03-16-2012, 05:27 PM | #1 |
Member#: 120048
South East
Vehicle:2008 STI WRB |
Problem reading ECU of 08 USDM STI
Hello all,
I recently purchased my08 STI and i am trying to at least read the ecu from it. i plan on doing some light bolt-ons so i need the access.. I used to have a my02 bug which i was able to read and write to ecu with my old 1.3 cable.. now i have purchased the OP 2.0 from tac trix and i am having a hell of a time trying to connect. always get the same error. [13:10:46.296] EcuFlash Version 1.43.3150 [13:10:46.296] OS Version Windows XP [13:10:46.296] Qt Version 4.6.2 [13:10:46.312] 62 memory models read. [13:10:46.312] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata [13:10:46.656] 354 ROM metadata models scanned. [13:10:46.656] checksum module "subarudbw" loaded. [13:10:46.656] checksum module "mitsucan" loaded. [13:10:46.656] checksum module "mitsuh8" loaded. [13:10:46.656] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded. [13:10:46.656] patch module "Mitsu CAN RAM Parameter Logging" loaded. [13:10:46.656] flashing tool "wrx02" loaded. [13:10:46.656] flashing tool "wrx04" loaded. [13:10:46.656] flashing tool "sti04" loaded. [13:10:46.656] flashing tool "sti05" loaded. [13:10:46.656] flashing tool "mitsukernel" loaded. [13:10:46.656] flashing tool "mitsukernelocp" loaded. [13:10:46.671] flashing tool "mitsubootloader" loaded. [13:10:46.671] flashing tool "shbootmode" loaded. [13:10:46.671] flashing tool "shaudmode" loaded. [13:10:46.671] flashing tool "subarucan" loaded. [13:10:46.671] flashing tool "mitsucan" loaded. [13:10:53.500] J2534 API Version: 04.04 [13:10:53.500] J2534 DLL Version: 1.00.3147 Sep 3 2010 00:11:07 [13:10:53.500] Device Firmware Version: 1.11.3209 [13:10:53.500] Device Serial Number: TAzk6LOh [13:11:02.000] kernel get version [13:11:02.218] VIN : JF1GR89638L825492 [13:11:02.218] CVN : 369893B7 [13:11:02.218] SSM2 init [13:11:02.265] SSM2 ECU ID is 5A12784107 [13:11:02.265] Requesting Seed... [13:11:02.265] Sending Key... [13:11:02.265] interface close [13:11:02.281] interface close I have updated the drivers to the Tactrix open port.. i have uninstalled and reinstalled both ecuflash and the drivers to the tactrix 2.0 dongle.. with the older drivers i can reset the ecu with romraider but still cannot read ecu.. I have tried searching thru all the forums but to no avail was not able to help.. I hope someone can assist me .. thank you in advance and for your time Rolando |
03-16-2012, 09:21 PM | #2 |
Member#: 70395
MAIC
Make sure you have the latest Ecuflash and latest definitions. 99% of the time it's user error. Manually tell Windows where the driver is. If you are using Vista or 7 run as admin.
03-16-2012, 10:26 PM | #3 |
Member#: 108089
MWSOC
Vehicle:2003 WRX NF Performance |
if this keeps happening, you may have a locked ecu, most likely a cobb ap
03-17-2012, 08:37 AM | #4 | |
Member#: 120048
South East
This is what i hope is not the case... if I do have a locked ECU.. what would be my solutions.. purchase ECU ?? Is there a way to tell what locked the ecu either a Cobb which is most likely or a ECUtek ?? |
03-17-2012, 09:12 AM | #5 |
Member#: 274499
NESIC
Vehicle:1994 5.8T Cobra 755rwhp @ 16psi |
Does the car have any mods? (ones that were installed when you bought it)
03-17-2012, 10:29 AM | #6 | |
Member#: 120048
South East
its throwing me a P0420 cel due to the Catless downpipe... so my logic is if the ECu is locked with a Cobb or a ECUtek i wouldnt be getting the CEL right ?? |
03-17-2012, 10:48 AM | #7 |
Member#: 274499
NESIC
sounds like you have software and cable issues. I would suggest trying to downgrade your version of ECUflash to 1.42 and trying again.
03-17-2012, 10:55 AM | #8 |
Member#: 120048
South East
Thats what i am hoping it is... I dont know if its my timing but I have racked my brain and sweated my Arse off in the hot humid Miami weather.. LOL. but i will try again with a clean install
03-17-2012, 11:09 AM | #9 |
Member#: 274499
NESIC
I do strongly suggest you get off the beta software though. Ive used 1.42.2595 on both XP and windows 7.
03-17-2012, 11:48 AM | #10 | |
Member#: 108089
MWSOC
i'm using beta version and have no issues. if you have op2.0 and ecuflash, it should read. if it doesn't and locks you out, well, you're locked. |
03-17-2012, 11:55 AM | #11 |
Member#: 120048
South East
03-17-2012, 12:15 PM | #12 | |
Member#: 274499
NESIC
troubleshooting... have you ever done it? |
03-17-2012, 01:08 PM | #13 |
Member#: 120048
South East
thanks for your assistance gentlemen... i will continue to troubleshoot when i get home.... and post the update afterwards
03-17-2012, 06:35 PM | #14 |
Member#: 120048
South East
well and update..
i uninstalled and reinstalled 3 different versions of ecuexplorer and they all had the same results... I am believeing now that the ecu is locked... now the mystery is who is it locked by... Cobb ??? or ECUTek... If it is locked by ECUTek can a ECUTek tuner remove the lock with my request ?? I read there was a way with the Cobb AP .. But i dont know anyone localy here in Miami that would help.. I guess i will post in the South East region and ask arouund... thanks for all your help |
03-17-2012, 09:04 PM | #15 |
Member#: 108089
MWSOC
I've been using beta version for over a year without any issues. if it's not letting you in, it's not letting you in lol.
you can sell the op and get an accessport and tune with that. |
03-18-2012, 07:18 AM | #16 |
Member#: 120048
South East
Thats probably what i will do.. sucks cuz i already paid for a etune for the damm thing..
06-14-2012, 02:31 PM | #17 |
Member#: 315692
MWSOC
Vehicle:2005 WRX STi WRB |
What did you end up doing Qbanz? Mine is doing the same thing.
06-14-2012, 04:03 PM | #18 |
Member#: 294644
MAIC
Vehicle:2011 WRX Agile Auto DGM 440whp 420wtq |
i had this problem when i was using a laptop with vista, vista for some reason doesnt want to work with the newest update, once i switched to windows 7 it worked perfect
06-15-2012, 09:52 AM | #19 |
Member#: 315692
MWSOC
I'm using windows 7 I will try another computer just in case.
06-26-2012, 02:48 PM | #20 |
Member#: 232458
SWIC
Vehicle:2005 & 2008 STi Cobb 20g & EFR 7670 |
There's issues with Java too. Uninstall that and reinstall. Could be that
07-01-2012, 11:16 PM | #21 |
Member#: 227643
TXIC
Vehicle:2008 Stock as Hell :( STi |
my car wouldn't hook up with the tactrix either. i heard it's because 08+ are canbus??? i don't know what that means but i heard that's the issue
07-02-2012, 08:54 AM | #22 |
Member#: 70395
MAIC
The 2.0 Tactrix cable supports CAN-BUS cars. I highly suggest reading ALL OF THE FAQ'S on Romraider's site.
Similar Threads | ||||
Problem reading ECU with ECUFLASH | Subyroo2.5 | Open Source Reflashes | 3 | 02-10-2008 10:02 AM |
Photos of 2007 USDM STi Intake Ports compared to v7 JDM STi Intake Ports... wow | TROLL | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 29 | 09-11-2007 12:09 PM |
How would you describe the difference in handling of the USDM STi and the BMW 330i? | Zoso | General Community | 4 | 01-04-2004 07:01 PM |
In defense of the USDM STi. | Siper2 | New England Impreza Club Forum -- NESIC | 23 | 08-23-2003 08:49 PM |
Anyone know the price and p/n of the USDM STi seat | pittkid333 | Interior & Exterior Modification | 16 | 05-23-2003 10:22 AM |
