#29151 | |
Member#: 301179
BAIC
Vehicle:2013 WRX Limited SWP |
![]() Quote:
The under the spare tire, that's a good spot to start. If you can do the whole floor, do it. If not, the doors are another good place.
#29152 |
Member#: 301179
BAIC
#29153 |
Member#: 466474
![]() Just did a motor swap in mine put the badge on today
#29154 |
Member#: 421858
Vehicle:2012 Impreza |
![]() uh... what?
#29155 |
Member#: 316869
Vehicle:2012 Impreza Sport Dark Gray |
![]() My impreza just threw the p0340 code. Anyone experienced it before and know of a fix?
Cruise control, hill assist and most things aren't working. Diagnostics say camshaft position sensor. Anyone know where it's located? |
#29156 |
Member#: 301179
BAIC
#29157 |
Member#: 466474
#29158 | |
Member#: 319157
Vehicle:2012 Impreza 4DR 5MT |
![]() Quote:
They are a wear item and bad shifting can burn them out well before 100K. You don't DC on every shift, but it's worthwhile in these scenarios: -Skipping gears up or down. -Upshifting into second near redline. -Downshifting from >1500 RPM. It seems like a hassle at first, but after a while the motions blend together and you do it without thinking. Basically, if you feel the stick fighting you on a shift, DC could have helped there. |
#29159 | |
Member#: 319157
![]() Quote:
#29160 | |
Member#: 319157
![]() Quote:
Ever stand next to a wall covered with pyramid foam? You'll think your ears are playing tricks on you. |
#29161 |
Member#: 421858
![]() If you really think it's a good use of money you go right ahead and do it. I can tell you it's not though.
#29162 |
Member#: 445904
#29163 | |||||
Member#: 445904
![]() Quote:
I just trained myself to do heel-toe to bring the revs up to match correctly on downshifts -- does double clutching add anything that rev matching via heel-toe doesn't? I've tried double clutching since reading about it in this thread over the past few days and either I'm not doing it right, or the way I was shifting before was pretty good already, because honestly it isn't making any of the shifts feel smoother nor is it reducing the force necessary to snick the shifter into the next gear. I do find it really, really hard to heel-toe in the Impreza. My ankles are not flexible enough to turn my foot anything close to 90 degrees to be able to reach both pedals. Instead I just keep my foot upright, half on the brake and half on the accelerator and kind of rock it left or right to distribute pressure between the two pedals simultaneously. It takes some concentration because my foot can easily slip off of one or the other pedal, and slipping off of the break pedal in the middle of braking is kinda dangerous. Honestly I learned to drive a stick from my dad in my first car and have kind of always driven the same fairly unsophisticated way. It's always worked pretty well except for this Impreza second gear difficulty. And even this is tolerable. I guess it's something like cheating but shifting on a motorcycle is so much nicer. The shifts are instant, the rev matching is easy due to the clutch and throttle being in different hands, and the wet clutch plates probably takes away alot of the chatter that would otherwise happen. Someday I'll get me another bike ... when the kids are grown ![]() Quote:
My problem isn't in getting the shifter into the second gear, it's when I let the clutch out, it's hard to make that shift without some grab and chatter. 3rd 4th and 5th are always so smooth that I'm pretty sure my passengers are not even aware that I've shifted. But 2nd, people feel. My wife complains that my car "isn't very smooth" because of it ... embarrassment ![]() |
#29164 | |
Member#: 319157
![]() Quote:
There are two major things your passengers will feel from the 1-2 shift: 1. Sudden loss of acceleration out of first. Your passengers jerk forward when you shift out of first, caused by not leveling off your acceleration before hitting the clutch. Roll off the throttle before you approach your shift point to minimize acceleration. It should almost feel like you're coasting before you shift out of gear. If you do this right, you can easily slide the stick out of first without any clutch (for practice only, don't make a habit of this). 2a. Sudden deceleration into second. If your passengers jerk forward and the tach jumps suddenly when you let out the clutch, this is your problem. Your revs from the 1-2 shift shouldn't dip below the 2nd gear RPM. The throttle by wire delay is partially to blame here, but you can work around it doing these two things: Apply more pressure to the stick to engage second sooner and apply throttle sooner (relative to the clutch). 2b. Sudden acceleration into second. If your passengers jerk back into their seats, you're shifting into second too quickly or applying throttle too soon. You'll never be able to shift quickly enough to avoid the jerkiness of bad timing/throttle. Slipping the clutch excessively just masks bad timing and isn't necessary for a smooth shift. At no time during the shift should the car experience deceleration. Pay attention to the force you apply on the stick going into second. It will set much of the timing for your shift. More force is required at higher revs. Shift out of first as early as possible. There's no reason to wind out first gear if you don't need the acceleration it can provide. Smooth 1->2 shifts are much easier at lower RPMs. A good 1->2 shift goes like this: 1. Smoothly roll off the throttle as RPM reaches your shift point in first. 2. When acceleration is near zero, stomp the clutch, let off the throttle and shift into second. Deceleration here means you've waited too long. 3. Begin applying throttle 4. Begin letting out the clutch Timed correctly, these events will happen at the same time: 5a. The engine begins to respond to your throttle input 5b. Clutch grabs 5c. The tach dips 0-200 rpm as the clutch fully engages 5d. The car smoothly accelerates If the tach jumps into second, you've waited too long to engage second gear. If revs dip excessively into second and it feels like you've been rear ended, you've engaged it too soon. If it dips, then your passengers jerk forward, you haven't applied enough throttle early enough. Done correctly, the tach should not hunt around and your throttle input shouldn't be visible. It should look very similar to that of an automatic car. Last edited by Commander Keen; 04-30-2017 at 04:24 AM. |
#29165 | |
Member#: 316869
![]() Quote:
It somehow randomly went away. I drove it around while being in ****ty mode, got home, restarted the engine and the lights were gone. I just finished cleaning around my engine bay so maybe I sprayed/moved something I wasn't supposed to. |
#29166 |
Member#: 316869
![]() My armrest currently looks like 2 dogs did a jig on top of it. Probably because my dogs do a jig on it while inside my car. Anyone know of how to remove just the arm rest cover. I'm trying to cover it in a leather or suede material to freshen it up.
When you lift it up there are 3 screws on the underside of it but it still doesn't come loose. Anyone done this before? |
#29167 | |
Member#: 417828
NESIC
Vehicle:2014 Sport Prem. M/T Satin White Pearl |
![]() Quote:
![]() ![]() ![]() Pull armrest straight up ![]() Now u can take out the screws and recover your armrest Last edited by Andrew7887; 04-30-2017 at 12:16 PM. |
#29168 |
Member#: 435599
Vehicle:2016 Impreza Sport White |
![]() Nice demo
#29169 |
Member#: 316869
![]() Awesome Thanks! I covered it with some random blue material but it kinda sticks out like a sore thumb. Will be ordering a matching armrest cover shifter and ebrake boot cover that matches. Where did you get yours?
#29170 | |
Member#: 417828
NESIC
![]() Quote:
No guarantee but the one from Subispeed MIGHT work http://www.subispeed.com/2015-subaru...ke-accessories Last edited by Andrew7887; 04-30-2017 at 02:44 PM. |
#29171 |
Member#: 421858
![]() Anyone know of a way to tell if the electronic center differential on the CVT disconnects when you pull the e-brake? It seems like it should... wouldn't be too hard to program whatever control unit is responsible. Maybe I should just pull up the ActiveOBD app and see what the lock up duty is on the center "differential" when I pull the e-brake quick.
#29172 | |
Member#: 340297
Vehicle:2013 Impreza 5sp Prm Ice Silver |
![]() Quote:
#29173 | ||||||
Member#: 301179
BAIC
![]() Quote:
When you rev match, you're only bringing the engine to match the speed of the gear you want to downshift into. When you double clutch, you will be rev matching + bringing the transmission to the same "speed" as the engine. Quote:
What's wrong with the shifter going into gear? Is it hard to get in gear... or? Quote:
The problem with 1st to 2nd is that 1st is a really high torque gear, where as 2nd isn't as much. Most other car's aren't really like this, so learning to get 1st to second takes some time to get used to. |
#29174 | |
Member#: 421858
![]() Quote:
#29175 |
Member#: 319157
![]() A quick summary of clutch braking vs rev matching vs double clutching:
Clutch braking: -Clutch in -Stick into desired (lower) gear, synchro accelerates clutch plate -Clutch slipped until flywheel speed approaches clutch plate speed -Engine continues to provide braking as RPM drops Wears: Synchros and clutch Rev matching: -Clutch in -Stick into desired (lower) gear, synchro accelerates clutch plate -Throttle blipped, brings flywheel roughly to clutch speed -Clutch is quickly engaged -Engine brakes as RPM drops Wears: Synchros Double clutching (fast version): -Clutch in, throttle floored -Stick to neutral -Clutch slightly engaged (very little torque is needed to spin the gearbox in neutral) -Release throttle when RPMs approach anticipated speed of the next gear (must be done quickly to avoid bouncing off redline). -Clutch in -Shift to desired gear -Clutch out and accelerate or engine brake as needed Wears: Nothing Double clutching (slow/textbook/practice version): -Clutch in -Stick to neutral -Clutch out -Rev engine to anticipated RPM of next gear -Clutch in -Shift to desired gear -Clutch out and accelerate or engine brake as needed Wears: Nothing Note: RPM = Flywheel speed Clutch plate speed = Gearbox input shaft speed Last edited by Commander Keen; 05-01-2017 at 05:37 PM. |
Possibly looking into a 2011 or 2012 Impreza? | xenonk | Mid Atlantic Impreza Club -- MAIC | 2 | 03-08-2020 06:34 PM |
2012 Impreza STI concept art | khaki_man | Member's Car Gallery | 37 | 03-15-2011 03:02 AM |
Newsflash: 2012 Impreza looks like BigElm's Butt | WagonMonster | Off-Topic | 4 | 02-28-2011 08:11 PM |
2012 Impreza Concept | Zakster87 | General Community | 14 | 11-17-2010 05:09 PM |
