Welcome to the North American Subaru Impreza Owners Club Thursday December 14, 2017
Old 08-01-2017, 02:58 PM   #1
messinger
Member#: 331311
2008 wrx sedan
psm
Default 08 wrx random no start
I have a 2008 wrx manual and randomly it won't start. Sometimes it runs fine but randomly at any time of day and cold or warm engine it will crank but not start. No CEL
Things I've replaced
Starter
Battery
Imobilizer and reflash
Spark plugs
Diagnostic test ran and found no faults
messinger is offline   Reply With Quote
Old 08-01-2017, 04:12 PM   #2
Fearsnear
Member#: 435606
are you getting fuel?
Fearsnear is offline   Reply With Quote
Old 08-01-2017, 04:26 PM   #3
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper BK, 5MT
If it cranks normally, why replace the starter?
If it cranks normally, why replace the battery?
Stock or modded?
If modded, what?
How many miles on your 2008 WRX?
Stock ECU map or tuned?
Any recent work done?
Recent gas fill up or about 1/2 way through a tank?
Old 08-01-2017, 04:45 PM   #4
messinger
Member#: 331311
2008 wrx sedan
psm
Stock or modded?
If modded, what?
Changed starter because at first because it would only pop start and if I tapped in that starter start
Battery was tested so I replaced that because either way it needed to be done
Turbo back exhaust Cobb intake running Cobb ots map
No recent major work then what I've listed and done to try to solve this problem
This happens. I matter how much gas is in the tank
Old 08-01-2017, 04:48 PM   #5
messinger
Member#: 331311
2008 wrx sedan
psm
143000 miles and yes I'm getting fuel
Old 08-04-2017, 07:56 AM   #6
taxkourel
Member#: 333315
Did you find what was wrong?
taxkourel is offline   Reply With Quote
Old 08-04-2017, 09:20 PM   #7
messinger
Member#: 331311
2008 wrx sedan
psm
Still have no idea at all so it's sitting till I get days off from working in the oil field to attempt to take it to a garage. Side note it didn't start at all for two days straight. This morning it fired up like nothing was ever wrong at all
Old 08-05-2017, 05:17 PM   #8
taxkourel
Member#: 333315
I am having similar symptoms but much less frequently. Happen on rainy days with half tank gas or less (might be coincidence though)...keep us posted and so will I.
Old 08-06-2017, 10:03 PM   #9
messinger
Member#: 331311
2008 wrx sedan
psm
Bump ran fine this morning now it's back to nonstart
Old 08-10-2017, 10:12 PM   #10
messinger
Member#: 331311
2008 wrx sedan
psm
Still won't start
Old 08-11-2017, 08:24 AM   #11
jpg40
Member#: 390218
Check fuel pressure. My FPR failed to relief at correct pressure, causing 90+ psi during startup. If pressure is too high, injectors will draw too much current, which will cause ECM to disable them. Check by teeing in a pressure gauge into the fuel supply line before the rail.
Note that when I had this issue, it only happened during hot starts. If I waited 20 min (enough time for the 90 psi to bleed off) it would start.
jpg40 is offline   Reply With Quote
Old 08-12-2017, 11:41 AM   #12
kingsalami
Member#: 206257
2009 WRX 5-door
I'd check the clutch engagement switch. If the switch doesn't complete the circuit, the car won't start.
This would explain the intermittent nature of the problem.
kingsalami is offline   Reply With Quote
Old 08-12-2017, 07:23 PM   #13
messinger
Member#: 331311
2008 wrx sedan
psm
Car started today drive it 15 miles not one problem at all
Old 08-12-2017, 09:37 PM   #14
conseann3ry
Member#: 472772
Are you getting spark when it won't start?
conseann3ry is offline   Reply With Quote
Old 08-13-2017, 01:54 AM   #15
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
That switch prevents cranking.
Issue is crank but no start.
Old 09-10-2017, 03:12 PM   #16
messinger
Member#: 331311
2008 wrx sedan
psm
Alright I've change fuel pump, new battery (I got a bad battery that wouldn't hold a charge), and new Alternator. Drove the car multiple days, most was 150 yesterday, stopping and restarting the car multiple times. This morning I go out and same problem again will crank but no start.
Old 09-12-2017, 02:46 PM   #17
messinger
Member#: 331311
2008 wrx sedan
psm
Replaced crank sensor problem still occurs no start
Old 09-14-2017, 11:01 AM   #18
Scoobyfan09
Member#: 471513
2009 WRX
Cam sensor maybe?
Scoobyfan09 is offline   Reply With Quote
Old 09-14-2017, 01:45 PM   #19
winston856
Member#: 170133
2006 WRX Wagon
Gray
Yes, I agree.
What are the results of your fuel pressure test? I suspect the Fuel Pressure Regulator is faulty and not bleeding off enough fuel, as the poster above has suggested. Too much fuel is just as bad as not enough.
winston856 is offline   Reply With Quote
Old 09-14-2017, 02:17 PM   #20
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Originally Posted by winston856 View Post
Yes, I agree.
Interesting info from both of you, I will have to test this out. Thanks for the idea.
Old 09-18-2017, 12:06 PM   #21
klimt
Member#: 163162
2006 WRX wagon
WR Blue
Any update on your car, man? I'm having a similar no-start problem (cranks but won't catch). Took to a shop that tested my fuel line pressure, saw over 100 psi, so I replaced the Fuel Pressure Regulator with a new OEM part. Still won't start...
klimt is offline   Reply With Quote
Old 09-29-2017, 11:25 PM   #22
messinger
Member#: 331311
2008 wrx sedan
psm
Still no new info. Wonít start still so Iím waiting for my days off to take it to a shop
Old 09-30-2017, 02:28 AM   #23
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Klimt fixed his......https://forums.nasioc.com/forums/sho....php?t=2853031
Old 09-30-2017, 11:35 AM   #24
taxkourel
Member#: 333315
He said he changed the fuel pump.
