#30401 | |
Member#: 411867
E. Canada
Vehicle:2011 Impreza 2.5i WRB |
![]() Quote:
Tuned intake and header back to 91oct. Can snap an old mans neck on demand.
#30402 | |
Member#: 454773
Vehicle:2012 Impreza Sport Pearl White |
![]() Quote:
#30403 |
Member#: 324361
Vehicle:2012 Impreza Sport ICM 5MT |
![]() Has anyone with heated seats replaced the seat heating element? My driver side heated seat no longer works and I suspect a broken wire inside somewhere.
#30404 |
Member#: 319157
Vehicle:2012 Impreza 4DR 5MT |
![]() Yes, twice.
The first time, the thermo switch wire broke off so I bypassed it and removed them both. The second time the actual wire on the seat bottom broke so I spun my own element using nichrome wire from Amazon, intended for vaping. Test the heater on both HI and LO. If one of the elements is still working on HI, it's a break in the dead element's wiring. If the seat works on LO but not HI, the elements are fine and the failure is likely in the wiring leading to the thermo switch. Do yourself a favor and pull the seat out of the car. Cut away hog rings and replace with zip ties. Last edited by Commander Keen; 03-16-2018 at 09:20 PM. |
#30405 |
Member#: 324361
![]() Thanks for the tips Commander Keen.
#30406 | |
Member#: 314216
Vehicle:2012 2.0i Sport 5MT DGM |
![]() Quote:
Struts too, ground clearance is like 0.25" different, those are the biggest differences |
#30407 |
Member#: 454773
![]() So I was looking into a loud noise from the rear, I was thinking it might be a wheel bearing or the diff or something.
When I had the wheels up one spun hard so I'm thinking the slide pins are sticking. Anyone have this happen and did manually moving them and wd40/grease fix them? I'm going to check them all when I switch to my summer tires. |
#30408 | |
Member#: 314216
![]() Quote:
in fact you even posted in that thread......anyway, here is my orginal post from this thread. https://forums.nasioc.com/forums/sho...ostcount=30276 |
#30409 |
Member#: 19843
Vehicle:2000 2.5 RS Sedan 2016 Base 5MT VRP |
#30410 | |
Member#: 89967
NESIC
Vehicle:2012 Impreza Sport DGM |
![]() Quote:
Hoping that once I get a chance to install my new front rotors and pads all will be fixed. I'm going to be installing new guide pins and boots in the fronts as well. |
#30411 | |
Member#: 314216
![]() Quote:
#30412 |
Member#: 314216
#30413 |
Member#: 89967
NESIC
![]() Makes sense, thanks. I'll check out the service manual. I just sprayed some brake cleaner around the area and cleaned with a rag. MY guess is the inside gets more corrosion since its harder to rinse off with water etc.
#30414 |
Member#: 314216
![]() which is why i think it suggests/says to lubricate both sides of the clips
#30415 | |
Member#: 314216
![]() Quote:
![]() and a quick look at a parts site rear: 3 different springs, Base/Premium/Sport trims are all different. 2 different struts, steel wheels or alloy wheels. front: 2 different struts, steel vs alloy again 2 different springs, manual vs cvt so yes, the sport should be taller than the rest Last edited by flyboy1100; 03-19-2018 at 09:04 PM. |
#30416 |
Member#: 314216
![]() So oil consumption now looks like 1qt/1600 miles even on 0w-40. Eff me, I thought i got a good one. I think once the snow is gone it is going bye bye. I'm not going to re-ring it. At 6yrs and 145k Subaru probably won't do crap for me
Pull oil cap while running and it is like a small blower just blowing air out, not sure how much is normal but it seems excessive |
#30417 |
Member#: 454773
![]() That sucks.
It's such a craps shoot for problems like these it seems. |
#30418 | |
Member#: 316869
Vehicle:2012 Impreza Sport Dark Gray |
![]() Quote:
#30419 |
Member#: 314216
![]() yes
![]() gonna go try this, the air from the filler cap is probably normal since i didn't see smoke. https://forums.nasioc.com/forums/sho....php?t=2476439 Last edited by flyboy1100; 03-21-2018 at 11:25 PM. |
#30420 | |
Member#: 19843
![]() Quote:
I was looking at the wrong model years. I was looking at 2015-2016, they went to all trims the same i guess. |
#30421 | |
Member#: 89967
NESIC
![]() Quote:
I have to say, if I develop oil consumption again as the miles increase, I will probably just sell my car as well (as long as I would get decent $$ for it). It's a shame that we have to deal with this on our cars. Wouldn't hurt to reach out to SOA - they may be able to help you out, especially since its such a widespread issue. |
#30422 | |
Member#: 314216
![]() Quote:
for kicks i ordered some Auto-RX today, will dump in 2 bottles as suggested to clean ring packs. worst case i just wasted 40 bucks i guess. I also ordered some Kreen, will probably try that first. kinda regretting ordering the Auto-RX now, but it shipped right away so i can't cancel it if it works i might try it on my other vehicles too, but so far just switching from 5w-20 to 5w-30 to 0w-40 on my excursion has changed oil consumption from 1qt/1000 to 1qt/1500 to 1qt/3000-4000 so i was really hoping for positive results on my Subaru ![]() Last edited by flyboy1100; 03-22-2018 at 03:24 PM. |
#30423 |
Member#: 314216
![]() I may be tempted to re-ring it depending on what happens this summer, i would need a solid few weeks to be able to do it though.
here is the complete parts lists minus a few extra things maybe like rod bearings???? grand total w/o some sort of parts special coupon from subaru parts warehouse is 453 shipped. ![]() |
#30424 | |
Member#: 89967
NESIC
![]() Quote:
#30425 |
Member#: 314216
![]() I might tomorrow if I have time, current fix is a new short block and that alone is 2k.
Then i also have to debate a clutch because im already in there..... |
Possibly looking into a 2011 or 2012 Impreza? | xenonk | Mid Atlantic Impreza Club -- MAIC | 2 | 03-08-2020 06:34 PM |
2012 Impreza STI concept art | khaki_man | Member's Car Gallery | 37 | 03-15-2011 03:02 AM |
Newsflash: 2012 Impreza looks like BigElm's Butt | WagonMonster | Off-Topic | 4 | 02-28-2011 08:11 PM |
2012 Impreza Concept | Zakster87 | General Community | 14 | 11-17-2010 05:09 PM |
