Welcome to the North American Subaru Impreza Owners Club Friday January 17, 2020
Rocky Mountains Impreza Club
Go Back   NASIOC > NASIOC Chapters > Rocky Mountains Impreza Club Forum -- RMIC
Old 02-16-2009, 05:13 PM   #1
LazyRacer07
Member#: 158309
2007 impreza WRX
pearl white
Default Which is a better turbo for efficiency and availability for quick responsive spool up
I am looking at a VF48 and a FP 18G and i want to run about 20lbs of boost on 550 injectors
LazyRacer07 is offline   Reply With Quote
Old 02-16-2009, 06:15 PM   #2
Version:88
Member#: 174377
2006 Forester X
Thick around the thighs
You will need to upgrade your injectors for sure. I have a FP RED and it spools about 3500 rpm's.
Hope that helps? PM with any other ?'s
Version:88 is offline   Reply With Quote
Old 02-16-2009, 06:56 PM   #3
bhhamblin
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
I had an FP 18g on my 2006 wrx with stock injectors at about 18-19lbs of boost and i loved it. If you wait a couple days my friend is putting a vf48 on his 07 wrx.
bhhamblin is offline   Reply With Quote
Old 02-16-2009, 06:58 PM   #4
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
brody what idc were you seeing at 19 psi on that turbo? seems maxed on stock injectors?
06HAWKMAN is offline   Reply With Quote
Old 02-16-2009, 07:01 PM   #5
Stames_wiltz
Member#: 143264
2006 WRX TR
Obsidian Black Pearl
1) the stock injectors are 565cc, the same as the STi.
2) The FP Red is a bolt on GT35R with a small turbine. Should be a 4200 rpm turbo. So how Version:88 is getting full spool by 3500 rpm is beyond me
3) Neither turbo's. 20 psi is out of there efficiency zone. You would be better off with the APT GT3071R or the Blouch Polka pickle for those boost levels. The VFxx turbo and 18G are more of a 17-18 psi turbo. You can take the VF and 18G to 20+ psi but it will start tapering fast shortly after.
If you want to stick with the stock injectors, take a look at the APS SR30 or the ATP GT28R. They are similar to the VF turbo but will spool faster and make slightly more power. Plus they will last longer being a CHRA.
If you choose to get a turbo based on boost goals, you will need 750cc injectors. In my honest opinion, for the 2.5L I wouldn't do anything smaller than a 20G if you are going with a bigger turbo.
Stames_wiltz is offline   Reply With Quote
Old 02-16-2009, 07:03 PM   #6
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
I know the inj. are 565cc the reason i ask is because i am maxing my stockers out on the ewg'd vf39
Old 02-16-2009, 07:09 PM   #7
Stames_wiltz
Member#: 143264
2006 WRX TR
I wasn't referring to you. I was posting for the OP. and hawkman, you are making as much power as brody was on his 18G
Old 02-16-2009, 07:09 PM   #8
bhhamblin
Member#: 99397
15 WRX, 83 DR30,
honestly i cant remember. but i remember it being like 91.x%
Old 02-16-2009, 07:11 PM   #9
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
How is it that I am making close to the same power? I dont understand? to the o.p. what are the goals for the car and what is the budget?
Old 02-16-2009, 07:14 PM   #10
bhhamblin
Member#: 99397
15 WRX, 83 DR30,
Maybe I am retarded. But you made more power than I did. I had my car tuned by Christian, I made 270whp and 298tq
Old 02-16-2009, 07:16 PM   #11
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
and i made 272whp and 290 wtq on a conservative tune?????????
Old 02-16-2009, 07:24 PM   #12
bhhamblin
Member#: 99397
15 WRX, 83 DR30,
hmm weird I dont know. but i do have some 750cc injectors ill sell you in about 3 weeks haha unless my buddy ends up buying them.
Old 02-16-2009, 07:34 PM   #13
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
k i will take them, dibs if you dont sell.
Old 02-16-2009, 07:36 PM   #14
bhhamblin
Member#: 99397
15 WRX, 83 DR30,
okay
Old 02-16-2009, 09:27 PM   #15
Stames_wiltz
Member#: 143264
2006 WRX TR
RMIC off topic again
Old 02-16-2009, 09:52 PM   #16
06-wrx-tr
Member#: 185106
2006 Subaru WRX WRB
Mazda protege'
i have a vf48 coming in.. i'll let ya know what kinda power/spool i make
06-wrx-tr is offline   Reply With Quote
Old 02-16-2009, 09:54 PM   #17
Stames_wiltz
Member#: 143264
2006 WRX TR
seriously!!! You have a VF39 already, the VF48 isn't going to do much of anything for you. (Emoticon for banging head against a brick wall)
Old 02-16-2009, 10:02 PM   #18
06-wrx-tr
Member#: 185106
2006 Subaru WRX WRB
Mazda protege'
ya a blown cracked pos 39. i went vf48 cause the price was right.
Old 02-16-2009, 10:08 PM   #19
Stames_wiltz
Member#: 143264
2006 WRX TR
OKAY, that makes more sense. I just realized that you are the TurboJunkie rebuilt VF39. You should still go bigger.
Old 02-17-2009, 11:12 AM   #20
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
I am not with the whole bigger is better crew. I just want lightning spool and semi good top end. It is after all a DD, I think 300-350whp is just about right for a DD. Also I think that a vf48 set up with an inlet,ebcs,ewg,ported exhaust mani,crosspipe,ported intake mani and tgv deletes could make some sick power and be a great commuter car.
Old 02-17-2009, 11:46 AM   #21
Stames_wiltz
Member#: 143264
2006 WRX TR
Have you ever driven a car with a "bigger turbo?" I can assure you that the 45-52 lbs minute turbo's spool up only a few 100 rpm slower than the VFxx turbo's on the 2.5L. And when making 120 more WHP up top, that few 100 rpm spool doesn't matter.
Drop a gear and my spool is just as fast as the stock turbo, from a same gear roll you may have a 5 foot initial jump, but then I will have a semi trailer lead by the end of the gear.
Old 02-17-2009, 12:00 PM   #22
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
Well my friend that is why you need to take me for a ride so you can change my mind
Old 02-17-2009, 12:05 PM   #23
r8r4life
Member#: 101464
Dom III pussie turbo.
r8r4life is offline   Reply With Quote
Old 02-17-2009, 12:12 PM   #24
06HAWKMAN
Member#: 166626
2006 wrx ewg vf39'd
obp
anyone have any expierience with the polka pickle?
Old 02-17-2009, 12:26 PM   #25
Stames_wiltz
Member#: 143264
2006 WRX TR
I don't know why you keep saying that. It is the same turbo you have but on a bolt on fashion.
Which is a better defense for a ticket? sha_zapple Off-Topic 30 08-06-2008 05:25 PM
Which is a better turbo? TurboSlime Tri-State Area Forum 6 04-26-2004 02:03 PM
Which is a better picture for my Credit Card? chrisdeaner Off-Topic 20 01-06-2003 04:23 PM
Which is a better Turbo timer? Genner Newbies & FAQs 8 05-06-2002 03:14 AM
