Welcome to the North American Subaru Impreza Owners Club Saturday February 29, 2020
Old 09-12-2019, 04:51 AM   #1
Sartaj96
Member#: 498710
Question Engine to Transmission Bolts Size and Part Number
Hello, I separated my engine and transmission to change the clutch. I forgot and lost the 6 bolts and 2 nuts that put them together. I am asking for the size/dimension/part number for the 6 bolts.
Out of the 6 bolts, two are longer (1 for each side)
What is the part number for these two?
the other 4 are the same size but smaller.
What are the sizes for these?
and finally, what is the size for the nuts.
Sartaj96 is offline   Reply With Quote
Old 09-12-2019, 01:14 PM   #2
scoobydooluth
Member#: 382724
09 WRX Sedan
Pretty sure it's all M10x1.25.
As for bolt length, they're all around 70-90ish mm probably but it varies. Here's a good start on the PN's but you'll need to nav to the same diagram for your own year:
https://parts.subaru.com/a/Subaru_20...12-005-01.html
scoobydooluth is offline   Reply With Quote
Old 09-12-2019, 08:21 PM   #3
Mauled
Member#: 500169
This is what I used:
https://www.fastwrx.com/products/subaru-bell-housing-bolt
Mauled is offline   Reply With Quote
