Welcome to the North American Subaru Impreza Owners Club Sunday February 18, 2018
Old 06-15-2006, 11:56 PM   #1
sgrassbaugh
Member#: 116505
2004 WRX Wagon-Stg 1
Default Where to run amp power cable from engine to cabin?
Couldn't find an FAQ or DIY on this - can someone please point me in the direction or give some pics of the best (hint easiest) to run amp power from engine to cabin (hopefully on driver side).
Thanks!
Sam
sgrassbaugh is offline   Reply With Quote
Old 06-16-2006, 12:04 AM   #2
aspitfire
Member#: 59916
2004 STi
on my '04 wrx there is a large hole in the firewall on the passanger side i just ran the power cable thru the rubber grommet, then ran it underneith the side plastic running board things (sorry dont know the proper name), then ran it up to the side of the back seat, and ran it to the trunk from there. Sorry not that good a decsribbing the areas but i easily ran a 4awg wire to the trunk.
aspitfire is offline   Reply With Quote
Old 06-16-2006, 12:17 AM   #3
clbd39
Member#: 104078
2013 WRX
i'm going to be replacing my 8 guage with 4 guage here in the next week so i can take a pic of where i'm running it if you still need it then
clbd39 is offline   Reply With Quote
Old 06-16-2006, 01:11 AM   #4
thedieselspeaks
Member#: 66475
2003 WRX Wagon
http://www.scoobymods.com/forums/sho...+wire+firewall
It looks like a WRX, but the concept is the same for most cars anyway.
thedieselspeaks is offline   Reply With Quote
Old 06-16-2006, 09:38 AM   #5
ekw
Member#: 92141
2004 STi-WRB on gold
Street prepped by TiC !
you can run it up the driver's side.
just keep it well separated from the head unit to amp signal runs.
and by 'well separated' i mean put the signal runs on the passenger side!
i ran my power up the center 'hump', signals on passenger side, speaker wire down the appropriate side, so that my amp power would not be near any of the others.
ekw is offline   Reply With Quote
Old 06-16-2006, 10:37 AM   #6
googooboy
Member#: 85306
2005 WRX obp
Stage Too Slow
through the rubber grommet behind the brake pedal. i cut a hole in it and passed my power cable through it. be careful when trying to put the rubber grommet back in the hole, it can be tricky to get it in the right position without popping back out.
then up the driver's side to the trunk! and run your audio cables behind the glove box and up the passenger side.
googooboy is offline   Reply With Quote
Old 06-16-2006, 01:25 PM   #7
02BlueSuperRoo
Member#: 78290
2011 WRX 5-door
SSM
I used the same hole as the first poster. On the passenger side, towards the left there is a nice sized hole. Although mine doesn't have a grommet anymore not that it has a boost gauge line, 4 gauge power wire, and power for my gauges. And yes, IBTyou'rewiresaregoingtogetcut, I know I should do something about it mayb but its packed tight.
02BlueSuperRoo is offline   Reply With Quote
Old 06-17-2006, 12:44 PM   #8
Blackchaos
Member#: 117775
04 Impreza STi
Like googooboy said, behind the brake pedal there is allready a precut hole with a rubber stop in it. Just pull out the rubber stop, cut a small hole in it. Best if the hole is smaller than your wire your running though. Then shove your power wire through it and now you can choose where to run it from there. I personally ran my 4 ga power wire up the drivers side. It is suprisingly easy to pop off all the panels to run the wire. No screws at all. I ran my Audio cables up the center console. Its best if you run your audio cables in a different spot than your power to prevent any noise. I recommend pulling the back seat (actuall sitting part not the back rest) it makes it a lot easier to pass the wires. Only 2 bolts holding it in, and very easy to reinstall it.
Blackchaos is offline   Reply With Quote
2008/2009 WRX Owners - Optimum place to run amp power wire Obsessive Car Audio, Video & Security 10 02-15-2016 07:19 PM
replacing the power cable from battery to car 949 Car Audio, Video & Security 1 09-16-2006 03:36 PM
Where to run amp power cables through firewall ? Mops Legacy Forum 7 10-24-2002 09:18 PM
Need help with splicing power cable from battery to amp and sub Jasno999 Car Audio, Video & Security 4 06-17-2002 03:29 AM
Where to run Amp Power Cable Scooby do Car Audio, Video & Security 2 07-17-2000 01:58 AM
