3' lever) and I almost lifted my 215lb keester off the floor before the exhaust ones broke free. I didn't dare use my two part craftsman allen socket for this and no snapon store nearby so I bought a set of impact allen sockets from Harbor Freight (They dont' sell them individual) It worked great. Holy Guacomole!!! These bolts were a nightmare but once I figured this all out they came off with a snap. |
11-27-2016, 01:03 PM | #279 |
Member#: 458813
RMIC
Vehicle:2007 WRX STI Urban Gray Metallic |
Company 23 makes some awesome tools for this. We couldn't get those pesky gears off until we got one person holding down the gear with the gear tool and another person with half inch ratchet 2 foot long breaker bar on the other side. But that's how we did it on my car, also helps for holding cams in place while putting it back together and getting timing right.
11-27-2016, 02:44 PM | #280 |
Member#: 149262
Vehicle:03WR rallycarFXTleg PrimerGrey |
STI Cam Sprocket/Gear Removal??
Best Allen key and heat always but I would stay away from impact tools or you will have to do what I did here. Which is actually really easy if you have a welder.
https://youtu.be/n5hNj9D5QeQ |
11-29-2016, 09:25 AM | #281 | |
Member#: 265628
I appreciate your resourcefulness and am not looking to criticize your work or start a debate. I just wantt o caution other readers that IMHO, I would not advise using heat as the exhaust cam pulleys are plastic... unless you plan on replacing them. |
12-02-2016, 11:33 PM | #282 |
Member#: 71910
Vehicle:2005 WRB WRX - Stg 2 2013 DGM WRX 5-dr |
I tried an impact gun, big breakers, and the Company 23 tools, and the allens just rounded. Drilling with a good bit and cutting oil worked like a charm. I definitely recommend this method.
02-20-2018, 11:10 AM | #283 |
Member#: 482365
Subaru Camshaft Sprocket Removal
Hi Guys and Gals. I work on Subarus a lot. I am a ASE Master. I made a video that solves removing these Camshaft bolts very easily with no failures to date for me. Its simple, its fast and no special tools are needed. The video is only a couple minutes long. I hope it helps someone else out.Here is the link.
~Shaun :) |
02-20-2018, 05:14 PM | #284 |
Member#: 73932
RMIC
Vehicle:2005 STi EFR 6758 04 S2000 EFR 7064 |
I basically did the same thing on a stand... I could not get the bolt out and had to drill. The leverage I had was provided by sticking a gun barrel of an F-16 on my ratchet. I broke bits and ratchets, and then stripped the Allen head.
In the end, drilling wasted less time for me. |
03-23-2018, 06:21 PM | #285 |
Member#: 482365
cam bolt removal watch this first!
Watch this video before you attempt any other method on the cam bolts. This should solve all problems. No special tools needed. ~shaun :banana
03-23-2018, 06:32 PM | #286 |
Member#: 375462
NWIC
Vehicle:2006 Impreza WRX STI WR Blue |
Thanks for the video... but did you really need to bump 5 other decade-old threads?
03-23-2018, 08:27 PM | #287 |
Member#: 93646
Vehicle:Many Track Records Let us help you go fast! |
if only someone made some nice easier to remove bolts for foresight of maintenance. Oh wait...
03-24-2018, 09:54 AM | #288 | |
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper BK, 5MT |
Note, if clamping a timing belt like that, I would likely NOT use it on an engine again. Maybe keep an old belt around just for this task. |
03-24-2018, 10:41 AM | #289 |
Member#: 396660
Vehicle:2015 WRX STI WRB |
03-25-2018, 09:35 PM | #290 | |
Member#: 482365
belt trick reply
05-11-2019, 04:23 PM | #291 |
Member#: 351744
TXIC
Vehicle:2004 WRX Wagon SRR |
Cam Pulley Bolts with Company 23 Tools and a HF 10mm Hex on a Breaker
So here's an example doing it with the tools on an unopened JDM EJ205. I'm not a big guy, and it wasn't that much fuss. It's similar (but with AVCS) to when I tore my 04 WRX EJ205 down.
04 Sti Cams and gears | xilles | Engine/Power/Exhaust | 6 | 12-23-2008 08:59 PM |
Any other ways to remove the cam sprocket on a sti without a special tool? | ride_the_pony69 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 7 | 09-09-2006 05:20 PM |
wtb jdm sti cam sprockets | wearejoy | Private 'Wanted' Classifieds | 8 | 01-22-2006 07:03 PM |
WTB: Sti Cam sprocket (cam gears) | HD-sw20 | Private 'Wanted' Classifieds | 0 | 09-30-2005 10:05 PM |
Cam shaft gear removal? HELP! | johndingk2 | Legacy Forum | 2 | 01-16-2005 10:27 PM |
