Welcome to the North American Subaru Impreza Owners Club Wednesday January 16, 2019
Old 05-30-2009, 03:02 PM   #1
pwr_wrx
Member#: 85050
2005 Sti
Silver Psm
Default No start on 2.5 hybrid swap
Need some help from the experts. I just did a hybrid swap in my 2004 wrx. Im using wrx heads, usdm sti bottom end. The motor was assembled and timed by a very good shop. I am getting spark and fuel but the car will not start. I am leaning toward ECU. Im using the stock WRX ecu. The check engine light will not blink when the key is moved to ign, however the ecu is showing codes. I have check all the sensor and they are connected. The car was running before and the reason I swapped out the 2.0 because the ring land cracked. I would appreciate if someone could point me in the direction I need to go to further to diagnose this problem.
pwr_wrx is offline   Reply With Quote
Tony's 2.5 Hybrid Swap Thread mokujin22 Built Motor Discussion 169 05-01-2012 05:14 AM
about to finish 2.5 hybrid swap....... dc_adio28 Built Motor Discussion 21 11-16-2009 09:13 PM
2.5 hybrid swap...smoke...turbo??? wtf! Just of Spades Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 07-23-2008 04:51 PM
Starting my 2.5 hybrid orion411 Built Motor Discussion 16 10-01-2007 12:14 AM
2.5 hybrid swap, what parts ar needed? Confused. ebeck Subaru Conversions 5 04-12-2004 05:16 PM
