Welcome to the North American Subaru Impreza Owners Club Thursday January 23, 2020
Old 12-12-2019, 04:16 PM   #1
master c
Member#: 168226
2000 2.5RSti Coupe
02 Forester L
Default Master C's 2000 RSTi Coupe
Hello NASIOC!
I have been a long time member, lurked since 2004 when I bought my 2000 2.5RS coupe and signed up in 2008 when I finally moved over from rs25.com. Most of my build progress is on Instagram but since NASIOC now has image hosting I thought I'd start a thread.
Instagram: Chaecker5
I have owned this 2.5RS coupe since 2004 and it has gone through several evolutions:
2004-2006: N/A basic bolt ons, Apexi N1 exhaust, intake, HKS lowering springs
2006-2008: N/A-t build. Started with a small vf11 turbo and variable rate fuel pressure regulator and eventually got up to a TD04 and about 12psi of boost with emanage blue piggyback
2008-2012: built the original EJ251 with forged pistons, STi rods, and custom heads from delta cam. Ended up with a Greddy 18g and emanage ultimate piggyback and eventually had 800cc injectors and a Greddy 25g turbo running 21psi which maxed out my injectors and capabilities of the piggyback.
2012-present: decided to go full STi swap, shaved engine bay, chargespeed body kit, and go after my dream build. Life has got in the way along the journey but I have slowly been building.
Now that the thread is started, I will try and find pictures of the older build and share as it progresses.
Pictures as it sits today:
master c is online now   Reply With Quote
Old 12-12-2019, 04:40 PM   #2
lub
Member#: 343218
2004 WRX wagon
I need moar!
lub is offline   Reply With Quote
Old 12-12-2019, 07:13 PM   #3
pazzoduc
Member#: 493859
06 WRX TD Swapped
sorta black-ish
very cool stuff
Dah... no radiator build?
pazzoduc is offline   Reply With Quote
Old 12-12-2019, 07:20 PM   #4
master c
Member#: 168226
2000 2.5RSti Coupe
02 Forester L
Originally Posted by pazzoduc View Post
very cool stuff
Process West V-Mount setup
Old 12-19-2019, 01:55 PM   #5
master c
Member#: 168226
2000 2.5RSti Coupe
02 Forester L
Just scored a set of Defi Link gauges in white with green backlight to match the STi 10k rpm cluster I have. Won't be using the tach, but these should look good together.
Old 12-19-2019, 02:09 PM   #6
D-Rodman
Member#: 110078
05 Saabaru JDM STi
Black Ver 7 VF48 6sp RA
Iím really liking what I see here.
D-Rodman is offline   Reply With Quote
Old 12-19-2019, 02:48 PM   #7
JDMJNKY
Member#: 253498
02 RSTI
MURK'D
SUCH A TEASE!! Lessssss go Master C!!
just followed you I'm @elcucuy_sti
JDMJNKY is offline   Reply With Quote
Old 12-19-2019, 06:11 PM   #8
master c
Member#: 168226
2000 2.5RSti Coupe
02 Forester L
Originally Posted by D-Rodman View Post
I’m really liking what I see here.
Thank you!
Thank you - When I am off work I will follow back! I enjoy tracking your builds
Old 01-20-2020, 06:06 PM   #9
master c
Member#: 168226
2000 2.5RSti Coupe
02 Forester L
Quick update: built a custom bracket setup for the hella horns, designed a fuel filter mount for my AEM fuel filter, got the power steering system from Chase Bays routed, and am currently working on the fuel pump hanger/fuel tank and getting the engine oil cooler mounted/duct work completed.
Old 01-21-2020, 04:44 PM   #10
stu
Member#: 25768
2003 GEN2 GTX35 40++
2.3 slobaru
Love It!
stu is online now   Reply With Quote
Old Yesterday, 09:27 AM   #11
horsePOOGAS
Member#: 450712
04 STi
Followed you as well man. mine is @OG_Boo.Barusti
Love builds like these.
horsePOOGAS is offline   Reply With Quote
Old Yesterday, 12:29 PM   #12
master c
Member#: 168226
2000 2.5RSti Coupe
02 Forester L
Followed back - thanks for checking out the build
Old Yesterday, 02:40 PM   #13
XROLLER
Member#: 1273
98 Impreza
RBP
following
XROLLER is offline   Reply With Quote
Old Yesterday, 09:37 PM   #14
kaos200
Member#: 2692
Well whaddawehave here?... Sub'd
kaos200 is offline   Reply With Quote
