Welcome to the North American Subaru Impreza Owners Club Wednesday September 19, 2018
Old 07-03-2004, 01:05 PM   #1
Davenow
Member#: 23676
Default What does it take?? 200WHP from an RS
My buddy is looking at buying a GC8 RS. His goal is 200whp He would LIKE 210 or so, but will be happy with 200whp.
Can it be done without major $$$$$$$??
We figure the lighter GC8 will be VERY peppy with 200whp.
Davenow is offline   Reply With Quote
Old 07-03-2004, 01:15 PM   #2
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Default Re: What does it take?? 200WHP from an RS
Can it be done without major $$$$$$$??.
NO!
Kevin Thomas is offline   Reply With Quote
Old 07-03-2004, 01:51 PM   #3
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
yes with a turbo
Jay
munkis is offline   Reply With Quote
Old 07-03-2004, 02:07 PM   #4
nunyo
Member#: 35575
'07 Subaru OBS
Silver/Gray
BWAHAHAHHAHHAHHAA!
Sorry I had to laugh or cry. This thread has been posted so many times it's getting to be a joke.
nunyo is offline   Reply With Quote
Old 07-03-2004, 02:11 PM   #5
Crash477
Member#: 49881
2006 Subaru STi
1989 BMW 325is
I wanted that as well. However it is only possible if you do a EJ20 swap, and then start moding. Ive heard RS's with about 170 whp, and that was with cams, and heads, and tits, and everything. I'm going to do stage 2, plus cams, which should get me about 160+ whp. but thats about it with an RS. So if he wants that much power, tell him to do a swap.
Steven
Crash477 is offline   Reply With Quote
Old 07-03-2004, 02:57 PM   #6
Kevin Thomas
Member#: 110
1989 1989 XT6
Originally posted by Crash477
Ive heard RS's with about 170 whp, and that was with cams, and heads, and tits, Steven
Hey Steven,
If you can give me an RS with these, I'll take two of them. Woohoo!
Remember the key words he asks above, "Can it be done without major $$$$$$$??"
And yes, this has been asked soooo many times.
Old 07-03-2004, 02:59 PM   #7
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
1996 Impreza coupe
Dave, Dave, Dave... You've been around here long enough to know how to SEARCH, man!
This has been discussed a bazillions times, specifically just last week with a nearly identical subject line: http://forums.nasioc.com/forums/show...ghlight=200whp
Pat Olsen
'97 Legacy 2.5GT sedan
Patrick Olsen is online now   Reply With Quote
Old 07-03-2004, 04:43 PM   #8
Kevin Thomas
Member#: 110
1989 1989 XT6
Pat Olsen
Yeah Pat!
Here's a long one from back-n-da-day.
http://forums.nasioc.com/forums/show...&highlight=200
Although, I think this thread is at the crank rather than the wheels.
Old 07-03-2004, 08:37 PM   #9
Davenow
Member#: 23676
Yeah I know.. I suck
Old 07-03-2004, 10:22 PM   #10
Honkey3k
Member#: 53992
SOLD CGM 2005 2.5RS
35 PSI -- in my tires
Originally posted by Kevin Thomas
NO!
Honkey3k is offline   Reply With Quote
Old 07-04-2004, 06:45 AM   #11
Kevin Thomas
Member#: 110
1989 1989 XT6
Question
Old 07-04-2004, 09:02 AM   #12
nunyo
Member#: 35575
'07 Subaru OBS
Silver/Gray
...His goal is 200whp He would LIKE 210 or so, but will be happy with 200whp.
NO!
Dumb graphic illustrating that I am clueless
Old 07-04-2004, 12:07 PM   #13
JonofScio
Member#: 53595
1987 GL Hatch
EA81 1.6L + Weber
Default hm
Well, anything is possible. You can get 200 WHP from an EJ25, but to answer the question, no, it would take some money.
200 WHP is about ~ 268 flywheel hp. (if subaru trannies average 75% efficiency stock...)
You're looking at 100+ flywheel horsepower. It can be done...
Here's how you would do it...
lightened crank pulley (1.2lbs) , lightened flywheel (13lbs) would gain you _back_ about 17 whp. more can be realized with a lightened pulley SET. (17whp is about 22.7 flywheel hp)
port and polish, could possible gain 30 hp or more if done well...
excessive barely driveable cams with power to about 9,000 grand
you can grab for $400 off rallitek a valve train kit capable of letting your motor rev REALLY frickin high.... to be able to withstand that 9,000 RPM powerband...
exhaust (can get you as much as 37 flywheel hp) equal length headers, ect. ect.
So even without induction, I don't know why it's not possible. I hate the fact that everyone just assumes you should ALWAYS just go grab a EJ207 and drop it in for performance. Seriously, you'd spend as much buying all the **** to put that in off ebay as you would doing the stuff for the EJ25.
Cam: weld, regrind, and heat treat from delta cam in tacoma would run you $120 for all your cams
Flywheel: there's a place in albany/oregon that will shave and drill flywheels on a CNC to whatever weight you want for $50. or grab a 13 lbs one made of good alloy from rallitek for a couple hundred.
Pulley: the pulley I talked about 1.2lbs, is less than $150 off rallitek.
Shim and valtrain kit: $400 off rallitek
exhaust: you could grab a whole borla exhaust for less than $800
I could keep going. I think I might get flamed for this, but hey - N/A builds aren't hard.
JonofScio is offline   Reply With Quote
Old 07-04-2004, 12:57 PM   #14
rawrFERNY
Member#: 51517
2007 Outlander LS
avo kit from rallitek.com brings you to around 212whp IIRC
rawrFERNY is offline   Reply With Quote
Old 07-05-2004, 12:15 AM   #15
Hondaslayer
Member#: 4562
2014 Electric Datsun
2005 Chrysler Town & ****
Default Re: hm
You cannot add #'s together to make it accurate
All those listed parts will add power in different areas of the power band, what adds low end power may affect top end power, and vice-versa. 200 WHP is achievable with forced induction. My RS-t with a TD-04L from a WRX on a custom kit put down 201 WHP and 230lbft. That was pushing 10 psi on otherwise stock engine. With a VF-22 I finally saw 237/266
Old 07-05-2004, 09:03 AM   #16
Section 8
Member#: 821
Lightened drivetrain componets lose their ability to "gain" HP in higher gears. Their largest benifit is in first gear, when acceleration is the highest (people usually use the gear closest to 1:1 on the dyno). If the drive train is not accelerating, the less inertia does not make any difference, where as in first gear the acceleration is the greatest (well actually the greatest acceleratin is free reving the engine, but that is sort of pointless except for rev matching).
F = M A, blah blah blah
cheeRS,
Greg
Section 8 is offline   Reply With Quote
Old 07-05-2004, 09:31 AM   #17
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
What, no price listing on headwork?
NA builds have diminishing returns, plain and simple. Unless your religion doesn't permit it, forced induction is the way to go for at-or-over base WRX power levels.
Jon, if you can get my Legacy to 200 civilized NA whp for less than $3000, you're welcome to it.
LetItSnow is offline   Reply With Quote
Old 07-05-2004, 10:20 AM   #18
Kevin Thomas
Member#: 110
1989 1989 XT6
Question Re: hm
Hey Jon,
Are you sure that DeltaCams would give some gains on a 2.5RS in N/A form? I ask because I had some cams done for my XT6 and only gained a tiny bit of horsepower above 5500rpm. I had to advance my ignition considerably to get back some lost hp and torque. Even with my ignition advanced all the way with no knock, I still had a considerable loss of low end torque compared to my stock cams. I know the turbocharged 1.8ltr Scoobies supposedly had nice gains throughout their entire powerband.
Here's a dynograph plot with before DeltaCams, after Delta Cams installed and after fuel/ignition adjustment with Delta Cams on my XT6. I'd love to see a before and after Delta Cam install on a 2.5RS. Perhaps my car is just sick (in a bad way).
Old 07-05-2004, 10:50 AM   #19
JonofScio
Member#: 53595
1987 GL Hatch
EA81 1.6L + Weber
It's always easier to get a turbo engine with the same amount of money to a higher Hp than an N/A engine with the same amount of money.
But I still believe in N/A builds... just between intake, electrical, exhaust, head work, and cams, I don't know why 200whp isn't possible.
as for your XT6 man, that sucks about the cams... what grind did you get? Choosing duration, lift, and general cam specs is hard on an engine where there isn't alot of cam testing done. What's good on one engine won't show the same effects on another.
Old 07-05-2004, 11:49 AM   #20
Kevin Thomas
Member#: 110
1989 1989 XT6
Sorry! I don't mean to take this off-topic.
Old 07-05-2004, 01:08 PM   #21
darksurfer81
Member#: 57459
2001 2.5RSTi
Blue Ridge Pearl
Hey Hondaslayer, I might be doing the wrx turbo drop in on my car. The injectors, upipe, downpipe, intercooler bov and wastegate are with it. Right now on my 01 RS, I have injen cai, borlas, rt cat, and greddy cat back. Now when you did this what else did you need save exhaust manifold computer gagues etc?? Just curious, and I have been conducting searches too just nice to get someone who has done its opinion.
darksurfer81 is offline   Reply With Quote
Old 07-06-2004, 07:28 AM   #22
cew25
Member#: 50517
2003 2.5RS
"port and polish, could possible gain 30 hp or more if done well..."
is this true, seems like a pretty hight gain and people dont talk about doing it that much
cew25 is offline   Reply With Quote
Old 07-06-2004, 08:16 AM   #23
JonofScio
Member#: 53595
1987 GL Hatch
EA81 1.6L + Weber
my boss' dad owns a head shop (no, for cars! really! :P ) that is pretty much world renowned. If you get into the really expensive stuff (like a $1G job, a full on Stage 3 port) you could get about that much power out of the head. But that's like full on head work. Valve job and porting and polishing.
Old 07-06-2004, 03:27 PM   #24
Chi_San
Member#: 53558
2005 Baja Turbo
White/Silver/Black 3tone
I'd say, it would be easier to find a 12b. It would be a terrible swap, but it woudl be worth it.
Chi_San is offline   Reply With Quote
Old 07-06-2004, 03:37 PM   #25
jasona
Member#: 11786
2014 OB 2.5i 6MT
Custom Dirt/Snow twotone
nitrous oxide
jasona is offline   Reply With Quote
So what does it take to make an 02 WRX slip? Wakeforce General Community 34 12-14-2008 02:02 AM
So what does it take to from 51/49 to 50/50? Undepelo Brakes, Steering & Suspension 12 03-16-2007 03:43 PM
what does it take to be an IT recruiter besides a pulse? AC Lerok Off-Topic 33 03-31-2006 11:58 AM
What does it take to destroy an iPod nano, Pics.and what's inside this tiny package? Loscocco Off-Topic 10 09-16-2005 01:15 AM
