Welcome to the North American Subaru Impreza Owners Club Thursday January 23, 2020
Old 09-27-2019, 09:11 AM   #8301
dpetro1
Member#: 487500
2018 WRX
Originally Posted by Pande View Post
I am leaning towards
18x8.5 +44 Off Set 265/35 .. Thoughts??
I would stick to a stock tire size on that wheel.
Edit: I see you have a 2015. 245/40/18 is a good size for an 8.5" wheel (stock size on 2018 premium)
dpetro1 is offline   Reply With Quote
Old 09-27-2019, 04:44 PM   #8302
Pande
Member#: 506705
Originally Posted by Norm Peterson View Post
For 265/35's?
9.5" wide.
Norm
18x8.5 245/40 +44 off set
Pande is offline   Reply With Quote
Old 09-27-2019, 09:26 PM   #8303
wuuusaa
Member#: 92894
2015 Wrx
That's correct, wouldn't recommend that wide of a tire on 8.5" wheel.
Old 10-01-2019, 12:16 AM   #8304
Pande
Member#: 506705
Decision has been made
I've ordered these
http://www.autotechnik.com.au/index....product_id=892
18x8.5 +44 offset rubber on the rims will be 245/40/18
Old 10-01-2019, 08:31 AM   #8305
ChriS2000
Member#: 480264
2017 WRX
I've ordered these
Those are the wrong bolt pattern. You need 5x114.3.
ChriS2000 is offline   Reply With Quote
Old 10-01-2019, 10:28 AM   #8306
standardtranny
Member#: 450713
2017 WRX Stage 3ish
world rally blue
lol good catch
standardtranny is offline   Reply With Quote
Old 10-01-2019, 03:36 PM   #8307
Pande
Member#: 506705
Originally Posted by standardtranny View Post
lol good catch
I clicked the wrong link haha
Old 10-02-2019, 07:35 PM   #8308
Stoleyourboard
Member#: 483007
2018 Subaru
ISM
9.5 +22; 255/35 Ad08r
Stoleyourboard is offline   Reply With Quote
Old 10-02-2019, 07:55 PM   #8309
Pande
Member#: 506705
Just PM'd you! that WRX sits so so nice!
Old 10-03-2019, 11:44 AM   #8310
Molo35
Member#: 506556
Can someone tell me the best setup if I知 keeping suspension stock? I知 hearing 18x9.5 +38 offset is that true? What size tires ?
Molo35 is offline   Reply With Quote
Old 10-07-2019, 06:48 PM   #8311
evei0326
Member#: 451587
My setup is best setup.
19x9.0 +50mm 275/30R19 stock sus no rub no fender rolled.
if you can, grab O.Z. ULTRALEGGERA 18x9.0 +55mm with 5mm spacer and run 275/35R18
Cheers,
evei0326 is offline   Reply With Quote
Old 10-08-2019, 12:08 PM   #8312
kaeknows
Member#: 357191
2016 WRX
ISM
N O
kaeknows is offline   Reply With Quote
Old 10-08-2019, 12:19 PM   #8313
Stoleyourboard
Member#: 483007
2018 Subaru
ISM
Cheers,
19's look horrendous on these cars
Old 10-14-2019, 01:39 PM   #8314
buschman
Member#: 49615
2018 WRX
WR Blue
I notice a lot of guys are moving to 9.5 width rims and moving up to 255 or 265 tires. I myself am also considering doing this. I'm curious if those that are moving up in tire size are also correcting their speedometers or just living with the error?
What I'm finding kind of tricky is the vast majority of wheels, including all the ones I really like, seem to come in 8.5 and 9.5 widths, not 9.0. What I've noticed is my stock setup(245/40R18) is exactly 1 mph slower than GPS(Speedo shows 80mph/GPS shows 81mph). Thus, if my calculations are correct, a 255/40R18 would by slightly larger diameter and read almost exactly almost exactly 1mph faster than the 245s. So it would just correct the built in error I have from the factory.
Issue for me, and this is just me, I'm not knocking it, I'm not a fan of the stretched look. So on a 9.5 in rim, I'm guessing a 265 would fit just right. If I go 265/35 A/R my wheel diameter is smaller than the 245/40 and thus I introduce more error(Speedo 80/GPS 82.26). If I go 265/40 I over correct(speedo 80/GPS 79) and then my tire is .6 in taller. I haven't heard of many running this setup. But I have to assume rubbing becomes an issue unless you introduce camber(not interested).
So this is a long winded way to see if anyone else grappled with this when making your decision? Did you have a way to correct your Speedo? Or do you just live with it and it doesn't bother you.
Thanks
buschman is offline   Reply With Quote
Old 10-14-2019, 01:53 PM   #8315
nappyrat
Member#: 307012
Thanks
I just live with it; I'm currently on 18x9.5 265/35 and it's off by ~1 mph. I couldn't tell the difference in 1 mph and a cop wouldn't pull me over for 1 mph over so it's whatever
nappyrat is offline   Reply With Quote
Old 10-14-2019, 02:19 PM   #8316
Norm Peterson
Member#: 498642
'19 WRX Limited 6M
'08 Mustang GT (the toy)
Over the years I've owned several cars whose speedometers were known to be off, either from the get-go or after tire sizes or axle gears were changed. And the speedometers in at least two of those cars were inop for extended periods of time. I remember driving one of those on a longer trip and keeping a rough track on speed by converting the number of seconds between mile markers to mph, and driving by converting the tach reading to mph in another.
That's kind of a roundabout way of saying I don't worry much about speedometer accuracy. Don't look at the thing all that often anyway.
I will admit to having eventually corrected speedometers - but only when it was convenient to do so. I didn't even consider trying to correct the Mustang's speedometer when I went to tires a whole inch or more shorter than the OE sizes. I may not even bother when I get an axle gear swap finished (it's not a very big ratio change, but it will exaggerate however much error it's at now). At least not right away.
Norm
Norm Peterson is offline   Reply With Quote
Old 10-19-2019, 04:25 PM   #8317
Pande
Member#: 506705
Finally got my wheels on my 2015 WRX
https://imgur.com/gallery/CyD4HfQ
Old 10-20-2019, 02:31 PM   #8318
honeybucket
Member#: 505996
Care to share some info?
Wheel size, tire size, suspension mods?
Edit: Scrolled back a little and found your specs. Looks good.
honeybucket is offline   Reply With Quote
Old 10-20-2019, 02:54 PM   #8319
wuuusaa
Member#: 92894
2015 Wrx
^^ Pretty sure he's still on stock suspension.
His wheel setup - 18x8.5 +44 offset rubber on the rims will be 245/40/18
Old 10-20-2019, 10:28 PM   #8320
JRowland
Member#: 454620
2017 WRX
Red
Looks great
JRowland is offline   Reply With Quote
Old 10-21-2019, 02:25 PM   #8321
Pande
Member#: 506705
Wheels are
SSR GTX 01- 18x8.5 Offset 44
Rubber: 245/40/18
Coilovers have been ordered looking to lower the car 20mm all round so the wheels can tuck in nicely.
Overall I知 very happy with the end result
Old 10-21-2019, 03:45 PM   #8322
vlad11591
Member#: 295970
2019 STI
CWP
19 sti, using my winter set up from my old wrx
225/45/18 with Koni Rajin with offset of 50
I should be ok on stock suspension?
vlad11591 is offline   Reply With Quote
Old 10-21-2019, 06:31 PM   #8323
Pande
Member#: 506705
...Should be ok.....
Old 10-22-2019, 10:58 AM   #8324
ChriS2000
Member#: 480264
2017 WRX
Wheels are
Rubber: 245/40/18
Do you happen to have any pictures from the front that show how far in the wheels are from the fender? Debating going with a similar spec wheel.
Old 10-22-2019, 12:38 PM   #8325
dpetro1
Member#: 487500
2018 WRX
They will be 11mm (1cm) out from stock. Pretty conservative setup. Maybe you can measure off your car to get a better idea?
