Welcome to the North American Subaru Impreza Owners Club Sunday October 21, 2018
Old 09-12-2007, 02:04 PM   #1
IIdiceII
Member#: 90438
Default Brake light comes on and off but not low on brake fluid?
Ok I did some searching and now im just confused.
A couple weeks ago is when I first noticed that on hard acceleration, my brake light would come on and then go away. its the PARKING BRAKE light, not the abs light.
well since then its a lot worse. now it stays on basically the whole time and turns off for about a minute.
I searched and came up with the problem was lowbrake fluid.
I checked and im fine...just to be safe, i put a little extra in and it didnt do ANYTHING...
any ideas?
IIdiceII is offline   Reply With Quote
Old 09-12-2007, 02:05 PM   #2
IIdiceII
Member#: 90438
btw the cars a 2002 wrx sedan 5spd
Old 09-13-2007, 10:25 AM   #3
strohausii
Member#: 26770
'02 WRX
midnight black
Handbrake has a switch too that would kick on that light, maybe it came loose? Do you have a Video screen, I think those are tied to the handbrake switch too.
strohausii is offline   Reply With Quote
Old 09-13-2007, 10:52 AM   #4
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
OH! Good suggestions on this one! Do what he said.
Old 09-13-2007, 09:31 PM   #5
scooby_drew21
Member#: 148054
Even though you may not be low enough on brake fluid to trip the light, while under hard acceleration, decel, or hard cornering, the inertia of the fluid will swish it to one side. This would leave part of the reservoir lower than the rest, throwing the light. I have seen this happen on several occassions. Top her off to the max mark and check it out, if this doesn't fix it, the grounded e-brake switch may be shorting out.
scooby_drew21 is offline   Reply With Quote
Old 09-13-2007, 10:44 PM   #6
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car
^^There should be no need to fill the reservoir beyond the maximum point. The only things I can think of would be low fluid or worn pads (when they get too thin the fluid level dips way down due to additional travel) so if those aren't a problem then it's probably electrical.
boost junkie is offline   Reply With Quote
E-brake light coming on, won't shut off, help me out here!! NJwrbT-WRX Tri-State Area Forum 21 09-10-2004 01:05 PM
Battery and brake lights flickering on and off together. AcquaCow Electrical & Lighting 2 07-04-2004 02:21 PM
"brake" light comes on and off at random OneArmedScissor Brakes, Steering & Suspension 5 08-13-2003 10:09 PM
e-brake light coming on and off... help? scaryfastskier Brakes, Steering & Suspension 9 06-26-2003 04:12 PM
Check engine light coming on and off, seemingly randomly GusS Legacy Forum 8 12-07-2001 01:50 PM
