Welcome to the North American Subaru Impreza Owners Club Monday November 23, 2020
Old 12-28-2006, 02:57 PM   #1
Wade-O
Member#: 31190
2016 STI Limited
Default Raw fuel smell in cabin
My wife's stock 2002 2.5RS has just recently started having this problem. When the car is sitting with the engine at idle, the cabin starts to smell so strongly of gas/raw fuel that it makes my eyes burn and I even start to get a little light headed. The problem doesn't go away once the engine is warmed up. I asked her to take it to the dealership today since she works about a block away. They told her that they couldn't find anything wrong with it, and it could be the cold weather causing the fuel mixure to run rich, and just put the vents on recirc.
I disagree, but they said there is nothing else they can do. I told her to get new fuel and air filters when she picked the car up this afternoon and I would install them myself. The current fuel filter only has about 20k on it though. I couldn't see any visible signs of a fuel leak anywhere under the hood, but the smell seems to be the strongest in the passenger side fuel rail area. Any ideas?
Wade-O is offline   Reply With Quote
Old 12-28-2006, 03:41 PM   #2
Erconcepts
Member#: 59669
02 Bugeye
About a month ago, I was getting a raw fuel smell, I put my car on the lift and looked around and I found out that my gas filler neck in the back was leaking. Easy way to spot a gas leak is to look on the ground where you have parked for a long time, Gas should leave a cleanly marked area in the ground for you to notice.
If your smelling gas that strong then something is definitely wrong.
Erconcepts is offline   Reply With Quote
Old 12-28-2006, 04:05 PM   #3
Robstunner
Member#: 134222
2015 WRX Limited
ISM
look up raw fuel smell log on search link..
welcome to the club
Robstunner is offline   Reply With Quote
Old 12-28-2006, 05:07 PM   #4
Wade-O
Member#: 31190
2016 STI Limited
welcome to the club
Yeah, well, I'm no stranger to the raw fuel smell and associated TSB for the WRX. But this is my wife's 2.5RS, and the TSB doesn't apply that model.
Old 12-28-2006, 05:23 PM   #5
Robstunner
Member#: 134222
2015 WRX Limited
ISM
o. im sorry.. i skipped through that part
good luck to u anyway!
Old 12-28-2006, 05:40 PM   #6
Wade-O
Member#: 31190
2016 STI Limited
Yeah, I'm guilty of the same thing. "Smells like gas you say? Easy! It's the leaky fuel line TSB!" Then I got my head under the hood of her car and noticed that the plumbing is totally different. Then I looked at the TSB and saw that it was only for 2.0l engines. Doh!
Old 02-15-2007, 04:57 PM   #7
Wade-O
Member#: 31190
2016 STI Limited
Default Update
So this problem is still stumping me. Can anyone recommend a good procedure for finding a fuel leak?
Old 02-15-2007, 05:08 PM   #8
Calamity Jesus
Member#: 44501
that 's, like, your
alternate facts, man.
Light a match? Oh, wait.. scratch that, you asked for a good procedure.
Search for "gas leak detection" on Google, and try adding "soap" and "Windex" as those seem to be popular DIY tools.
Old 02-15-2007, 05:17 PM   #9
piker28
Member#: 22664
fuel filter spraying junk all around? dunno id try another dealer than if that one was to stupid to figure it out... or like any place you should ever bring a car sit there and show them the problem otherwise they could care less to try and fix it
piker28 is offline   Reply With Quote
Old 02-15-2007, 08:46 PM   #10
Subieformance_Guy
Member#: 108716
2004 2.1L, PT 6069
[email protected] Subarus-R-Us
check the hose that leads to fuel rails. Let the car run and watch for it. Even smell around under the hood to see whch side. So far I have fixed 3 with the new Gen 2.5 and it was the leaky fuel rail hoses.
Subieformance_Guy is offline   Reply With Quote
Old 02-15-2007, 11:03 PM   #11
Idahoreza
Member#: 116894
If the weather has been super cold the in lines and out line to the fuel filter tend to get a little loose. My buddy was just dealing with this problem, check to see if the lines are loose anywhere.
Idahoreza is offline   Reply With Quote
Old 02-15-2007, 11:56 PM   #12
Wade-O
Member#: 31190
2016 STI Limited
When you say the fuel rail hoses were leaking, do you mean the clamps were loose, or the hoses themselves were cracked/leaking? I've tried sniffing around, but honestly, it is so strong it's hard to pinpoint the source.
I'm really pissed at the dealership too, I can't believe they would say this is normal.
Old 02-16-2007, 01:38 PM   #13
recnelis
Member#: 92778
2000 Impreza 2.5RS
recnelis is offline   Reply With Quote
Old 02-16-2007, 01:52 PM   #14
Wade-O
Member#: 31190
2016 STI Limited
Originally Posted by recnelis View Post
Thanks for the link, it's nice to know I'm not alone in this. I'm pretty sure the leak is on the passenger side though. It sure would be easy to find if it were a visible drip like yours. At this point I think it's just small enough that it vaporizes right away.
I went through last night and tightened all the fuel line and fuel rail clamps that I could get to. Most were fine, but about 4-5 of them took a couple turns. Unfortunately, the passenger side fuel rail is almost completely covered by a shield that prevented me from getting to all of the clamps.
I definitely eliminated the fuel filter lines as a possible source. It took me about 30 minutes to get the old filter out because the hoses were so tight on it.
Old 02-16-2007, 05:35 PM   #15
Wade-O
Member#: 31190
2016 STI Limited
Well we just got back from lunch, first drive since I did my handiwork, and it still reeks. Not even a little better.
Old 02-23-2007, 11:20 PM   #16
midnight2.5rs-t
Member#: 126217
04 Jetta GLI
i now have joined this boat did not have it til my car went to the body shop for two weeks i will try to figure mine out tomorrow
midnight2.5rs-t is offline   Reply With Quote
Old 03-10-2007, 04:26 PM   #17
Wade-O
Member#: 31190
2016 STI Limited
Problem solved! Apparently the shop that did the 60K service forgot to reconnect the PCV hose after replacing the valve. Real nice that the Subaru service department couldn't find that.
Raw Fuel Smell Inside Cabin - WRX Kenneth2000 Warranty Issues & SOA Problems 13 12-21-2012 11:28 PM
Raw fuel smell in MT quoiasdaddy Warranty Issues & SOA Problems 3 01-08-2010 06:47 PM
Need Help For Raw Fuel Smell in Cabin roburXunitas South East Region Forum 6 01-04-2008 06:43 PM
Horrible Gas Mileage/Raw gas smell in cabin ScoobySnacker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 12-18-2007 08:14 PM
need help - fuel smell in cabin and engine bay nhluhr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-06-2002 08:38 PM
