Welcome to the North American Subaru Impreza Owners Club Tuesday January 22, 2019
Go Back   NASIOC > NASIOC Technical > FA Series Factory 2.0L Turbo Powertrain
Old 05-24-2018, 08:58 PM   #1
evans312
Member#: 479935
2016 WRX Base
CWP
Default Crazy Knock Readings WOT
Since it started getting warmer, I have noticed some crazy numbers WOT, it does vary though. Some days it gets up to -8, some days only -3. I'd love to blame it on bad gas, but I don't even know at this point. The knocking normally is little at around 4-5k but when it gets to 5-6k is when I get the big numbers. I feel a slight shutter or lag when doing a pull. However, my dam only drops when cruising or at a really low load, which is understandable. Has anyone else experienced anything like this or might know whats up?
evans312 is offline   Reply With Quote
Old 05-24-2018, 10:12 PM   #2
undyjr
Member#: 459692
2015 WRX
pure red
Knock during WOT is REALLY bad. I would cease doing pulls immediately until someone more knowledgeable on this forum can advise you.
undyjr is offline   Reply With Quote
Old 05-24-2018, 10:18 PM   #3
simpleJ
Member#: 391748
2015 WRX CWP (sold)
2019 STi CWP
Log??
simpleJ is offline   Reply With Quote
Old 05-25-2018, 05:03 AM   #4
evans312
Member#: 479935
2016 WRX Base
CWP
Originally Posted by simpleJ View Post
Log??
Here is a 3rd gear pull log, I believe this should work.
https://docs.google.com/spreadsheets...it?usp=sharing
Old 05-25-2018, 05:50 AM   #5
Schoat333
Member#: 452248
2017 Base WRX
You need to log the command afr options including the one for cl.
From the looks of what you have logged you tune is very lean compared to most logs I have seen. You should contact your tuner asap.
Schoat333 is offline   Reply With Quote
Old 05-25-2018, 02:24 PM   #6
evans312
Member#: 479935
2016 WRX Base
CWP
Itís an ots map, do you think a cat less setup would cause these problems?
Old 05-25-2018, 02:40 PM   #7
simpleJ
Member#: 391748
2015 WRX CWP (sold)
2019 STi CWP
Lol yes.
Old 05-25-2018, 02:46 PM   #8
rtv900
Member#: 428511
2016 STI
why would a catless setup lean it out?
It's metering the intake air no different.
rtv900 is online now   Reply With Quote
Old 05-25-2018, 02:58 PM   #9
tegxsi
Member#: 446029
So you're running a Cobb Big SF intake?
tegxsi is offline   Reply With Quote
Old 05-25-2018, 04:06 PM   #10
evans312
Member#: 479935
2016 WRX Base
CWP
Yes I am
Old 05-25-2018, 04:07 PM   #11
evans312
Member#: 479935
2016 WRX Base
CWP
Lol yes.
I mean they say on their website that you can run a cat less setup, though it is reccomended to run catted. Iíve only been running catless temporarily
Old 05-25-2018, 04:08 PM   #12
sth36
Member#: 449914
2016 WRX, Stg 2, FF
Ice Silver
Is this a troll? Because you broke two cardinal rules.
1. Never use the Cobb Big SF intake as it's a b1tch to tune and will be messed up unless you position the filter perfectly each time.
2. Cobb OTS maps only work should be used with CATTED J pipes.
Edit: Cobb's site actually says it will run but not recommended due to boost creep and CELs.
sth36 is offline   Reply With Quote
Old 05-25-2018, 04:21 PM   #13
anjuna
Member#: 401977
IDFK Wat
bish whet
hi, welcome
you screwed up
step back
educate yourself
stop being a bro
pay off your car before you blow it up
anjuna is offline   Reply With Quote
Old 05-25-2018, 04:39 PM   #14
evans312
Member#: 479935
2016 WRX Base
CWP
sory i was looking for help, didnt mean to offend anyone, just wanted to know if anyone had similar problems/fixes. sorry
Old 05-25-2018, 04:59 PM   #15
sth36
Member#: 449914
2016 WRX, Stg 2, FF
Ice Silver
You didn't offend anyone, but no one here wants to see your car blow. Intakes of any make seem to be nothing but noisemakers and come with inherent problems (trust me, I had one and went back to stock). The Cobb unit has the most variability and is probably the last intake to be recommended by any tuner, at least that's the general consensus.
Secondly, back when I was running an OTS tune, I was under the impression they were created for catted j pipes. They may work with a catless set up, but that doesn't mean it's going to be good for your car. I'd expect CELs, overboosting, and the often mentioned boost creep.
Best advice you can take away from all of this is READ READ READ. Ron Watson (Phatron) has a website that tells you all his recommended parts. I don't know a single person who would suggest that everything on his site isn't really good and accurate info so take a look at recommended parts and his FAQs.
Old 05-25-2018, 05:07 PM   #16
evans312
Member#: 479935
2016 WRX Base
CWP
thank you for helping. god bless, ill be gooing back to catted and stock intake today, might be to late but worth a try
Old 05-25-2018, 05:56 PM   #17
vlad11591
Member#: 295970
2018 WRX
ISM
Why is it that people just add intakes and other mods without doing proper research? I researched for months before even doing any shifting mods. Do you guys use condoms? Or just wake up the next morning saying "**** it" Putting random parts on the car, without proper tune, is like getting a girl pregnant, off a one night stand. Now you have a headache/financial stress, for most of your adult life, that you didn't have before.
Aren't you scared that, adding random parts to the car, can indefinitely destroy the car?
Not pointed at OP, but I see this ALOT on the forums.
uhhh good luck.
vlad11591 is offline   Reply With Quote
Old 05-25-2018, 06:27 PM   #18
tegxsi
Member#: 446029
It's running very lean for some reason and not because you are catless...
All I can suggest is clamp the air filter closer to the edge of the intake pipe and make sure it is straight. Clean your MAF sensor and make sure that is seated correctly.
Are there any other mods you didn't mention?
Old 05-25-2018, 06:36 PM   #19
Straight6
Member#: 419593
Just take the intake off and sell it for few bucks. Keep the rest of the parts, stay out of boost and get an etune ASAP from a reputable tuner. If you haven't heard an audible knock, the engine still maybe OK.
Straight6 is online now   Reply With Quote
Old 05-25-2018, 06:48 PM   #20
evans312
Member#: 479935
2016 WRX Base
CWP
Just a full turbo back, intake and full recirc bpv.
Old 05-25-2018, 06:49 PM   #21
evans312
Member#: 479935
2016 WRX Base
CWP
Do you have any recommendations for tuners?
Old 05-25-2018, 06:59 PM   #22
Straight6
Member#: 419593
Ron Watson or Bren.
Also, read this when you have some free time:
https://phatbottituning.com/2014%2F15-wrx-instructions
These engines are very sensitive to modifications and really benefit from custom tuning.
Old 05-29-2018, 08:56 AM   #23
vtwinjunkie
Member#: 415503
2016 WRX limited
black silica
uhhh good luck.
Lol.
I bought my Cobb AP from a kid who had a cvt wrx with catless Jpipe, cobb intake and nameless axleback.
When I asked him what he was going to do with his car since he was selling the AP, and if he was going to go back to stock.
He said nope. he was just gonna run it like that cuz he needed moneys.
I diddnt argue because I got his AP for $320 and it was 2 months old lol.
He let out a sick cloud and rolled out full throttle.
vape life
vtwinjunkie is offline   Reply With Quote
Old 05-29-2018, 10:47 AM   #24
gn4rwhals
Member#: 453427
2017 WRX
Crystal White Pearl
Originally Posted by vtwinjunkie View Post
Lol.
vape life
Probably needed to pay his child support
gn4rwhals is offline   Reply With Quote
Old 05-31-2018, 01:23 AM   #25
zachreny
Member#: 475860
Mishimotot cold air intake with box also have protons done by bren
zachreny is offline   Reply With Quote
