Welcome to the North American Subaru Impreza Owners Club Monday January 21, 2019
Old 12-08-2006, 09:01 PM   #1
darkmist2k1
Member#: 31364
Ver6 Trek and couple
bottle of gatorade 4boost
Default need help diagnosis my brakes
i have a 93 turbo legacy sedan
my brake pedal is soft.. i tried bleeding them twice.. still soft.. i change the master cylinder and bled it twice again and its still soft...(while it was bleeding the pedal is really hard.. as soon as starts the car pedal become really soft)
the only way for me to get some brake pressure while driving is to pump it two time then i the brake actually bites( at 30 percent on the pedal) .. if not i have to press down like 80 percent before i get to slow down
my pads are good.. rotor are good.. inspected my hoses.. nothing is leaking..
any susgestion?
Sunny
darkmist2k1 is offline   Reply With Quote
Old 12-08-2006, 09:12 PM   #2
chrisarella
Member#: 35584
1965 FFR Roadster
Coyote + TR-6060
Sounds like your master cylider is on it's way out.
chrisarella is offline   Reply With Quote
Old 12-08-2006, 09:26 PM   #3
Major Johnson
Member#: 120705
2008 FXT Sports
World Rally Blue
If you already changed it, isn't there a slave for the brake system as well? Try that and check over all of the hoses and I mean all of them. Just today I found out one of my ABS steel lines was leaking brake fluid.
Major Johnson is offline   Reply With Quote
Old 12-08-2006, 10:50 PM   #4
darkmist2k1
Member#: 31364
no leak from the lines... i just change the brake master cylinder.. brand spanking new!!
never heard of brake slave cylinder.. if so.. tell me where it is!!!
Old 12-09-2006, 01:52 AM   #5
AKESREX
Member#: 110401
P silver -original owner
Ok, this will sound wacked out I'm sure. It IS possible to take a master
cylinder out of the box (new, not remanufactured) and have it be
defective. I've seen it in the domestic side of the business and on the
import side as well. (Wagner was the one and Autospecialty was the other)
I've seen it on at least 5 occasions, in about that many years.
If "pumping" up the pedal gives you brakes- you've got a bypassing
master cylinder. (internal fault in the master). In the case of a bypassing
master, this "solution" of pumping the brake pedal will work for several
days. If you have an external leak in the system, pumping up the pedal will
only work until the master cyl is dry.
AKESREX is offline   Reply With Quote
Old 12-09-2006, 01:44 PM   #6
darkmist2k1
Member#: 31364
hmmm... maybe defective.. but seems like more a brake booster or vacuum problem.. any other suggestions
Old 12-09-2006, 03:11 PM   #7
AKESREX
Member#: 110401
Default Possible vacuum booster issue.....
Ok, here's how to check that out.....
With the engine off, pump the brake pedal several times to bleed off
all the vacuum in the booster and all the power assist. Lightly press
on the brake pedal and start the engine. The brake pedal should
drop slightly under your foot if the booster is working properly. If
there is no pedal drop, the booster is not working.
Boosters are usually replaced and not repaired..... unless you
know someone and the unit can physically be repaired.
Need a bit of help on my brake set up MadmanGenius Mid West Subaru Owners Club Forum -- MWSOC 11 04-10-2010 07:30 PM
vibration when turning need help diagnosis s'ko 'Old School' Subaru Forum 5 10-09-2008 10:57 AM
Need some advice/help with my brake job.... onebaddx Brakes, Steering & Suspension 7 08-20-2008 02:18 PM
OK, I still need help with my brakes? Rock_Strongo New England Impreza Club Forum -- NESIC 22 05-20-2005 02:50 PM
need some help on my brakes...Will this work Scooby South Brakes, Steering & Suspension 3 07-28-2003 09:16 PM
