Welcome to the North American Subaru Impreza Owners Club Friday January 24, 2020
Old 04-20-2009, 09:14 PM   #2226
flycaster
Member#: 60142
2011 WRX
Grey
1. Is the system primed up to pressure?
If by this you mean is the pump primed, then yes. Prior to hooking the pump flow outlet -> WPS #162/201, I fired the aux. trunk pump and pushed fluid all the way to the WPS #162/201. The pump itself then fired and stopped - I assumed it built pressure.
2. Have to disconnected one of the wire of the manifold pressure switch before grounding the green wire?
No, this was not mentioned before, or if so, I missed it. The only wire I ground was the green injector wire. I assume you'd like me to also pull off either the blue wire or ground wire from the PS #157?
flycaster is offline   Reply With Quote
Old 04-21-2009, 05:06 AM   #2227
Aquamist
NASIOC Manufacturer
Member#: 110029
2004 Citroen Picasso
With the blue wire off, the system should trigger. Please let me know.
Aquamist is offline   Reply With Quote
Old 04-21-2009, 01:23 PM   #2228
STIlin'
Member#: 103395
2006 STI
WR Pearl Blue
Default Pump 1.5 feet above resevoir
Originally Posted by Aquamist View Post
This is further proof of a dry intake line. Before long, you need to wettiong the pump manually before priming. The system is in danger of aging fast if that condition persists - dry pistion seal will not last very long.
It seems to spray instantly when turned on now so the intake line is no longer dry. The issue of getting it to shutoff is still a problem though. Why is the clogged jet warning light coming on if it is spraying? I have disconnected the jet to make sure it is actually spraying.
To prime the pump with a syringe do I need to remove the intake line and squirt water into the pump? I'm sure I'll need to do this in the future as I don't have a low windshield wiper fluid sensor.
STIlin' is offline   Reply With Quote
Old 04-21-2009, 07:26 PM   #2229
vulpina
Member#: 131903
GC8 PPG EJ25 GT3082
dark blue 95H
Hi richard ,
I feel dumb but after 6 month i bought my kit , i cant still figure how the WL and WH work and what is is used for and how to set it ,
Do you have a how to for that or something that could help me understand those , i think i got the SC thing sorted , its only for bargraph adjusting right ?
vulpina is offline   Reply With Quote
Old 04-22-2009, 01:14 AM   #2230
flycaster
Member#: 60142
2011 WRX
Grey
Bingo. That did it, and the rebuilt pump works great too. Terrific service, it is greatly appreciated.
Thanks, Richard.
Old 04-22-2009, 06:24 AM   #2231
jamal
Member#: 71875
Originally Posted by vulpina View Post
Hi richard ,
They set the low and high points of the flow window. Without them adjusted properly the system will not be able to detect a leak or clogged jet. I don't remember off the top of my head exactly where to put them, but basically the sc should be to 6 bars at full flow, wl should be to 4-5, and wh should be at 7-8.
Here's another pretty picture:
I think we've ordered 5 HFS-6 systems so far. So hurry it up with getting them to us please
jamal is offline   Reply With Quote
Old 04-22-2009, 12:11 PM   #2232
STIlin'
Member#: 103395
2006 STI
WR Pearl Blue
Default Question for Richard
Richard, what could cause the water injection light and clogged warning light to come on when the ignition key is turned to on? It sprays fine, albeit constantly. Breaking contact between the blue and black wires does not turn it off.
Old 04-22-2009, 04:16 PM   #2233
Aquamist
NASIOC Manufacturer
Member#: 110029
The clog led will stay on for about50-10second at start up. It is normal. If all is well, it will turn off.
Old 04-22-2009, 04:18 PM   #2234
STIlin'
Member#: 103395
2006 STI
WR Pearl Blue
It stays on and never turns off. It also sprays immediately when turned on and will not stop.
Old 04-23-2009, 12:09 AM   #2235
flycaster
Member#: 60142
2011 WRX
Grey
Richard,
Well, I thought I had it licked, but apparently not. I ran the car today and the system worked perfectly. I had to park the car for a couple of hours, and on re-start both pumps fired continuously and I got a LED warning light. I popped everything open, the lines were all good, no leaks, no visible shorts or wiring problems; then I re-ground both the injector wire and popped off the blue wire again on the 806-157, and the injector fired perfectly, but the pumps will not turn off no matter what I do. Could there be an issue with the pressure switch, or do you have some other ideas. I'm stumped.
Old 04-23-2009, 05:37 AM   #2236
Aquamist
NASIOC Manufacturer
Member#: 110029
The pressure switch (806-162) is responsible for shutting off the pump when the set pressure is reached. A mechanical switch is prone to wear and loose adjustment, this is caused by vubration and temperatre cycles inside the enigne bay.
I would concentrate the work on this switch, reset it to 7 bar and seal the adjust screw with some sealant. Fist of all, try a 1/$ turn counter-clockwise and see if it made any difference.
Aonther possible cause is the center pin of the pump is not making good contact with the 806-162. Unplug the 3-pin connector and check for any sign of corrosion.
Old 04-23-2009, 03:16 PM   #2237
crisdiarata
Member#: 208730
Hi my questions is what do I need to run to have the failsafe on? and if I have an AEM EMS and Electronic valve control (perrin) I don't need any other kind of controller to control my boost right? I can just controller with my laptop to the Aem ECU that is right?
crisdiarata is offline   Reply With Quote
Old 04-24-2009, 10:57 AM   #2238
flycaster
Member#: 60142
2011 WRX
Grey
Ricahrd:
I sent you an email rather than take up more space here; however, I'll post back here to let others know what we did and how to fix this pressure switch problem.
Old 04-27-2009, 12:42 AM   #2239
topfuelman
Member#: 140036
Default PWI-1 Flow volume issue
Hey Richard,
My tuner may have been in touch with you on this already, but I have done some more testing.
It was regarding a new Perrin PWI-1 system that I installed and have been trying to get 100 percent functional in my wrx prior to tuning.
Some details
• The flow sensor has a part# 806-428 and a serial# 3323
• Tank in hatch area,
• Primer pump after tank
• Filter between tank and primer pump has been cleaned/inspected.
On control unit: During 100% test cycle
• Pots adjusted to flickering orange (middle pot) and flickering blue (last pot)
• The third pot (Blue) needs to be turned nearly fully clockwise to maintain a blue flicker during test and to keep the low flow light out on the remote control/display.
On main pump assembly:
• The flow sensor has been taken apart and both screens cleaned (2x) to be sure.
• No kinks in the feed lines.
At nozzle outlet:
• Low flow volume measured at nozzle via multiple tests with different nozzles. Both pumps running (sound normal)
• Using a 1mm nozzle, I get an average of 240ml of spray volume/min.
• Using .8mm nozzle, I get an average of 210ml of spray volume/min
What else can I test? or What could the problem be??
Trev - Canada
topfuelman is offline   Reply With Quote
Old 04-28-2009, 07:59 PM   #2240
flycaster
Member#: 60142
2011 WRX
Grey
Richard, I sent you an email last week about the pressure switch (806-162) - did you get it?
Old 04-28-2009, 08:19 PM   #2241
Aquamist
NASIOC Manufacturer
Member#: 110029
Can you tell me which day. Do you go by another name?
Old 04-28-2009, 11:46 PM   #2242
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Where can I order the jet adapter? I looked on the Underdog Racing website and couldn't seem to find it.
Thanks.
alcoolaid is offline   Reply With Quote
Old 04-29-2009, 12:36 AM   #2243
flycaster
Member#: 60142
2011 WRX
Grey
I sent it on the 23rd to [email protected], and my name is Kirk Reynolds. Let me know if you need me to send it again. Thanks.
Old 04-29-2009, 04:39 AM   #2244
Aquamist
NASIOC Manufacturer
Member#: 110029
Please sent it again, I cannot find it.
Old 04-29-2009, 05:07 AM   #2245
alcoolaid
Member#: 134949
'07 SWP STi
Thanks.
Bump for more info.
Old 04-29-2009, 05:18 AM   #2246
Aquamist
NASIOC Manufacturer
Member#: 110029
Try our main US stockist listed on our website, they will get it for you.
Old 04-29-2009, 05:59 AM   #2247
jamal
Member#: 71875
I might have some laying around.
So.... weren't those HFS-6s supposed to be out by now?
Old 04-29-2009, 12:42 PM   #2248
flycaster
Member#: 60142
2011 WRX
Grey
Done.
Old 04-29-2009, 03:11 PM   #2249
Aquamist
NASIOC Manufacturer
Member#: 110029
I got the message, thank you.
I gather you have fixed it by giving the switch internal a good clean. Just require resetting the system pressure again. Requires an inline pressure switch:
http://www.mcmaster.com/#pressure-gauges/=1npgkb about $10.00
You may want to damp it with something on the inlet or it will shake the guage to bits.
Richard
Old 04-29-2009, 07:49 PM   #2250
flycaster
Member#: 60142
2011 WRX
Grey
Thanks, Richard. Buying the guage and resetting the pressure back to 7 bar will be easy enough, but the devil is always in the details: namely, how do I couple the Aquamist jet M8 male end to the 1/8" NPT male guage end (or snubber end to control the pulsation)? Or is there an easier way to do the same thing without trying to track down an exotic coupler that I'm only going to use one time?
Passing the NEW required OBDII Emissions test in PA Questions and Answers!! mrtrex Mid Atlantic Impreza Club -- MAIC 29 03-10-2013 08:23 PM
Snow Performance questions and answers... Ultimate Collision Center Water/Methanol Injection, Nitrous & Intercooler Cooling 374 09-23-2008 05:36 PM
Motφrhead Guidlines, questions and answers here: GO LEMMY!! El Camino Off-Topic 9 01-20-2006 03:39 PM
Roll Center, questions and answers Arnie Brakes, Steering & Suspension 5 12-21-2004 04:26 PM
