Welcome to the North American Subaru Impreza Owners Club Sunday February 28, 2021
Old 06-29-2020, 08:44 AM   #31601
rizaldiiii.13
Member#: 512180
hello, i just wanted to ask , is it normal for the 2012 impreza hatchback to have noise when going over uneven roads or small bumps??, coz i feel like theres a 'thumping' sound, i just recently replaced all the bushings and both of the rack end
and one more thing,my seat's springs ate broken so i hear like a squeak/creaking sound if the car shakes, and now whenever i went on an uneven road the car feels so bumpy, is it bcs of the seat's springs?
thankss
rizaldiiii.13 is offline   Reply With Quote
Old 06-29-2020, 09:07 AM   #31602
JustaImpreza
Member#: 357515
2018 WRX - Base
Crystal White Pearl
thankss
This happened to my 2013 twice while under warranty. Rear shock and front shock were leaking both times. Look for oil on the lower part of the strut assembly below the bottom of the spring seat down to where it meets the hub assembly. Compare all four corners. Should be easy to tell which one is leaking.
JustaImpreza is offline   Reply With Quote
Old 06-29-2020, 10:23 AM   #31603
rizaldiiii.13
Member#: 512180
So did u replace the strut?? im gonna check for the oil leak in the struts tomorrow
Old 06-29-2020, 03:19 PM   #31604
JustaImpreza
Member#: 357515
2018 WRX - Base
Crystal White Pearl
Absolutely! Covered by warranty both times. Had to argue to get an alignment check / adjustment, but that was covered too. The noise went away after replacement.
Old 06-30-2020, 09:26 AM   #31605
rizaldiiii.13
Member#: 512180
i just checked the struts and theres no sign of oil leak though
Old 07-04-2020, 05:46 PM   #31606
CalTech87
Member#: 348055
2013 Impreza 5MT
ISM
Changed my spark plugs this morning. Unless I missed something this was easier than doing the brakes. Cost was less than $100 and took a couple hours. Vice the quoted $650 from the dealership.
Probably old news or maybe a refresher:
HIGHLY recommend a "spark plug" socket (deep/magnetic), link to the one I used: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Also a 3" socket extension as mentioned on some forum or another. Was a tight fit but worked. Some were using a joint socket for a better angle but this shouldnt be necessary.
Saw a lot of caution about cross threading, some guy using a hose to align the spark plugs? The socket helped here, I could just hold the extension and start inserting by hand easily.
Was getting a smell through my vents about a month ago, dealer fixed a seal on the engine under warranty from the short block replacement. Paid for steam cleaning after.
Still getting that smell. Put the car on ramps this morning and it looks like some parts are caked with dirt = sticky oil layer. Noticed a spot of oil on my fumoto and under the transmission. Either the dealer didnt clean it or its still a problem. Will notify them and check again in a couple weeks for droplets.
Hoping the oil consumption issue is at least gone for good...
CalTech87 is offline   Reply With Quote
Old 07-04-2020, 08:00 PM   #31607
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
I’m surprised too, everyone always says how bad the plug job is.
The brakes were easy too. It’s actually a very simple car to work on which is nice for the diyer
DieselDorf is offline   Reply With Quote
Old 08-05-2020, 12:32 PM   #31608
Invisible3mpire
Member#: 373741
2013 Impreza Hatch
ISM
Did my plugs somewhat recently as well. Wasn't happy with the amount of gunk left on one. Ended up having a shop owner friend replace the valve cover gaskets and spark plugs tube seals @ ~163k miles.
Invisible3mpire is offline   Reply With Quote
Old 08-05-2020, 06:13 PM   #31609
CalTech87
Member#: 348055
2013 Impreza 5MT
ISM
Nice! Hoping I can make it to that many miles if my oil leak ever gets fixed.
Old 08-14-2020, 01:33 PM   #31610
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Time to fix drivers seat again. Fixed it 7 years ago, might actually be broke this time. At least a new frame is only about 180 shipped
Old 08-14-2020, 09:29 PM   #31611
IHaveAHorse
Member#: 507873
I know this isn't strictly related to the car but boy am I not looking forward to having to go to the DMV and register my car again and get a new license and everything. I have enough anxiety going out when I don't have to worry about overcrowding and a pandemic at the same time.
Thankfully it looks like we've been given a couple extra months to renew, even if your registration and license (mine isn't) are expired, all you have to do is say you couldn't make it to a DMV to renew. I should still get it done ASAP obviously but it takes a little stress off.
IHaveAHorse is offline   Reply With Quote
Old 08-15-2020, 01:46 AM   #31612
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
We just do ours online
Old 08-16-2020, 04:08 AM   #31613
IHaveAHorse
Member#: 507873
Wish ours worked like that
Old 08-20-2020, 01:04 AM   #31614
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
As suspected
I plan to use 1/8 or 3/16” rod to make my own to replace these since you can’t actually buy these thin POS clips. Factory clips are 1/16” and there is easily space for 3/16” in the holes
Old 08-21-2020, 11:32 PM   #31615
dcon9999
Member#: 326345
2012 5-Door Premium
Ice Metallic Silver
Hey all, So just checking in to see if anyone else is in the same boat. since my oil consumption test and subsequent failure, my engine has never been sealed back up correctly. Around 80,000 mi I had the short block done as part of the class action o-ring issue. Since then, I've been back to two different Subaru dealers I think 12 times at this point to have my engine completely taken out and resealed. Now at 161,000 mi, and just getting it back two weeks ago, I still think it's leaking oil. Anyone else have this issue or do the goons who took apart my engine the first time just **** it up?
dcon9999 is offline   Reply With Quote
Old 08-22-2020, 12:20 PM   #31616
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
I would cal Subaru of America. Get them all the info you have had about it. It shouldn’t be that complex of a job especially for a delear.
They are good at taking care of people.
Old 08-22-2020, 01:35 PM   #31617
CalTech87
Member#: 348055
2013 Impreza 5MT
ISM
Been back to the dealer a couple times for oil leaking after short block replacement. Actually have to take it back again but haven't gotten around to it.
First time they redid the main rear seal? Second time they suggested the Fumoto valve and the fix was to put an OEM drain plug in. There is clearly oil above the pan and **** caked on even though they steam cleaned it. Also getting burnt oil smell through the vent.
I looked at Subaru of America contact form but haven't filled it out yet. I will before taking it in next time just to get the ball rolling.
Old 08-23-2020, 12:59 AM   #31618
dcon9999
Member#: 326345
2012 5-Door Premium
Ice Metallic Silver
Yeah, SOA has been involved since the beginning. :/
Old 08-23-2020, 02:21 PM   #31619
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Seat is fixed, used 1/8” steel rod and was really easy to bend into something that would work. I’m surprised it took me so long to notice the lack of support!
Old 08-24-2020, 01:13 PM   #31620
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
Hmm never noticed mine. Before I bought it the seat had a squeak and the dealer fixed it, never had any issues since.
Old 08-25-2020, 12:55 AM   #31621
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Mine did take over 8yrs to break, but it has been apart 7+ years ago to fix the squeaks.
Old 08-30-2020, 06:18 PM   #31622
Dlu650
Member#: 451054
Default how do i post in here?
anyone know how to post or start a new thread in here?
Dlu650 is offline   Reply With Quote
Old 08-31-2020, 02:40 PM   #31623
Ladeef
Member#: 318753
2012 Impreza
Dark Grey
Timing cover is the usual culprit, leaks right onto the exhaust.
Ladeef is offline   Reply With Quote
Old 09-21-2020, 04:07 PM   #31624
IHaveAHorse
Member#: 507873
Are there any standard recommendations for a cheap replacement muffler for the wagon/hatch to increase the volume and rumble a little bit? Not civic fart cannon levels but something that makes it a little less prius-sounding?
And it doesn't have to be as cheap as possible or anything, just preferably not $500 for a replacement muffler or something. Most importantly probably, easy to swap out, not requiring drilling holes all over the place or welding or anything.
Old 09-22-2020, 08:37 AM   #31625
Cujo31
Member#: 19843
2000 2.5 RS Sedan
2016 Base 5MT VRP
namelessperformance.com their impreza muffler is usually around $200,
Cujo31 is offline   Reply With Quote
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 2 03-08-2020 06:34 PM
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 03:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 08:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 05:09 PM
