Welcome to the North American Subaru Impreza Owners Club Thursday January 23, 2020
Old 06-26-2016, 04:44 PM   #4626
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
to remind you, I can't manage to set the WL trimmer
as an idea I can reconnect the HFS IDC wire to a PWM output and using the ECU simulate injector duty to have one bar displayed constantly, and try to trim the WL from there - will this work?
Hyper is offline   Reply With Quote
Old 06-26-2016, 07:54 PM   #4627
Aquamist
NASIOC Manufacturer
Member#: 110029
2004 Citroen Picasso
Can you post a picture of your controller here. top side.
Aquamist is offline   Reply With Quote
Old 06-27-2016, 06:56 AM   #4628
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
Old 06-27-2016, 07:11 PM   #4629
Aquamist
NASIOC Manufacturer
Member#: 110029
We have been talking iDC but you have set the controller to trigger by MPS.
This confuses me.
Old 06-27-2016, 08:25 PM   #4630
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
appologies for the confusion, Richard, I should have commented...
disregard the MPS trigger, as I have moved it on IDC from our last talk, but I didn't modify the threshholds thus I used the same picture
Old 06-28-2016, 03:24 AM   #4631
Aquamist
NASIOC Manufacturer
Member#: 110029
OK, with the iDC trigger set, you are unable to set WL?
Old 06-28-2016, 04:40 AM   #4632
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
yes, I am doing part throttle trying to hold 1-2 bars on the gauge, but they quickly increase so it is hard to catch the moment
also even with 1-2 the WL is already @ 2 PM with no effect which seems odd
my WH trimmer is @ 11am, which also seems different than what I've seen on other installations
if I output a PWM signal from the ECU to the IDC wire, will this force the system to activate with no map signal? This way I can try to set WL trimmer stationary setting the duty to any %
Old 06-28-2016, 04:08 PM   #4633
Aquamist
NASIOC Manufacturer
Member#: 110029
Your WL and WH setting is not normal.
Try this:
WL at 10am
WH at 2pm
Old 06-28-2016, 06:16 PM   #4634
utc_pyro
Member#: 237189
2006 Legacy GT Wagon
Dark Blue
So the more I think about it the more the HFS-3 seems like it would suit my needs as is. MAP correlates roughly to G/Rev load, so it should be possible to predict when the WI system will fire on the fueling map. IDC based flow fixes the rest as the ECU will handle any compensations and the WI system will just follow along. Add a failsafe WBO2 gauge and you have a super safe setup.
Few more questions though.
Just to confirm, changing "TRIG" to "MPS" changes the "THRES" pot to a MAP sensor voltage trigger reference?
Does the controller add duty cycle based on the MAP sensor input to compensate for pressure across the injector like "BOOST COMP" did on the HSF-6? Does it do anything else with the MAP sensor input?
At what point does the system turn the pump on? Is there any protection for running the pump dry, or it does the pump even care?
Thanks!
utc_pyro is offline   Reply With Quote
Old 06-29-2016, 10:14 AM   #4635
point78
Member#: 344329
2008 Wrx, 6mt
Thanks!
I believe if you set the trigger to MAP, that's what it uses for the initial trigger point(yes voltage), then it follows the IDC to ramp in the water.
Although IDC is my preferred way to go for the trigger point, my last system only had map, and it drove me nuts with altitude changes...
I have the hsf4, which can alter duty cycle with another input, like IAT. It also has another failsafe input for something like a wideband.
I have mine wired in to the wideband, but I've never got around to dialing it in.
There is a float switch that will trigger a failsafe if the water level gets low. I have mind setup to map switch to non water maps if the unit is turned off, or the water level gets low, or there's a flow based failsafe trip.
You set the system trigger point with the THRES trimmer pot. Mine goes on at 30% idc.
point78 is offline   Reply With Quote
Old 06-29-2016, 02:20 PM   #4636
utc_pyro
Member#: 237189
Dark Blue
Thanks point78!
That's the system I was originally looking at just for that reason. It's just not as flexible as I'd like on the wideband trip point. That's why I'm now leaning toward the AEM gauge and "lower end" HFS-3. After selling my LC-1 the difference comes out as a wash.
So as soon as the sensor trips it puts the entire thing in failsafe? Hum... Is there some sort of delay between indicating the level is low and triggering failsafe? I'm planning on using the "green connector" method to drop to the "low IAM" tables, so that would get rather annoying. When your low gas light comes on your car doesn’t go into limp mode.
Originally Posted by HFS-3 Manual Page 2
The system retrieves the fuel flow (IDC) and manifold pressure signals (MPS) from the engine management system as the prime source to control the flow of water.
This statement from the first page of the manual is why I want to know if the HFS-3 is doing any other MAP based compensations. Maybe Aquimist could chime in on that.
Old 06-29-2016, 03:05 PM   #4637
point78
Member#: 344329
2008 Wrx, 6mt
Thanks point78
It's never been a issue for me. I don't even remember the last time I filled up? I have a 2 gallon tank. I do go full throttle most times when I drive though, just not for long periods, on ramps, etc.
I don't exactly remember, but I think I've seen my "low fluid" light flicker a bit before going steady. And I don't think it tripped the failsafe untl it was on steady. I believe there is some delay counter, but you can't adjust it.
You can adjust the delay on the flow meters failsafe activation though
Im sure he'll chime in. I think the 4 can blend both MAP & IDC- and a few other things, but the 3 can only use MAP for initial trigger...
Old 06-30-2016, 07:32 PM   #4638
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
Try this:
WL at 10am
WH at 2pm
I did some more tests today, I connected HFS green wire (IDC) to ECU controlled PWM output, this gives me an opportunity to play with the IDC signal and observe the system's work
I raised the duty from 0 to 100% watching the gauge - based on my observations it follows IDC nicely, and at about 75-80% starts spraying at full force
These are the settings I settled with for now
here is a video of how its working, the B LED is always on, both orange LEDs stay off during injection period - this is normal, right?
could you confirm it works as designed now? sorry for poor quality, blackberry aren't known for their cameras
https://www.youtube.com/watch?v=th9e...ature=youtu.be
Old 07-01-2016, 07:33 PM   #4639
point78
Member#: 344329
2008 Wrx, 6mt
You can look at your controller board too.
Green light blinking with the idc signal.
Amber will light up when system first activates. This is how you can see where you have the THRES set at.
Red starts to flash then steady as iDC approaches & hits 95%
Old 07-03-2016, 08:33 AM   #4640
Aquamist
NASIOC Manufacturer
Member#: 110029
If the both yellow leds stays off while you are on boost and spraying, the failsafe is now set correctly.
Old 07-05-2016, 08:04 AM   #4641
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
yep, finally got it working and loving it, thank you for your help and patience, Richard
no more knock, but slower spool and I did loose some power, but I hope I can get it back with leaner AFR and more timing to compensate for the later burn, wonder if it can be had without raising boost
Old 07-22-2016, 01:52 PM   #4642
JMlegacy
Member#: 341649
It's much, much safer to raise boost than timing or AFR. If you are at the limits of the turbo, seek to raise timing, then afr to squeeze the last bit of power out of the setup.
JMlegacy is offline   Reply With Quote
Old 07-27-2016, 02:47 PM   #4643
mtl_sti
Member#: 351705
2012 STI Sedan
Obsidian Black Pearl
My hfs3 system was professionally installed by Lachute performance, so I did not do the install myself.
They wired the necessary failsafe wires, from the hfs3 module to the ecu. They informed me, that if I turn off the hfs3 system at the gauge, that the failsafes from the hfs3 module might still be active and cut boost/go to safe mode while aquamist spray is turned off. They said in order to really turn off the hfs3 AND the system's failsafes, that I had to disconnect the hfs3 wires from the ecu and return it to the oem wiring setup.
This conflicts with info I have from another aquamist owner who says turning off the system at the gauge also turns off the hfs3 failsafes.
Please let me know which is correct. Does turning off the hfs3 at the gauge turn off the failsafes? Or must I also disconnect the hfs3 wires from the ecu?
mtl_sti is offline   Reply With Quote
Old 07-27-2016, 03:08 PM   #4644
Hyper
Member#: 15822
1999 WRB GM6
2.34 LR destroker
no
turning off the HFS3 at the gauge forces the system to go into failsafe mode, if installed and setup correctly
Old 07-27-2016, 08:59 PM   #4645
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4+ hybrid STi
What do you mean turn off the fail-safe? Also what ECU are you wired into?
I have an HFS-3 kit wired into a Link G4 ECU. The fail-safe wire is just a 5 volt output from the HFS controller that can be set to be either 5 volts or 0 volts when the fail safe is active.
In my setup the fail-safe from the HFS-3 controller goes to zero for any fail-safe and when I turn the system off on the gauge front. My ECU interprets that as "I need to switch to my low boost/timing map".
I'm not sure how your system is wired up but another method is to use the contact output on the HFS-3 controller to interrupt the signal to the BCS to limit boot pressure to wastegate spring pressure. Without really knowing how yours is wired up or what it trying to accomplish, I cant help you with troubleshooting.
Let us know what fail-safe you used and how you implemented it.
Old 08-02-2016, 07:08 PM   #4646
Aquamist
NASIOC Manufacturer
Member#: 110029
Here is a complete truth table shows how the HFS3/4 aquamist failsafe works under different jumper links and gauge switch.
It should clarify all uncertainties.
Old 08-09-2016, 02:19 PM   #4647
tank the ek
Member#: 295911
2015 WRX
LR
tank the ek is offline   Reply With Quote
Old 08-09-2016, 02:23 PM   #4648
shaman
Member#: 164259
Richard, can the flow failsafe be setup to ignore a low flow for part throttle spray?
shaman is offline   Reply With Quote
Old 08-09-2016, 04:26 PM   #4649
kellygnsd
Member#: 32669
LINK G4+ hybrid STi
If you set up the failsafe following the instructions the failsafe should not activate under part throttle conditions. Remember this is idc based injection. If you have injections set to start at say 29% IDC and that corresponds to 3 bars on the flow gauge, you set the low flow fail safe below 3 bars. Throttle position should not have any effect on this. For erroneous failsafe activations you may have to tweak the failsafe time delay.
Edit: You can always turn the low flow failsafe trimmer fully CCW to disable the low flow failsafe but then you lose blocked nozzle detection.
Old 08-09-2016, 04:35 PM   #4650
kellygnsd
Member#: 32669
LINK G4+ hybrid STi
Delete
Passing the NEW required OBDII Emissions test in PA Questions and Answers!! mrtrex Mid Atlantic Impreza Club -- MAIC 29 03-10-2013 08:23 PM
Snow Performance questions and answers... Ultimate Collision Center Water/Methanol Injection, Nitrous & Intercooler Cooling 374 09-23-2008 05:36 PM
Motörhead Guidlines, questions and answers here: GO LEMMY!! El Camino Off-Topic 9 01-20-2006 03:39 PM
Roll Center, questions and answers Arnie Brakes, Steering & Suspension 5 12-21-2004 04:26 PM
