Welcome to the North American Subaru Impreza Owners Club Saturday January 25, 2020
Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 03-20-2013, 11:19 AM   #51
robo_robb
Member#: 350815
2001 Legacy GT
I registered just to reply here. Sorry for resurrecting an old thread, but I just want to thank you, subeman, for posting this. I just purchased an '01 Legacy GT 5 speed (absolutely love it!!) and will be doing an outrageous amount of highway driving with it in the next 4 years. I'll be commuting to grad school 160 miles a day. I think my car's stock 5th gear ratio is .85 - I'm at around 3.5k @ 75mph. The rpms are so high I feel like it's really stressing the engine. I'm going to try to ask my Subaru dealer if they are comfortable with changing my gear to the .738 from the WRX... the lower the better (there's nothing lower that fits, is there?).
Thanks again for the detailed post!
robo_robb is offline   Reply With Quote
Old 03-20-2013, 12:47 PM   #52
subeman90
Member#: 65681
13 XV Limited
gray
nope there is no lower.
I have a feeling that the dealer will say no way to doing that...or they are going to charge you out the a$$. Google map reinholds PA and see if it is a reasonable distance for you. You could go to the guy that did mine.
Glad to be of help.
subeman90 is offline   Reply With Quote
Old 03-20-2013, 01:36 PM   #53
robo_robb
Member#: 350815
2001 Legacy GT
Reinholds isn't too far-- about 80 miles away. I might take you up on your suggestion! What do you think I should expect to pay for a job like this?
Old 03-20-2013, 03:08 PM   #54
subeman90
Member#: 65681
13 XV Limited
gray
budget $400 in labor ((estimate)for the guy I went to) and parts you can call around to get a good price.
If you do go that route I'll hook you up with info and who to talk to, they will be very upfront with you on cost etc.
Old 03-20-2013, 04:28 PM   #55
robo_robb
Member#: 350815
2001 Legacy GT
Great! I'll go ahead and shop around for the parts. I'll circle back in a bit!
Old 05-28-2014, 12:17 AM   #56
CRX7
Member#: 31639
99 Impreza
Note, in order to get this to work with phase 1 transmissions. You need to change out the synchro hub assembly as well, as the synchros are not compatible.
BTW, this can NOT be done on the car. Taking the end housing off requires a lot of manipulating movement which would not be possible in the tight transmission tunnel.
CRX7 is offline   Reply With Quote
Old 06-04-2014, 11:04 PM   #57
subeman90
Member#: 65681
13 XV Limited
gray
well mine was in the car and we are talking about Baja's here not phase 1 transmissions.
Old 06-06-2014, 05:29 PM   #58
ristiphx
Member#: 289781
I do know an amateur mechanic who swapped a 2004 sti 6 speed into an 02 wrx with differential and all. I wonder if anyone has done this on a turbo?
ristiphx is offline   Reply With Quote
Old 10-14-2014, 02:10 AM   #59
CRX7
Member#: 31639
99 Impreza
So I actually did this, not a shop.
1) you need access to all the bolts on the exterior or the case, this would be difficult with it in the tunnel
2) To get the end casing off the shifter forks you need to tilt it at some funny angles, nevermind getting it back on with the forks in the right position. This would be next to impossible in the tunnel.
3) The 3 large nuts on the ends of the shafts need are locked and need to be unlocked with a chisel then you take an impact wrench to get them off.
4) The 50mm nut holding 5th gear is very difficult to take off and requires a special tool or two 50mm sockets welded together.
5) The 5th gear shift fork needs to be removed by hammering out the roll pin.
6) 5th gear had to be pressed/pulled off with a very fine toothed gear puller.
7) This all has to be put together nicely with everything clean as it is the inside of a transmission so that it seals well and does not leak. Good luck doing that in the transmission tunnel.
I'm not saying I don't believe you, but that mechanic you had do this has to be the most skilled mechanic I've every heard of. I do all my own work and this is not my first transmission to take apart, and this was a very technical and difficult job for me. I did it with a spare transmission and swapped them.
Maybe I'm off topic, but I gave the info for phase 1 transmissions, in case any one with a phase 1 tries to do this. There isn't much info on the net on doing this swap and I thought it would be helpful info. Swapping the synchro hub assembly is easy, you just need to source it.
BTW, I've got it in, it's working, and God it is beautiful. Car is so much nicer and quieter at speed, I'm passing everyone and wondering why they're going so slow, look at my speedo and realize I'm going too fast.
And power, I'm running a TD05 which spools a little later 3300 to 3500 rpms, and I've still got plenty of passing power in 5th with the .738 and 4.11 final drive. I don't recommend anything higher for a US Highway cruising gear.
Thanks for your write up and helpful information, it inspired me to do this swap, just adding to the info.
Old 05-06-2015, 10:21 AM   #60
clint78z
Member#: 235144
I have a question for CRX7. I am looking to do the 5th gear swap on JDM STI 5speed DCCD RA box. If you could elaborate on what tools you used to get the nuts off the shafts, did you use the special tool or modify a socket??. Will any of the 5th gears fit the phase 1 transmission. Just looking for a bit of clarification before I jump right in. Looking forward to this swap.
clint78z is offline   Reply With Quote
Old 05-29-2015, 07:41 PM   #61
CRX7
Member#: 31639
99 Impreza
The main issue is the 50mm nut as it needs the special subaru tool or a very deep 50mm which doesn't exist. I took two 2" sockets from tractor supply, cut the end off one and welded them together. Otherwise the other socket you need is a 32mm I think.
Old 05-29-2015, 07:45 PM   #62
CRX7
Member#: 31639
99 Impreza
You just need a phase 2 syncro hub, and I would assume any corresponding phase 2 5th would fit, but I only have experience with the 0.738
Old 05-31-2015, 02:44 PM   #63
Baja_Gernaut
Member#: 229922
2005 F-Inductd BAJA
rumble black
Gee, this sounds so complicated
Baja_Gernaut is offline   Reply With Quote
Old 06-15-2015, 11:36 AM   #64
Mr.Chow
Member#: 256390
2004 Baja Turbo
Dark Blue
I'm very interested in the 5th gear swap too as I have a 99 v.5 RA box coming this week. So as far as parts (and I think I'm going to have a transmission shop do the wrenching and inspect the trans) I'll need the following:
-phase 2 syncro hub
-phase 2 fifth gear .738
CRX7, would this be all I would need to provide the shop to do the swap?
Mr.Chow is offline   Reply With Quote
Old 11-27-2019, 05:03 AM   #65
mihael
Member#: 296973
2007 Forester XT
I am really glad to announce that I finished installing a .634 5th gearset (that I got from a 5MT diesel) into my 5MT on my Forester!
Thanks to everyone for everything that was posted here... it really helped and encouraged me to do the job.
I did it with the gearbox out of the car because I changed the whole case and the front differential as well. But, after putting everything together I realised I installed the hub for the 5th gear backwards and I solved that with the transmission on the car - more details and a picture for that here: https://forums.nasioc.com/forums/sho....php?t=2912115 - so, I guess you could do the 5th gearset change with the transmission on the car but you need the gearpuller and the 50mm extra deep impact socket... But there is space. I recommend getting the transmission out of the car though - this way you can inspect the clutch. Plus, putting back the extension case in the horizontal position was a real pain!
mihael is online now   Reply With Quote
Old 12-02-2019, 04:59 AM   #66
mihael
Member#: 296973
2007 Forester XT
After a long drive I can say that there is no noticeable improvement in fuel economy so, the greatest gain is the fact that I don't need to go over 3000 rpm on the highway anymore so the engine does not struggle anymore and it should not use that much oil as before when I was driving it at 3500 rpm.
Old 12-28-2019, 12:58 PM   #67
steven765
Member#: 105920
2006 Baja 5 Speed
subeman where are you located. Based upon the thread I bought the taller 5th gear. However not attempting this myself. I don't touch transmissions besides fluid.
steven765 is offline   Reply With Quote
Anyone know ratio of 5th gear in a Legacy SS? shemoves Legacy Forum 1 10-31-2006 07:17 PM
My 5th gear was acting stupid yesterday styng88 Mid Atlantic Impreza Club -- MAIC 6 02-03-2006 05:26 PM
How difficult to change from JDM 6th gear ratio to USDM? BADWRX Transmission (AT/MT) & Driveline 4 08-16-2003 12:46 PM
5th gear ratio? yamarocket630 Mid West Subaru Owners Club Forum -- MWSOC 1 07-02-2002 12:39 AM
Whats wrong with my 5th gear? Vitamin-K General Forum Archive 1 11-07-2000 12:10 AM
