Welcome to the North American Subaru Impreza Owners Club Thursday January 23, 2020
Old 06-14-2005, 07:53 PM   #76
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
measure the diameter of the hole - there will only be a couple of potential thread pitches to choose from.
Old 06-15-2005, 09:38 AM   #77
aidrock
Member#: 21028
2002 WRX Sedan WRB
02 Triumph Sprint RS
Do you have any local stores that you could drive to (i am assuming the pipe is in the car and you dont wish to remove) and use their bolt display to check for fitment? I know the NAPA down the street from me has a display of bolts and nuts that you can use to test fit before purchasing something. I brought my uppipe in there and test fit bolts in the store, but they may be willing to let you bring it outside, who knows.
aidrock is offline   Reply With Quote
Old 06-17-2005, 11:15 AM   #78
2000bluegts
Member#: 66095
2016 Sti
Well its definately bigger than a M14 x 1.25 so I guess I will just keep getting bigger til I find the right one. I would rather not pull the uppipe if possible thats why I haven't taken it to an autoparts store. nobody seems to have the right bolt size thus far though which sucks.
2000bluegts is offline   Reply With Quote
Old 06-17-2005, 11:35 AM   #79
Peaty
Techno Sapien
Member#: 449
2019 Impreza Sport
Lithium Red
Can you take the probe to the store and find a nut that fits on the probe then a bolt that fits in the nut?
Peaty is offline   Reply With Quote
Old 06-17-2005, 12:53 PM   #80
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
Does it possible have an O2 bung in the uppipe? Seems strange but weirder stuff has happened.
I believe you can buy O2 plugs, I just don't really know where. You could try Godspeed.
mbiker97 is offline   Reply With Quote
Old 06-17-2005, 03:38 PM   #81
2000bluegts
Member#: 66095
2016 Sti
No I had a plug already in the up pipe not the sensor. I got a M16 bolt now hopefully that will be big enough. With as much trouble as this is causing I am debating just finding a new up pipe... mostly because I kinda need my car and for some reason no bolts want to fit the sensor hole.
Old 06-22-2005, 01:53 PM   #82
2000bluegts
Member#: 66095
2016 Sti
Finally got it I needed an M18 bolt to fill the stupid hole. Who could have guessed it would be that big. Everything works fine now.
Old 07-05-2005, 08:31 PM   #83
intence
Member#: 58477
. Member #1 of
the witty MS Crew
is the M12x1.25 bolt supposed to screw all the way and have the nut be flush against the uppipe? this is as far as it will screw in
intence is offline   Reply With Quote
Old 07-05-2005, 09:42 PM   #84
aidrock
Member#: 21028
2002 WRX Sedan WRB
how long is the bolt? that will tell you how far it will screw in. If you look into the end of the pipe is the bolt maxed out or is it hitting the end of the threads/weld where the bung is welded on?
Old 07-05-2005, 10:10 PM   #85
intence
Member#: 58477
. Member #1 of
the witty MS Crew
its hitting the end of the thread in the uppipe. below that is a smaller non threaded opening.
Old 07-05-2005, 10:23 PM   #86
aidrock
Member#: 21028
2002 WRX Sedan WRB
that is where it is bottoming out. the only way to make it thread any farther is to run a tap thru the hole, which i would not do. if you have the bolt threaded in that whole lenght (about 1" or so?) then it should be fine. If you are worried about it leaking you should use some loctite on it to insure the seal. I dont think mine is tightened all the way to the head and I have no leaks.
Old 07-05-2005, 10:35 PM   #87
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
you could always get a shorter bolt, or cut down the one you have... just be careful not to mess up the threads when you cut (if you can put a nut+however many washers it takes to protect the remaining thread on before you cut, then cut flush to the nut you should be fine - you might have to reshape the last thread, but that's it.)
Old 07-05-2005, 10:40 PM   #88
intence
Member#: 58477
. Member #1 of
the witty MS Crew
i think im just going to cut it since its not threaded the whole way down. probably 5/8th of it is actually threaded. the rest is just bare.
Old 07-06-2005, 12:21 AM   #89
aidrock
Member#: 21028
2002 WRX Sedan WRB
dremel tool cut-off wheel, or something a little more beefy.
Old 07-06-2005, 12:53 AM   #90
Peaty
Techno Sapien
Member#: 449
2019 Impreza Sport
Lithium Red
Here is a pic of the resistor to add to the info.
Old 07-06-2005, 01:16 AM   #91
GlobalWaste
Member#: 74792
too bad there's no more "radioshack" at least around here its called the "source" and they don't carry specific resistors- just random packs, I'll have to find some other place to get my resistor...
GlobalWaste is offline   Reply With Quote
Old 07-06-2005, 02:11 PM   #92
intence
Member#: 58477
. Member #1 of
the witty MS Crew
how many studs are needed for the uppipe install? i bought my new uppipe from someone who didnt use it and it came with 5 studs. is that enough?
Old 07-06-2005, 02:21 PM   #93
Peaty
Techno Sapien
Member#: 449
2019 Impreza Sport
Lithium Red
5 it is
Old 07-06-2005, 02:45 PM   #94
Samirr76
Member#: 4835
2003 Baja 5MT
Yellow w/ 220,000 miles
The part numbers for the WRX and STi OEM uppipes in the FAQ do not appear to be valid. I beleive the correct part numbers are:
WRX OEM UP: 44104FE010
STi OEM UP: 44104FE090
If I am not mistaken they are interchangeable and the STi UP is already catless. The WRX UP will have to be gutted.
Samirr76 is offline   Reply With Quote
Old 07-06-2005, 03:09 PM   #95
aidrock
Member#: 21028
2002 WRX Sedan WRB
yes, 5 studs is correct. be careful putting them in, make you use the double nut method.
Old 07-06-2005, 03:29 PM   #96
kcook
Member#: 78074
2005 STi
anyone : do i need EM to run a helix up pipe?
my car is stock and btw i ordered my up pipe a week ago.. its just backordered so i wont have it for another 2 weeks
kcook is offline   Reply With Quote
Old 07-06-2005, 03:32 PM   #97
Dooley
Member#: 61076
2005 WRX OBP
TurboXS Up/TB Cobb stg2
you will need a em like the accessport or a mechanical cel fix atleast to take out the cel.
Dooley is offline   Reply With Quote
Old 07-06-2005, 04:10 PM   #98
kcook
Member#: 78074
2005 STi
**** **** **** i dont feel like buying an EM right now
edit : what besides the cobb AP and utec is a good EM.. ive only read about those 2
Old 07-06-2005, 04:27 PM   #99
mbiker97
Member#: 7922
04 CTS-V b/b/b
99 GMC Highrider
Um no.
kcook: You don't need EM to run just an uppipe. The problem is when you are also running a downpipe too. Just do the resistor mod to eliminate the EGT sensor CEL.
Old 07-06-2005, 04:49 PM   #100
aidrock
Member#: 21028
2002 WRX Sedan WRB
You definitely do not need EM for an UP. I have an UP and headers and did the resistor mod = no CEL.
Does anyone know if the resistor is the same for the 05 as the 02?
kcook, if the mod is the same radioshack carries the resistor you need.
Downpipe FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 338 10-25-2019 01:04 AM
Exhaust FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 307 07-07-2019 04:40 PM
Turbo Timer FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 93 06-22-2017 09:29 AM
Pulley FAQ: Read if you are thinking of buying one! Unabomber Newbies & FAQs 118 12-08-2016 01:24 PM
