Welcome to the North American Subaru Impreza Owners Club Tuesday February 20, 2018
Old 05-10-2012, 07:14 PM   #51
nubsub
Member#: 313575
2012 Impreza 2.0i HB
Originally Posted by esaino View Post
Here is the response from Subaru Canada.
"Thank you for contacting Subaru Canada, Inc.
The normal time is 60:40 and will alternate 50:50 during acceleration.
Richard Ouellette | Bilingual Consumer Support Representative, Customer Care/Service à la clientèle
1-800-894-4212 | Subaru Canada, Inc. | www.subaru.ca"
What? the Canadians get the fancy trip computer and now 60/40 while we only get 90/10? what's next?!
lol
nubsub is offline   Reply With Quote
Old 05-10-2012, 07:15 PM   #52
grubincan
Member#: 300961
Subaru.ca says it's 60/40 but can go to 50/50 on demand. It's possible U.S. models are different.
http://www.subaru.ca/WebPage.aspx?We...&WebSiteID=282
BTW, did anybody else notice the paddles work in 'D' mode? I guess if you're not happy with the CVTs ratio selection you can force it. It seems to switch back after a while.
grubincan is offline   Reply With Quote
Old 05-10-2012, 07:18 PM   #53
esaino
Member#: 196009
2014 Forester XT Ltd
Originally Posted by riccnick View Post
.................. no VSC, Traction Control, ABS, and no AWD.
No AWD?!?!?!?!?!?!
omg... this is it!.... Subaru leaves secret trail to boost MPG... just disable AWD... so you can enjoy much better MPG.... Subaru so cool....
esaino is offline   Reply With Quote
Old 05-10-2012, 09:14 PM   #54
Haunty
Member#: 319378
2012 2.0i Sport Ltd.
That's interesting. And if you convert the Imperial mpg listed there to US mpg, it's a little more. Doesn't make sense.
Yeah the paddles do work in D mode. It mentions that in the manual too. Nice for when you want to quickly go to manual to pass a car or something.
Also today I noticed, I had to pass a tractor and I hit 5000rpm, when I was finished and got back into the right lane I let off the gas completely and it just stayed at 5000rpm and was engine braking big time. I had to get on the gas again to get back up to speed, lol. The CVT behavior is weird.
Haunty is offline   Reply With Quote
Old 05-10-2012, 09:36 PM   #55
nubsub
Member#: 313575
Was this in D mode and did manually shift to accelerate? What's the build date of your car?
Old 05-10-2012, 09:37 PM   #56
nubsub
Member#: 313575
No AWD?!?!?!?!?!?!
Lol
U can also remove all if the seats and dash to save weight.
Old 05-10-2012, 09:57 PM   #57
subiTWO
Member#: 273054
2012 Impreza CVT HB
Regarding Subaru's AWD stratagies: http://www.subaruoutback.org/forums/...anation-2.html
I found another great thread, but didn't save the link, where the Imp's CVT AWD system was discussed. It's supposedly 90:10 in normal driving, but varies *continuously* depending on throttle position, 'gear', cornering forces, etc. It's controlled by a clutch pack.
subiTWO is offline   Reply With Quote
Old 05-10-2012, 10:01 PM   #58
subiTWO
Member#: 273054
2012 Impreza CVT HB
The paddles will hold a downshift for a considerable distance, but upshifts 'disappear' in just a few seconds, in D mode. They'd be alot more useful if they held the 'gear' for 15-25 seconds. I use the paddles so that I can use 1/2 throttle, or more, at low revs, to let the engine lug while getting good MPG and good accel. In D mode, the system will go back to D, and the engine will rev 4000+ before the car has accelerated enough to catch the next gear.
Old 05-10-2012, 10:13 PM   #59
subiTWO
Member#: 273054
2012 Impreza CVT HB
This guy is the one I was thinking of: http://www.subaruoutback.org/forums/...tml#post362954
Old 05-10-2012, 10:22 PM   #60
subiTWO
Member#: 273054
2012 Impreza CVT HB
And from here: http://www.subaru.ca/WebPage.aspx?We...ebSiteID=282#1
For instant, seamless response to changing conditions, Outback 2.5i models are available with the new LineartronicT CVT (Continuously Variable Transmission). This production-car first - a CVT longitudinally paired with AWD that uses a chain instead of a belt - allows for a near infinite selection of gear ratios, keeping the engine in the most favourable rpm range at all times. This advanced transmission is mated to a multi-plate transfer clutch AWD system that maintains a 60/40 torque split (front/rear) for more predictable handling and automatically adjusts up to 50/50 split under hard acceleration or when conditions warrant. The Lineartronic CVTT is also specifically tuned to provide a more natural feel than other designs for instant response on demand with minimal application of the accelerator pedal. Paddle shifters also provide a 6-step manual mode for quick response on demand.
Although it's on the OB page.
Old 05-10-2012, 11:41 PM   #61
Haunty
Member#: 319378
I'm guessing they can program whatever torque split they want since it's computer controlled.
Yeah D mode, no manual shifting at all. Build date is March 2012
Old 05-11-2012, 01:54 AM   #62
nubsub
Member#: 313575
interesting, tried to replicate this tonight, but only hit 4000rpm and it quickly went back down without any engine breaking...but i'll try to explore it in other situations.
Old 08-17-2012, 08:04 AM   #63
boudy
Member#: 174665
Any new findings on disabling VSC on the 5 speed? I'm glad I found out about this before buying one.
boudy is offline   Reply With Quote
Old 08-17-2012, 09:38 AM   #64
Yuck
Member#: 327734
2012 Impreza sdn MT
I really want to know too...I don't mind losing ABS if needed
Yuck is offline   Reply With Quote
Old 08-17-2012, 10:15 AM   #65
Zeeper
Member#: 299286
2017 Legacy Limited
They aren't really marketing the 2012 Impreza for its customizable sporty attributes.
Especially if you bought a CVT. Paddle shifters < manual transmission for driver input.
Wouldn't it be better to go buy an STI and stop complaining about the lack of ability to customize the driving experience in your impreza ?
Old 08-17-2012, 11:30 AM   #66
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Can someone please explain the difference in Subaru's AWD implementation in CVT-equipped cars vs. 5MT-equipped cars. I know there is a difference (I think my salesperson said that the CVT implementation is more sophisticated/smarter), but I don't recall the details.
Old 08-17-2012, 11:37 AM   #67
Zeeper
Member#: 299286
2017 Legacy Limited
Subaru Automatic and CVT use an electronically controlled AWD system that has clutches to engage and transfer power from front to rear. Depending upon who you ask and which car (outback, impreza, etc) the split is 90/10 - 60/40 FWD/RWD power in normal driving.
When the computer senses or predicts wheel slip it sends more power to the rear tires as needed, and this happens quickly.
The 5spd Impreza uses viscous coupling, a hydraulic transfer system. It is normally 50/50 split power distribution, but if the wheels start to slip the fluid in the viscous coupling case heats up, thickens, and transfers more power between the front and rear to be distributed as needed (wheels that are slipping are stopped by the ABS system so wheels with grip take on the extra power).
That's the essence. Some systems like that in the STI are even more advanced and add differentials between the two rear tires to adjust traction and are much more adjustable over all.
I like the simplicity of the viscous coupling system, the electronic clutch system can respond quicker to slippage because it can more efficiently transfer power.
But if you want to irritate CVT Impreza drivers, just remind them their car is mostly FWD most of the time...
Old 08-17-2012, 11:42 AM   #68
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
OK, thanks for the explanation.
Between the AWD systems used in our 2012+ Imprezas (electronically controlled with CVT vs. hydraulic with 5MT), is it possible to say that one is more effective than the other on a snowy/slippery day?
Old 08-17-2012, 11:51 AM   #69
Zeeper
Member#: 299286
2017 Legacy Limited
On an Outback forum owners who had owned both in very slippery conditions seemed to prefer the Automatic/Electronically controlled clutch version, but no one complained that the viscous coupling system sucked.
The electronically controlled system is faster to respond, gives you slightly better mileage (FWD most of the time) and hopefully never fails, because I bet it gets expensive to fix.
The "old-school" viscous coupling system has been in use by Subaru since the 1980's, and of course my car is AWD all the time...
http://www.awdwiki.com/en/subaru/
How is that for excitement, they added a Subaru XV video showing the AWD system at work...
Old 08-17-2012, 12:13 PM   #70
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Yeah, that's what my salesperson said--that the electronically-controlled system was better, but that the hydraulic system was so good that most people will never notice the difference.
I'll be putting snow tires on my car this winter (a lightly used set of Blizzaks I bought on old 16" WRX wheels for cheap). I'm expecting excellent results.
Old 08-17-2012, 03:57 PM   #71
Ladeef
Member#: 318753
2012 Impreza
Dark Grey
Sounds good to me, 90% of my driving doesn't require AWD anyway
Ladeef is offline   Reply With Quote
Old 08-17-2012, 04:37 PM   #72
WStrembitsky
Member#: 323877
2012 Impreza Limited
Hey! 60/40! Subaru Canada says 60/40, I'm in Canada, so it's a 60/40 split. Can it with the damn lies about my AWD system.
WStrembitsky is offline   Reply With Quote
Old 08-17-2012, 05:05 PM   #73
ocellaris
Member#: 302559
Heck yeah. If I had a switch to fully disengage the rear drivetrain and gain 1 MPG, I would drive around like that 9 months out of the year.
ocellaris is offline   Reply With Quote
Old 08-17-2012, 05:33 PM   #74
uspopo
Member#: 317014
2015 WRX Limited CVT
ISM
Same here, but I do look forward to the other 10% in the dirt/mud/rain and snow!
uspopo is offline   Reply With Quote
Old 09-01-2012, 01:17 AM   #75
Cogito8888
Member#: 328981
2012 Impreza 2.0i
Hatch 5MT Camellia Red
Soooo, this was bothering me too the other day, wanted to slide couldn't had to resort to the hand brake.
However I did some digging according to the Forester people the VDC can be killed by removing the abs fuse in the fuse box.
http://www.subaruforester.org/vbulle...-thread-82168/
I looked at our fuse box under the hood looks almost Identical to the forester fuse box. May try removing it over the weekend and see what happens, seems to be the same fuse and everything.
Also I have a 5spd so may be different for cvt
Cogito8888 is offline   Reply With Quote
Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? somebody else Southern California Impreza Club Forum -- SCIC 3 12-23-2015 05:34 AM
2012 Impreza 2.0i Gas Mileage Thread Benchmark General Community 934 10-08-2013 03:49 PM
[REQUEST TO MODS] 2012 Impreza 2.0i only forum please? tornado542 General Community 10 04-26-2012 06:07 PM
2012 Subaru Impreza 2.0i Break-In Period Arseezy Newbies & FAQs 7 02-14-2012 09:28 PM
Impreza 2.0i durid Newbies & FAQs 2 02-07-2012 04:54 PM
