Welcome to the North American Subaru Impreza Owners Club Thursday February 25, 2021
Old 10-18-2020, 07:53 AM   #31651
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
Think itís brand specific.
Subaru has always been about safety, reliability etc.
Dodge has always been about the hp and cheap financing.
I think they are just catering to their specific market.
DieselDorf is offline   Reply With Quote
Old 10-18-2020, 10:55 AM   #31652
dcon9999
Member#: 326345
2012 5-Door Premium
Ice Metallic Silver
Anyone replaced shocks/struts? I have 165k across bumpy windy pennsylvania back roads and I don't feel like I have full steering control over uneven road surface it in the rain for the last 20k. Obviously going to look at tires for wear pattern, etc but didn't know if anyone else had replaced them and if so with what and roughly what that cost you?
dcon9999 is offline   Reply With Quote
Old 10-18-2020, 03:03 PM   #31653
IHaveAHorse
Member#: 507873
I see even like Toyota and VW doing it now on their cheap entry level sedans though. Then again I suppose the target market for cheap little sedans is young people who get their first decent paying job, probably the exact kind of people who want car go fast over anything else.
IHaveAHorse is offline   Reply With Quote
Old 10-21-2020, 11:09 PM   #31654
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Default 2012 Impreza thread
new OEM is about 1100.00 for the parts alone (every part, not reusing springs or anything). that is actually my plan, probably next summer.
I just replaced all my swaybar endlinks and bushings with new OEM and that made a huge difference. currently at 198k. thankfully most of my roads are quite nice and my shocks actually still do what they are supposed too..
Old 10-22-2020, 11:23 AM   #31655
bucky89
Member#: 459700
2015 Impreza
Crystal White Pearl
Originally Posted by flyboy1100 View Post
new OEM is about 1100.00 for the parts alone. that is actually my plan, probably next summer.
I wanted the extra ground clearance so I swapped my 2015 impreza struts with those from a 2009 forester. It was a straight swap. The older ďnewĒ setup has 120k miles on them versus the 80k on the originals. Iíll likely be upgrading to kybís down the road with king springs. Hereís the ride now: https://ibb.co/ZYbFPk4
Went from 5.7 inches to 12.4 inches.
bucky89 is offline   Reply With Quote
Old 10-22-2020, 06:29 PM   #31656
Ladeef
Member#: 318753
2012 Impreza
Dark Grey
Originally Posted by bucky89 View Post
I wanted the extra ground clearance so I swapped my 2015 impreza struts with those from a 2009 forester. It was a straight swap. The older "new" setup has 120k miles on them versus the 80k on the originals. I'll likely be upgrading to kyb's down the road with king springs. Here's the ride now: https://ibb.co/ZYbFPk4
um looks like the camber is way off, springs control the ride height.
Ladeef is offline   Reply With Quote
Old 10-22-2020, 06:42 PM   #31657
bucky89
Member#: 459700
2015 Impreza
Crystal White Pearl
Looks may be deceiving. Promptly brought to an alignment shop after install. Everything is dialed in.
May consider rear adjustable control arms, better end links, and beefier hardware when I upgrade to the kyb/spring setup.
Old 10-22-2020, 10:23 PM   #31658
IHaveAHorse
Member#: 507873
I went to spray this can of undercoating on my car that I thought was fluid-film like. It was something I grabbed from my late grandpa's stuff after he died a few years ago, he had all kinds of chemicals and stuff. The exposed metal (except the engine and exhaust of course) on the bottom of my car is all now rubberized. Oops.
I don't think it'll be too bad but I'll have to scrape it out of some bolt and screw holes and whatnot when I do service going forward. I could have stopped when I realized it was rubber-like of course but eh...
Unless someone thinks having a rubberized undercoating on most of the exposed metal, including most of the suspension parts, will damage anything?
Edit to add: I just noticed Valvoline CVTF is $42 for a 6 quart pack on amazon. I think that's a really good deal compared to what usually $9-10 a quart? I might pick up a pack or two.
Old 10-23-2020, 03:17 PM   #31659
Pelco
Member#: 435599
2016 Impreza Sport
Hi all, it's been a while since I posted on here.
Its good to see people are still talking about the good old Impreza
Pelco is offline   Reply With Quote
Old 10-23-2020, 04:27 PM   #31660
bucky89
Member#: 459700
2015 Impreza
Crystal White Pearl
If it wasnít for you, I donít think I wouldíve actually gotten this far with modding mine out. I remember specifically seeing your taillights and thought, ďI need those in my lifeĒ
You got rid of yours long ago, right?
Old 10-25-2020, 07:44 AM   #31661
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
That is unfortunate, I would try to get most of it off. Itís known to hold moisture on the metal and cause everything to rust faster.
Old 10-25-2020, 07:46 PM   #31662
IHaveAHorse
Member#: 507873
Well I suppose I have a new project then
Old 11-01-2020, 10:27 AM   #31663
IHaveAHorse
Member#: 507873
Castrol oils are on decent sale on Amazon, cheaper than I've seen them anywhere else. I'm set for oil for a couple years at least now.
Old 11-06-2020, 04:05 PM   #31664
dcon9999
Member#: 326345
2012 5-Door Premium
Ice Metallic Silver
Finally got around to modding the stupid cup holder:
https://forums.nasioc.com/forums/sho...3#post46454253
Old 11-13-2020, 02:22 PM   #31665
IHaveAHorse
Member#: 507873
I'm looking at getting a set of wheels and tires for spring/summer/fall and can't really bring myself to pay $650 for even the cheapest set of new wheels and tires, so I'm looking around craigslist and all that. Would a 205/65/16 tire fit on the 2.0i hatchback or will it rub?
Old 11-13-2020, 05:43 PM   #31666
dcon9999
Member#: 326345
2012 5-Door Premium
Ice Metallic Silver
Unsure. Local shop accidently put 205/60/17s on mine instead of 205/50/17 and I rubbed on bumps as I drove home before realizing they were the wrong size.
Old 11-13-2020, 08:41 PM   #31667
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
Thatís like 1.25Ē bigger, which is pretty significant.
You can also run smaller rims too if you donít have a second set already.
I need to get new tires soon too I have to go slow in the rain.
Old 11-14-2020, 08:07 PM   #31668
IHaveAHorse
Member#: 507873
I'm not sure, I might have a set of 15" rims around the property somewhere and I'm pretty sure it's the right bolt pattern but I'm not 100% sure.
It'd be annoying to have my winter tires be the wider, slightly narrower sidewall wheels though, and then use big, fat, narrow tires in the summer which I think is the opposite of what you want in both situations for optimal performance. I'll keep watching for deals on new wheels/tires though, of course there's plenty of time to wait for a good deal new or used before summer.
Edit to add: does anyone know if a 17x7 wheel with a +38 offset would fit? I know looking at wheels on tire rack and discount tire and all those places they're usually like 45-50 offset. But these wheels are super cheap, not super clean but cheap and functional is more than enough for me.
Old 11-15-2020, 03:28 PM   #31669
supertoast
Member#: 425248
2015 Impreza Prem 4d
Dark Grey Metallic
Changed the spark plugs a couple weeks ago. Was a lot easier now that I know a ratchet combo that worked well on our Forester when I did those. Just pull the battery and air intake, and they're right there.
Anyone know what this plug might be for? It's clearly taped off, but had me curious! It's on the passenger side, behind the air filter assembly.
supertoast is offline   Reply With Quote
Old 11-15-2020, 07:39 PM   #31670
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
I believe I have that on my car as well, not sure. Might be for aftermarket fog lamps?
Old 11-15-2020, 07:58 PM   #31671
supertoast
Member#: 425248
Dark Grey Metallic
Over on a Crosstrek forum someone had the same question. Sounds like it's for the remote start system. Well that explains things since I don't have that option
Old 11-29-2020, 04:30 PM   #31672
R0dzilla75
Member#: 459102
Just completed changing my spark plugs on a 2013 Impreza. Took two hours but it was my first time on a boxer engine. The correct tools will make all the difference. 3Ē wobbble socket extension with the correct spark plug socket. Iím only at 56k and the plugs on the passenger side looked worse. FYI, I havenít done the recall for the valve springs.
R0dzilla75 is offline   Reply With Quote
Old 11-29-2020, 08:34 PM   #31673
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
Mine were fine at 105k miles. Might want to get on that recall
Old 11-30-2020, 12:03 AM   #31674
IHaveAHorse
Member#: 507873
Are there any decently heavy duty steel replacement bumpers? Always been curious, and I'm pretty sure the front end parts that aren't suspension are very similar or identical to the crosstrek so that would mean better support I assume? Since there are probably a lot of people with crosstreks who want off road parts.
Old 11-30-2020, 03:02 PM   #31675
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
Iíve seen them but I think they are custom, yes the crosstrek is identical in that regard so might be easier to search crosstrek when looking.
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 2 03-08-2020 06:34 PM
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 03:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 08:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 05:09 PM
