Welcome to the North American Subaru Impreza Owners Club Tuesday February 20, 2018
Old 04-02-2005, 10:26 AM   #1
skid_mark_steve
Member#: 69775
2004 WRX Stage 4+
Java Black
Default do I need new gear set?
I just purchased all my stage 4 stuff and exedy 3 puck clutch. Do I also need new gear set or will ste stock hold up? I was told that it won't but I need advice. I don't really drive hard ( high rev launches) but If I have to get a new gear set now would probably be the time. Anyother stage4's out there having problems with stock tranny? heres what I have so far. performance wise.
hyperflowtop mount
sti pinks fuel pump
vf22
utec.
exedy 3 puck
turboXS turboback (no cats)
XXtuning header/upipe
perrin short ram.
skid_mark_steve is offline   Reply With Quote
Old 04-02-2005, 10:58 AM   #2
pux888
Member#: 8356
02 STi swap
12 WRX limited
i ran my stg 4 for about 65k w/ no problems, but i didnt upgrade the clutch, that will be your problem if you have one. also thats w/ me cutting consistent 1.8 60s at the track. i didnt beat it but i did have fun.
pux888 is offline   Reply With Quote
Old 04-02-2005, 11:14 AM   #3
skid_mark_steve
Member#: 69775
2004 WRX Stage 4+
Java Black
the way I see it, the clutch would go before the gears. ( i might be wrong) That's why I did the clutch. From what I heard on the forums this clutch handled pretty close to stock. Nothing is installed yet. I just wanted adive before install since it would be easier with the tranny already out to put the clutch in.
Old 04-02-2005, 11:25 AM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Any puck type clutch is a bad idea with a stock drivetrain behind it. Puck clutches have more of an "on-off" characteristic vs. a stock disc which allows for slippage. The added shock will not be friendly to the trans, besides which the car will be unpleasant to drive on the street with that clutch even if you do upgrade the trans.
This has been discussed previously many times, if you search for threads with "puck clutch" I'm sure you'll find plenty of info.
Old 04-02-2005, 11:41 AM   #5
pux888
Member#: 8356
02 STi swap
12 WRX limited
yeah i didnt mean your gonna have clutch problems, id rather have my clutch slip than my tranny explode. sorry for not clarifying.
Old 04-02-2005, 11:55 AM   #6
skid_mark_steve
Member#: 69775
2004 WRX Stage 4+
Java Black
no ptop I'm kinda new to this whole thing any advice is greatly apreciated!
Andrewtechs new gear set Dirtyhobo010 Car Part Reviews 3 05-07-2008 03:23 PM
Do I need a gear pulley to take off the rotor? down_for_the_scooby Brakes, Steering & Suspension 3 12-30-2004 06:21 PM
Do I need a gear pulley to take off my rotors? down_for_the_scooby Brakes, Steering & Suspension 4 12-30-2004 12:27 AM
I need a new gear set WrXtremeEJ20 Transmission (AT/MT) & Driveline 6 05-17-2004 08:17 PM
Need a new gear set, need alittle help. steppin16 Transmission (AT/MT) & Driveline 1 02-28-2003 11:54 PM
