Welcome to the North American Subaru Impreza Owners Club Monday August 20, 2018
Old 09-07-2002, 02:50 PM   #1
ANW
Member#: 4816
MY98 2.5 RS
RBP
Default Severe pulling with new suspension set up! Please help
I just installed a set of KYB AGX struts with Eibach springs on my 98RS. They feel nice in tight in turns and stuff but the problem I am having is that when I turn the wheel all the way in either direction (turning around, out of a driveway, parking lot etc) my car will pull hard in that direction untill you stop and turn the wheel about a full turn in the opposite direction. I Have just completed the install and havnt had the car realigned yet, but this problem seems to go deeper than an alignment 'cus it happens in either direction. It's not constant right or constant left. Anyone with the same or similar setup who had similar problems ??? Any input would be greatly appreciated!
adam
ANW is offline   Reply With Quote
Old 09-07-2002, 03:06 PM   #2
ElDuderino
Member#: 5980
Wingless Wonder
Well, you're turning the wheel, of course it's gonna pull in that direction.
/me thinking I'm missing something...
ElDuderino is offline   Reply With Quote
Old 09-07-2002, 04:54 PM   #3
HoRo1
Member#: 15618
Confused also. Do you mean that there is no self-centering action on the steering? An alignment will probably help solve the problem.
HoRo1 is offline   Reply With Quote
Old 09-07-2002, 05:11 PM   #4
CTKAG
Member#: 15001
STi V8 Spec C Power
NESIC TrackH0z # 10
Self centering is a castor issue I believe - not something that is adjustable usually. Not sure if it can be done, but are you sure you got the right struts on the right side? Are they assembled correctly? In any event, a trip to an alignment shop will tell you if something is way out of whack.
CTKAG is offline   Reply With Quote
Old 09-07-2002, 07:15 PM   #5
ANW
Member#: 4816
MY98 2.5 RS
RBP
Yes sorry for the confusion. It seemed to make sense to me but it always does to the writer. If you turn hard right/let pulling out of a driveway and then head straight down the street the car will pull in the respective direction. AS far as the correct struts on the correct side; I'm 99.5 percent sure; the brace clamp was on the same side, and the strut flares out over the tire on the same side still.
Do I need to have specific alignment specs done certain pos. or neg. % castor or camber ???
Old 09-07-2002, 10:24 PM   #6
ChrisW
Member#: 4181
2003 Lancer Evo 8
It's Blue, ok?
yes
ChrisW is offline   Reply With Quote
Old 09-07-2002, 10:36 PM   #7
Snowman
Member#: 3070
2009 Outback XT
Post
Make sure you go over every nut and bolt again.
The only thing my limited experience can offer is that you may have left something loose, maybe the strut top bolt? Dunno.
Good luck and get it fixed soon cause it's definitatly not right for it to be doing that.
Snowman
Bad spellers of the world, UNTIE!!!
Snowman is offline   Reply With Quote
Old 10-24-2002, 03:11 PM   #8
BIGSKYWRX
Member#: 7958
09 GH B+
This is happening to me, almost exactly. Have had it aligned, some improvement- not enough though.
Any help would be appreciated- also here at this thread
http://forums.nasioc.com/forums/show...hreadid=264455
adam- sent an email in the hopes you got this corrected
Thanks
Big Sky
Old 10-24-2002, 03:30 PM   #9
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
bigsky - the link you posted is THIS thread...
nhluhr is offline   Reply With Quote
Old 10-24-2002, 03:50 PM   #10
BIGSKYWRX
Member#: 7958
09 GH B+
Doh!- thanks, I think I got it now
Old 10-24-2002, 05:04 PM   #11
Austin
Member#: 7089
2016 STi
I replied in your other thread.
Austin is offline   Reply With Quote
Old 10-25-2002, 12:45 AM   #12
subaruracerx
Member#: 8380
I have the same problem in my WRX. If I make a hard right turn, the steering wheel will be slightly to the right when you drive straight and vise versa to the left. Happened before and after I lowered the car.
subaruracerx is offline   Reply With Quote
Old 10-31-2002, 08:16 PM   #13
DDMan
Member#: 11221
2002 2.5 RS
Black as Midnight!!!
Anyone find a solution for this...i just put on some STI-Ra springs and after the alignment my car is doing the same.
Lol, im reviving both the posts cuz im trying to see if anyone knows.
DDMan is offline   Reply With Quote
Old 10-31-2002, 08:55 PM   #14
BIGSKYWRX
Member#: 7958
09 GH B+
Posted in the other one.
Need help in what direction to go with a suspension set up. JarrodRex Brakes, Steering & Suspension 4 11-12-2009 04:46 PM
need help with my suspension set up Dhbamby Brakes, Steering & Suspension 1 11-24-2008 01:39 AM
New Suspension set up *Teaser Pictures* King Fish Member's Car Gallery 19 05-13-2006 03:00 AM
Suspension set up please chopaholix Texas Impreza Club Forum -- TXIC 94 07-09-2004 08:45 AM
