Welcome to the North American Subaru Impreza Owners Club Friday February 26, 2021
Old 09-23-2020, 04:06 AM   #31626
IHaveAHorse
Member#: 507873
Not liking that muffler delete based on the youtube clips of people who installed it, sounds like a violent fart. But the 5" muffler sounds pretty good.
IHaveAHorse is offline   Reply With Quote
Old 09-24-2020, 04:58 PM   #31627
lidirtrider
Member#: 334099
2012 Sport Premium
Dark Gray Metallic
Originally Posted by rizaldiiii.13 View Post
hello, i just wanted to ask , is it normal for the 2012 impreza hatchback to have noise when going over uneven roads or small bumps??, coz i feel like theres a 'thumping' sound, i just recently replaced all the bushings and both of the rack end
and one more thing,my seat's springs ate broken so i hear like a squeak/creaking sound if the car shakes, and now whenever i went on an uneven road the car feels so bumpy, is it bcs of the seat's springs?
thankss
I had a problem like that on my 2012 Sport Premium, turns out the steering rack itself was broken.
lidirtrider is offline   Reply With Quote
Old 09-29-2020, 01:08 AM   #31628
IHaveAHorse
Member#: 507873
So when car and oil manufacturers say like 5000 miles or 6 months, unless your car sits in a garage never used, isn't the age of any half decent synthetic oil not really relevant? I've been driving so little I've had the same oil for probably a year and a half but with less than 3000 miles on it. I can't possibly imagine what would break down in a decent modern oil that would warrant replacing it with very low mileage just because it's at 6 months or a year old. Am I wrong?
I could see something going wrong if you let a classic car sit in a garage without the engine running for 6 months maybe, or if you used an oil made 50 years ago when they probably had much lower quality and standards.
Old 09-29-2020, 11:57 AM   #31629
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
I always thought it was the mileage restriction or 1 year.
I think the thought is that especially when itís just sitting it can get a lot of moisture in it and that causes more engine wear.
I donít think itís so much the oil doesnít perform as well but that is has contamination in it.
I would change it if I were you. I went over by a few months as well but I wasnít driving at all.
DieselDorf is offline   Reply With Quote
Old 09-29-2020, 09:45 PM   #31630
Amejia
Member#: 518995
Default Will a 15 sti gurney flap fit on my 11-14 sti
Hey guys Iím just curious if the olm rs style gurney flap for the 15 sti fit my 11-14 sti wing cause it seems thereís not many options of gurney flaps for the 11-14 sti
Amejia is offline   Reply With Quote
Old 09-29-2020, 11:05 PM   #31631
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
This thread is for the base Impreza not the wrx.
Old 10-03-2020, 09:28 PM   #31632
IHaveAHorse
Member#: 507873
How long are PCV valves supposed to last on these cars? I've really lost track of most maintenance on my car but the PCV valve has to be at least 20k miles and 4 years old, possibly up to 40k or higher and 5 or 6 years old. Still works fine, air goes through one way and not the other way.
Maybe I should replace it if it's cheap just for the sake of not having to care about it for another few years..
Old 10-03-2020, 10:05 PM   #31633
nubsub
Member#: 313575
2012 Impreza 2.0i HB
Default hesitant starting: battery? starter? alternator?
hi all,
just the last week (last three times i've started the car), i have a hesitation to my car cranking over. it's not the same as the fuel pump issue, it's almost as if the battery is dead, but then it fires up.
while driving, i looked at the ODB2 port readings on the battery and it is all over the place...dropping as low as 11.7V and going as high as 14.0V with the low number being when i'm accelerating.
when i got home, i hooked up my NOCO5 charger/maintainer and it quickly went through the different charge cycles to a flashing green which means it wasn't all that low.
so the question is: what is the cause of my starting issues? i had suspected the battery (replaced Dec 2016), but now i'm not so sure.
any thoughts/experiences/insights?
thanks!
nubsub is offline   Reply With Quote
Old 10-03-2020, 10:19 PM   #31634
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
Mine was on for at least 50k/4 years. Thatís if the PO replaces it right before I got it. I think it was the original one at 107k and 8 years.
Mine wasnít clicking when I shook it but I didnít have any significant loss in mpg or increase in oil consumption (maybe a little of both)
It cost me $20 for the part and like 8 for a new hose and about 5 mins if you have the right tools. (Need about 18Ē of extensions)
Old 10-03-2020, 10:20 PM   #31635
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
Originally Posted by nubsub View Post
hi all,
thanks!
Could be the alternator not charging it very well I would get it tested at autozone or the like.
Itís super easy to access on the top of the engine.
Old 10-03-2020, 10:21 PM   #31636
IHaveAHorse
Member#: 507873
Couldn't tell you if the battery is bad, you have to use some kind of real battery tester not just a volt meter to check the condition of the battery. You can check the specific gravity of the battery acid or use one of those digital tester things that dealers and auto parts stores have. Batteries seem super hit or miss, I've heard of batteries lasting 6 months before dying and I've heard of people selling their 10 year old cars without ever replacing the battery.
I learned a while ago to turn the ignition to run/position 2 for a few seconds before starting and it's just become second nature to me after a couple years. I often had issues where the starter would have to crank for 10+ seconds until I started doing that, it seemed to often happen when the car was warm, especially partially warmed up like say after stopping for 30 minutes after a 5 minute drive, and a bit less often if the car was fully warmed up.
Could be battery, could just be whatever the starting issue seems to be with these cars.
Old 10-05-2020, 07:32 PM   #31637
nubsub
Member#: 313575
thanks everyone. turns out there was a bad battery cell. i hooked up the battery overnight on my NOCO charger and after 12 hours, it still didn't fully charge and the charger felt warm. i started the car and drove to Autozone to use their free diagnostics but their alternator test equipment was broken. their very limited battery test suggested my battery needed to be charged which hinted to me that something was amiss. i finally bit the bullet out of convenience since i didn't have any more time to devote to it, and called AAA. they came and ran a test showing that my alternator was fine but the battery had a bad cell. i replaced the battery and now things are back to normal.
Old 10-05-2020, 08:41 PM   #31638
dcon9999
Member#: 326345
2012 5-Door Premium
Ice Metallic Silver
Ugh. Pcv valve! Totally forgot about that on my regular maintenance spreadsheet. Lol. I'm at 165k on the orig...
dcon9999 is offline   Reply With Quote
Old 10-08-2020, 08:45 PM   #31639
CLL_OBP
Member#: 310435
'12 Sport Limited
VME 0W20 216,733 mi
Oh, you too? I'm almost at 215K on the original. No problems with the engine but the mpg has dropped off. From full, I used to go around 200 miles at a half tank. Now it's like 170. I'm going to change it out this weekend.
CLL_OBP is offline   Reply With Quote
Old 10-08-2020, 10:22 PM   #31640
dcon9999
Member#: 326345
2012 5-Door Premium
Ice Metallic Silver
Hahaha. I need an inspection this month and might actually take it to the dealer, so I'll grab part while I'm there. New tube for sure too. Hope its not baked in there too bad
Old 10-09-2020, 02:40 AM   #31641
IHaveAHorse
Member#: 507873
Where is a good place to get 0w-20 for fairly cheap? I don't have a stable income right now so I'm trying to save money wherever possible. Are there any places that have regular sales where I could stock up? Amazon doesn't seem to be particularly cheap for most 0w-20 they have on there unless you're comparing it to like royal purple at autozone or something.
edit - OK actually amazon looks like it's way cheaper than it used to be, I was wrong, I last looked maybe a year or two ago? And it was like $25-35 for those 5 quart bottles now they have a bunch under and around $20. Seems like a good deal unless someone knows somewhere to get decent oil even cheaper.
Old 10-09-2020, 07:32 AM   #31642
CLL_OBP
Member#: 310435
'12 Sport Limited
VME 0W20 216,733 mi
A good, cheap oil is the Walmart 5qt Super Tech High Mileage Synthetic 0w-20 for $14.xx. I've been using it in my daughter's car for the past 80k+ miles.
If you want to stock up, wait till the mid December when Autozone has 5qt jugs for $5 or $10.
Old 10-09-2020, 09:18 AM   #31643
dcon9999
Member#: 326345
2012 5-Door Premium
Ice Metallic Silver
As much as I hate the place, Walmart has amazing prices on 0W-20. What I usually do is check to see which brand is running a rebate and decide whether it's worth it to put that oil in my car. Lol. I find Pennzoil and mobile one usually run about 20 to $22 at Walmart minus a $10 mail and rebate makes it amazing. I then pick up the wix oil filter off Amazon or RockAuto
Old 10-09-2020, 12:22 PM   #31644
Angelus911
Member#: 89967
2012 Impreza Sport
Costco also has 0w-20 for about $15 per 5 quarts too, all though only makes sense if you have a membership
Angelus911 is offline   Reply With Quote
Old 10-09-2020, 12:49 PM   #31645
DieselDorf
Member#: 454773
2012 Impreza Sport
Pearl White
Sometimes manufacturers have rebates too, shop around cause the prices seem to fluctuate a lot.
Walmart is generally very cheap.
Avoid auto parts stores itís like twice as much,
Old 10-09-2020, 05:42 PM   #31646
dcon9999
Member#: 326345
2012 5-Door Premium
Ice Metallic Silver
Pennzoil rebate: https://www.pennzoil.com/en_us/promo...il-change.html
Walmart 5qt container...(takes 5.3 I think off hand so have an extra quart around. It'll get you through 3 changes)
https://www.walmart.com/ip/Pennzoil-...athlblid=L0100
Wix 57055 filter: about $8
New crush washer from dealer $.50
Synthetic oil change for under $20
Old 10-09-2020, 05:54 PM   #31647
dcon9999
Member#: 326345
2012 5-Door Premium
Ice Metallic Silver
Unrelated, could someone do me a favor? Can you post a picture of the wires and bulb holders for your front side market and headlight trim? Located at the very top inside edge of your stock headlight. Mine are reversed on both sides (don't remember messing that up, but in the change to all leds today -- because side marker blew and they are the worst most terrible bulbs to change in that car) I realized they were different on each side). Don't think it matters, but want to get back to correct...thanks in advance.
Old 10-10-2020, 02:30 AM   #31648
IHaveAHorse
Member#: 507873
I do actually, I rarely use it so that would be a good excuse.
And thanks for the suggestions from everyone else.
Old 10-10-2020, 03:11 AM   #31649
CLL_OBP
Member#: 310435
'12 Sport Limited
VME 0W20 216,733 mi
I've replaced the PCV hoses once as they do get hard being over the engine.
I ordered the PCV through the dealership online parts store and picked it up (25% off). You pay full price buying at the dealership $26.95 vs $20.21, go figure Part # 11810AA131
I saw a video where a guy used a 19mm socket. Thought I had one but I didn't. Trying other size sockets, a 3/4" spark plug socket fit perfectly and held it in place like a spark plug. The old PCV still rattled but the spring tension was weak.
Old 10-18-2020, 12:39 AM   #31650
IHaveAHorse
Member#: 507873
Has anyone else noticed car commercials have shifted from "Best in class safety/reliability/whatever" to "Lol horsepower and torque" the last few years or is it just me? I mean I guess the people buying new cars in the US more often than not now just want big engine make go fast and don't care about reliability or features as much, at least in my experience.
Possibly looking into a 2011 or 2012 Impreza? xenonk Mid Atlantic Impreza Club -- MAIC 2 03-08-2020 06:34 PM
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 03:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 08:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 05:09 PM
