Welcome to the North American Subaru Impreza Owners Club Monday November 30, 2020
Old 11-22-2012, 09:00 PM   #1
w0ng3r
Member#: 305528
Default Jack point failure
I was jacking up my car using the oem jack, placed it under the front jack point. I've done this at least a dozen times by now, so when I heard a cracking noise followed up by a loud thump, I thought to myself, "FK"
I had stepped away to grab a jack stand when it happened, this is the aftermath:
https://dl.dropbox.com/u/12397062/image_1.jpeg
I'm just glad I wasn't under the car when it happened, can I file a claim with subaru? Not looking to pay 400 bucks for a new pair of OEM side skirts that failed so hard.
w0ng3r is offline   Reply With Quote
Old 11-22-2012, 09:39 PM   #2
PlasticFoamMan
Member#: 197764
2002 Nissan Frontier
buh bye WRX :(
Looks to me like you were lifting it on the side skirt, not the jack point. I lift on the inside of the frame seam/pinch weld, never had a problem lifting any corner out of hundreds of times doing so.
Definitely not a warranty or defect issue unless you literally punched through your frame somehow, and THAT I would like to see
PlasticFoamMan is offline   Reply With Quote
Old 11-22-2012, 11:01 PM   #3
Zefy
Member#: 105104
1979 BRAT / 01 RSTI
99 2.5TS (DEAD)
ya looks like you were not in the correct spot. If where you were jacking is where that picture is pointing, you were in the middle of the vehicle. You're supposed to use the OEM jack pretty much right beside the wheel well. There is a reinforced section of the pinch seam for it to sit on.
Zefy is offline   Reply With Quote
Old 11-23-2012, 12:17 AM   #4
garudatwo
Member#: 322385
Sorry bud, I agree with the other gents before me, looks like you were using the sideskirts for support, and not that pinch weld.
Way to....jack up your own car.
garudatwo is offline   Reply With Quote
Old 11-23-2012, 12:53 AM   #5
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
doh
Old 11-23-2012, 07:37 PM   #6
Supraru
Member#: 23313
99' 2.5Rs
black
You know if people just read their damn owners manual when trying to do things or figure stuff out there would be a lot less issues.
Supraru is offline   Reply With Quote
Old 11-23-2012, 08:40 PM   #7
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Wow... you jacked up from the sideskirt? Did you not notice the reinforced metal jacking point? Going to go out on a limb and say Subaru isn't going to pay for them... good luck...
DrD is offline   Reply With Quote
Old 11-23-2012, 08:44 PM   #8
Zulu-
Member#: 232213
I don't think it was the skirts that failed.
Zulu- is offline   Reply With Quote
Old 11-23-2012, 08:49 PM   #9
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
you might want to peek under while jacking next time. if you were on the pinch weld, there is no way that would happen.
Old 11-23-2012, 10:07 PM   #10
sc00by4life
Member#: 97135
you are full retard.
you're now going to have to pay $400 bucks for a new pair of sideskirts because YOU failed so hard.
i'd venture to say that you should learn from this lesson, and not work on your own car....
Old 11-24-2012, 12:17 PM   #11
fenderpicks
Member#: 287694
You put it too much onto the left side of the skirt... meaning u had all the weight on the skirt... not onto a frame or sturdy point...
common sense man lol
fenderpicks is offline   Reply With Quote
Old 11-24-2012, 05:34 PM   #12
Tenament
Member#: 246813
OP, I have a set of JBP side skirts, 8/10 condition, for sale PM me!
Tenament is offline   Reply With Quote
Old 11-24-2012, 08:29 PM   #13
424wrx
Member#: 171948
08 wrx stg3 vf52
14 legacy, 11 fozzy
hes got a 2011 car man
Old 11-27-2012, 08:24 AM   #14
Tenament
Member#: 246813
Doh. Still, is funny he's trying to say the side skirts "failed so hard" when he indeed, failed in putting the jack in the right place.
Old 11-27-2012, 10:00 AM   #15
KC
Member#: 442
17 Imp Spurt
00 S2k
For future reference....
There are four reinforced jack points on almost every car. Two on the right, two on the left. Both inboard from the wheels by about 6-12".
The re-inforced seam near the rear wheel shown below in the picture fits in the slot on the jack top. The top of the jack should be placed in-between those two dimples. Both sides of the jack top come into contact with the re-inforced portion of the frame made to accept the jack and extra weight, surrounding the seam.
This is a standardized design for almost every car made to jack a car using OEM scissor jacks. Only use these points when jacking using the supplied scissor jacks. (There are other places one can jack a car from using better floor jacks, but that is a separate topic).
What you did is user error, not a warranty/Subaru issue. Jack point locations and instructions are firmly covered (by law) in every car user manual. Good luck in the repairs. You own the damage. And yes, you are lucky to have not been under the car at the time. Consider this mistake the less costly of the two and learn from it.
--kC
KC is offline   Reply With Quote
Old 11-27-2012, 11:46 AM   #16
lordgrinz
Member#: 293423
2011 WRX Limited 5dr
WRB SPT/Stock
I really wish they used the same jack point setup of my 2003 MINI Cooper, those rubber block jack points were nice. But yeah, bad mistake on your part, you are lucky you weren't under it!
lordgrinz is offline   Reply With Quote
Old 11-27-2012, 12:35 PM   #17
manticus
Member#: 162857
So true. I read the WRX/STI car manual front to back 4 months before I took delivery of the car. Sure helped with maintenance and day-to-day operation.
This guy could have been killed...
manticus is offline   Reply With Quote
Old 11-27-2012, 02:46 PM   #18
Navendra94
Member#: 327495
2012 Impreza WRX 5DR
Plasma Blue
... did you seriously jack a car up from it's side skirts.
Navendra94 is offline   Reply With Quote
Old 12-03-2012, 12:41 AM   #19
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP 2016 Sienna
idk how many of you guys have actually tried to jack up a GR but the side skirts kind of get in the way of the jacking points...its kind of a pain in the ass. I've never done anything quite as fail as the OP, but the bottom of my side skirts aren't too pretty anymore. There are other places to jack it up from but they aren't that easy to reach with my floor jack anyway.
Old 12-03-2012, 01:03 AM   #20
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
You can't reach the center of the front cross-member (that's the primary front jacking point when using a floor jack) or the rear differential (that's the rear jacking point)? - if you are going to use a floor jack on the side jacking points, you are supposed to use something to capture the seam... most folks don't have something, but a block of wood would probably work... then again, if you're using a floor jack, why not jack from the two locations designed for that... just sayin'
Old 12-03-2012, 01:08 AM   #21
garudatwo
Member#: 322385
If his car is lowered, it's almost impossible to get the front crossmember up with a floor jack. You can't get it up on rhino ramps either.
At least not the conventional way. My friend and I stuck the ramps at an angle behind the front wheels to get the nose high enough for the jack.
Old 12-03-2012, 01:13 AM   #22
Celery GT-5
Member#: 98210
edit: +1 ^^^
yeah probably, you can get it to work without actually destroying your side skirts though, just pinches the bottom plastic a bit while you are putting jack stands under it.
on a lowered car I think its hard to reach the front cross member with a floor jack too
a block of would would just crush the bottom of the side skirts too, there is only a very small opening in the plastic for the scissor jack
I can just barely get my car onto rhino ramps but it scrapes a bit...I only have a 1.2" drop or something...idk the hellafail guys must have issues
Old 12-03-2012, 01:50 AM   #23
garudatwo
Member#: 322385
My '11 with Eibach springs had a 13.5" hub to fender distance, and it was about half an inch too low for Rhino ramps. Now that I'm running RCE blacks for STI's, I have about a 5mm lift all around and boy am I glad for it. I think the hella flush gents have to use 2x4's to get up on race ramps.
Old 12-03-2012, 07:24 AM   #24
Supraru
Member#: 23313
99' 2.5Rs
black
I do it every day with a lift. Not once have I crushed a skirt.
Get a low profile race jack. Got my cheapie harbor freight aluminum race jack for maybe 120 bucks. If you're still to low then use the stock jack on one side to get it high enough to get it under or just drive up onto some wood. Problem solved.
Old 12-03-2012, 08:11 AM   #25
sc00by4life
Member#: 97135
conventional floor jacks aren't designed to lift by the body seam without a special adapter like this: http://www.eastwood.com/floor-jack-a...odel-cars.html
the body seam jack points are designed to be used with the OEM scissor jack.
