Welcome to the North American Subaru Impreza Owners Club Sunday January 19, 2020
Old 06-27-2019, 01:40 AM   #1
Twitch_PA
Member#: 286170
2006 WRX Wagon
Default Twitch's 6870 Wagon Build
Hey guys. Figured it's time to post up my build we are finishing up.
06 Wrx Wagon
20180427_182730 by Seth Burggraf, on Flickr
Iag Magnum 2.7 Fire Lock block
Iag CNC port and polished heads
14mm arp studs
Gsc guides
Gsc beehives
Gsc s2 cams
Super tech +1 exhaust
Super tech +1 intake
Gsc keepers
Gsc retainers
Gsc locks
12mm oil pump
Iag tgv delete
Killer B oil pick up and baffle
Killer b oil pan
Iag comp aos
Ets rotated vband kit
Rotated 6870 h sport compressor
Treadstone front mount
Iag comp pitch stop
Iag comp engine mounts
Iag comp trans mount
Torque solutions rear diff lockdown
Torque solutions rear subframe lockdown
Full 06 sti drivetrain swap
P&L Triple Disk with Push conversion
White line 24mm front and rear bars
Dba rotors
Hawk pads
06 sti brembos
Dss carbon driveshaft
Dss 800 hp rear axles
Insane Shafts 500 Front axles
06 sti dash
Braided brake lines
Radium surge tank
3x walb 525
8an feed and return
ID 2000s
Iag fuel rails
Cobb flex fuel
Invidia n1 resonated cat back
Ets big tube ELH
44mm tial gate
50mm tial bov
Fortune auto 500 coils
Fun stuff
Gs hood struts
Impreza sleeper hood
Painted the manifold black
Aohdan black 18x10
Custom flares
Sparco r333s
Flossy grit black knob
Defi gauges to match 06 sti dash
Video of first start after cam break in:
Will post dyno when I get it done. Broke cams in 2 weeks ago and just waiting on fuel system and break in miles now. Pics of the build below. I'm up in pa.
20190503_202814 by Seth Burggraf, on Flickr
20190503_195239 by Seth Burggraf, on Flickr
20190422_145455 by Seth Burggraf
[IMG]20190521_203503 by Seth Burggraf, on Flickr[/IMG]
Twitch_PA is offline   Reply With Quote
Old 06-27-2019, 01:45 AM   #2
Twitch_PA
Member#: 286170
2006 WRX Wagon
Old 06-27-2019, 09:18 AM   #3
bdubblu
Member#: 251046
2004 WRX Wagon
Stage 5.1.2a.2
Sweet build! You should get at least 300 hp to the wheels.
bdubblu is offline   Reply With Quote
Old 06-27-2019, 10:32 PM   #4
Dave D.
Member#: 130990
06 Red Ltd.Wagon
Dom 1.5xtr JJ tuned
Couldn't have found a better model to put it in! Similar in many ways to my build; I predict a sizeable more amount of whp, however.
Old 06-28-2019, 01:54 AM   #5
Twitch_PA
Member#: 286170
2006 WRX Wagon
Default Thanks
Thanks. The old setup was an fp black and an iag stage 2 block with stock heads on e85 it made 500 whp 460 wtq so I was kinda capped with that block.
I'm looking for a 600 whp daily tune and an 800 to 850 whp shootout tune.
Theres alot more done to it than listed but I'm building a 400 sbc for my 66 nova so I'm kinda double tasking. This is the car last year. I'll post a pic after I get it back from tuning at TPG Tuning in export PA. big shoutout to them for taking care of putting in the fuel system and handling the tuning !
20180427_181649 by Seth Burggraf, on Flickr
20180427_181341 by Seth Burggraf, on Flickr
20180427_181815 by Seth Burggraf, on Flickr
Old 07-01-2019, 12:07 PM   #6
bdubblu
Member#: 251046
2004 WRX Wagon
Stage 5.1.2a.2
http://<a href="https://flic.kr/p/2g.../a>, on Flickr
Say, what flares did you end up using? And what is your wheel fitment as a result?
Old 07-09-2019, 07:58 PM   #7
Twitch_PA
Member#: 286170
2006 WRX Wagon
Default Pics
IMG_0029 by Seth Burggraf, on Flickr
IMG_0028 by Seth Burggraf, on Flickr
IMG_0027 (1) by Seth Burggraf, on Flickr
The fender flares are 2 rear sets of Honda s2000 fender flares. I did not come up with this idea. I saw a YouTube video and figured I'd take a dive. They actually work really well. The pictures you see are wrx hubs with 20mm adapters but they fit even better now with the sti hubs and no spacers. I will post specs and the website and everything shortly.
Old 07-17-2019, 09:29 PM   #8
Twitch_PA
Member#: 286170
2006 WRX Wagon
Default Break in tune
Got her home today. Break in tune is making 600 whp till I put another 500 miles on it (1000 all together) then she goes back for the kill. Hit 600 whp at around 26 psi on e80 (e85 pump).
20190717_182251 by Seth Burggraf, on Flickr
20190717_182325 by Seth Burggraf, on Flickr
20190717_182343 by Seth Burggraf, on Flickr
Old 07-20-2019, 10:09 PM   #9
TDagen
Member#: 163648
V9 6mt R180 Brembos
This is an awesome build! And it’s a wagon so even better
Have a graph of the break in tune?
Old 07-20-2019, 11:40 PM   #10
thesleekninja
Member#: 504463
2004 WRX Wagon
Love the wagon!
thesleekninja is offline   Reply With Quote
Old 07-21-2019, 09:55 AM   #11
subbi7
Member#: 241967
02 wrx
Which clutch do you use?
subbi7 is offline   Reply With Quote
Old 07-21-2019, 11:28 AM   #12
TDagen
Member#: 163648
V9 6mt R180 Brembos
Looks like a competition clutch triple disk?
Old 07-21-2019, 07:59 PM   #13
Twitch_PA
Member#: 286170
2006 WRX Wagon
Default Yep
It's a P&L Comp Triple. Rated for 1000 + whp/wtq. I had a exedy twin disk but had to get rid of it b4 install because it just wouldn't hold up to the power I'm looking for. The company actually sells this clutch kit with a new slave and bracket to make it push so theres less stress with engagement.
https://www.pandlmotorsports.com/shop/pandl-products/pandl-chassis-driveline/p-l-motorsports-triple-disk-clutch-and-flywheel-kit/
Alot of Real St guys use them. I love it. Obviously has the triple jingle while the pedal is pressed down and has the little screetch while engaging but it's quiet while engaged. All my iag mounts obviously make the car sound like it has straight cut gears now but it's fun.
No graphs of the break in. Nate made 700 while testing the triple 525 setup with the radium tank then turned it down to 26 psi to make it a tame 600 for break in. I have to go back tomorrow or the next day to replace the faulty flex fuel sensor. Keeps bugging out but I'll post up mustang graphs when it's done and once I get it out to keystone for the 1/4.
Old 07-21-2019, 08:39 PM   #14
TDagen
Member#: 163648
V9 6mt R180 Brembos
I imagine it might spool like the 6766 with the 2.7L. This things going to rip!
Right on, can’t wait to see more. Been interested to see what the 6870 can do.
Old 07-21-2019, 10:16 PM   #15
Twitch_PA
Member#: 286170
2006 WRX Wagon
Default Spool
With the cnc"d heads and bigger valves I kept the cams at the s2 grind to try and keep a little mid range but Nate at tpg said this setup spools very well for such a big turbo on a Subaru. Its night and day from a stock location to a rotated set up but now that the only things that are stock on the car are the body, rear seats and windows I think its gonna be a rowdy one.
Old 08-01-2019, 07:29 PM   #16
Twitch_PA
Member#: 286170
2006 WRX Wagon
844 whp 658 wtq
Will post graphs when I get them. The dyno went down for a bit will tuning. This is on a mustang dyno at TPG tuning.
Thanks to my friends and family for making this dream come true. I have no sponsors and this is all built by friends and family.
Old 08-02-2019, 04:08 PM   #17
TDagen
Member#: 163648
V9 6mt R180 Brembos
Congrats! Looks good!
What rpm is it being revved to/redline? Can’t wait to see more.
Old 08-05-2019, 10:18 AM   #18
CEEBEE
Member#: 420458
07 WRX STI
Urban Grey
This is an animal!
CEEBEE is offline   Reply With Quote
Old 08-23-2019, 06:19 PM   #19
Twitch_PA
Member#: 286170
2006 WRX Wagon
Default Info
I have it tuned conservatively right now at 45 psi timing wise. It revs to 8k.
First time to the track getting used to the triple disk is gonna take some time. My 60 ft is killing me and my all season tires start to lose traction around 800 feet.
11.055 at 135 mph. 1.8 60 ft. Tune #3 out of 4. 40 psi. This is a full weight wagon. No weight reduction whatsoever. Subwoofer in the back, my cmmg banshee sbr in its mount, tools ect.
Going to track tonight to try kill tune. Dont think its gonna run anything better than high 10s because I rally have to drive the car after 7 to 800 feet. Peak boost causes alot of tire spin in 3rd and 4th.
Old 08-23-2019, 11:39 PM   #20
TDagen
Member#: 163648
V9 6mt R180 Brembos
Awesome!!!! Look forward to hearing about tonight.
You need some stickier tires ASAP! That’s a lot of power on all seasons lol. Serious power with little traction can result in some gnarly torque steering around, which can really get pretty wild.
Old 08-24-2019, 12:12 AM   #21
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
Well now, that's a beast wagon! Sick man!
JDMJNKY is offline   Reply With Quote
Old 08-24-2019, 11:22 AM   #22
Twitch_PA
Member#: 286170
2006 WRX Wagon
Default Too sticky
Last nights track prep was for night of fire today. Both me and my buddy broke our front driver axles haha. And I'm on street tires. O well I'll upgrade the fronts now and maybe a set of stickies and see wat she can do.
Old 09-19-2019, 04:52 PM   #23
Twitch_PA
Member#: 286170
2006 WRX Wagon
Default Updayyyyyyyte
Got a new set of 500 hp fronts. Should handle the power split. Upon further investigation I literally sheared my front axle straight in half. Like someone used a water jet.
Car is running amazing. Hit boost cut at 49 pounds so I am on a lower tune. Will be hitting the track tomorrow!
Old 09-20-2019, 09:57 AM   #24
CEEBEE
Member#: 420458
07 WRX STI
Urban Grey
This is mental!
Old 09-20-2019, 11:24 AM   #25
Twitch_PA
Member#: 286170
2006 WRX Wagon
Default Thought
This was from the other week when we thought we broke the CV.
20190903_195114 by Seth Burggraf, on Flickr
20190903_195101 by Seth Burggraf, on Flickr
20190903_195109 by Seth Burggraf, on Flickr
