Welcome to the North American Subaru Impreza Owners Club Thursday January 17, 2019
Old 07-16-2008, 08:05 PM   #1
Just of Spades
Member#: 167994
2004 WRX Wagon
JBP CTSUBIE.com
Default 2.5 hybrid swap...smoke...turbo??? wtf!
ok, here's the quick end of it...
blew my 2.0, put new 2.5 in, smoke issue instantly thereafter.
what the deal? bad head job/valve seal(cut @255, new guides too), turbo seal(used 39), or neither?
smokes blueish at idle after warm-up. when the light turns green, i go, smoke goes too...not noticeable. if it smoked like at idle...i see it driving, trust. burning a little less then a quart per 1000miles.
I WAS leaning towards turbo seal, but i disconnected the DP and saw ZERO residue, that mean anything? turbo used to see synthetic, not now though. mean anything?
have noticed dampness at turbo's oil return line(crap gasket) also near the clamp....
compression test on new block(haha) is ok.
catch cans installed...no collection and yes they are done right.
car has been to the tuner who made a minor change before pulling me off the dyno(301whp, 363wtq w00t!).
block ran its first 1100 miles on 2.0 meth tune(didn't boost) with tuners OK
relevant mod list on 04 wrx wagon..invidia TBE, 565 inj, walbro, 39, big tmic, meth, cleared up, catch cans, EJ25
please, meaningful help only. i'm here if you need more info.
Just of Spades is offline   Reply With Quote
Old 07-16-2008, 08:25 PM   #2
pawlooo
Member#: 123959
08 LGT
I wish I could help
pawlooo is offline   Reply With Quote
Old 07-16-2008, 09:58 PM   #3
Just of Spades
Member#: 167994
2004 WRX Wagon
JBP CTSUBIE.com
bump for help
Old 07-17-2008, 01:32 AM   #4
dan13
Member#: 157726
hunk of metal
How long have you been driving around with the blue smoke coming out? It could just be residue in the heads if you drove for about 20mins but more than that and THEN I would worry. Maybe someone didnt install a valve stem seal correctly?
dan13 is offline   Reply With Quote
Old 07-17-2008, 09:33 PM   #5
Just of Spades
Member#: 167994
2004 WRX Wagon
JBP CTSUBIE.com
i'm currently at 1900 miles on the block. smoke started the morning of the install and continued since. it's not a "per drive" thing either, makes no difference after warm-up....1/4 mile to 300 miles.
Old 07-21-2008, 03:18 PM   #6
b4rstiwsnc
Member#: 154802
2004 STi
I had blue smoke come out of the exhaust today at idle, but when I started driving it went away (boosting) then when I came to a stop again blue smoke came out. Changed the oil started the car and no smoke came out. Drove home and let it idle after boosting a few times and no smoke came out, it only happened twice. Compression test was done 2 months ago everything was fine, spark plugs changed and protuned. I am the 2nd owner of the car and this happened to the previous owner for a few days and then it disappeared for thousands of miles, and now its back. help please! I have a feeling it is the turbo seal and not the rings since its holding oil and doesnt smoke while driving.
b4rstiwsnc is offline   Reply With Quote
Old 07-22-2008, 10:46 PM   #7
Just of Spades
Member#: 167994
2004 WRX Wagon
JBP CTSUBIE.com
very strange how you're that sporadic.
mine is every drive, every light. i'm starting to think the heads were done poorly.
Old 07-23-2008, 04:51 PM   #8
slowmike
Member#: 24890
2002 Jackwagon
WRB GG
Sounds like valve guide seals, who did your heads? I'd have them look at it.
slowmike is offline   Reply With Quote
Tony's 2.5 Hybrid Swap Thread mokujin22 Built Motor Discussion 169 05-01-2012 05:14 AM
about to finish 2.5 hybrid swap....... dc_adio28 Built Motor Discussion 21 11-16-2009 09:13 PM
No start on 2.5 hybrid swap pwr_wrx Built Motor Discussion 0 05-30-2009 03:02 PM
2.5 motor swap and turbos WjRgX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-02-2005 02:37 PM
2.5 hybrid swap, what parts ar needed? Confused. ebeck Subaru Conversions 5 04-12-2004 05:16 PM
