Welcome to the North American Subaru Impreza Owners Club Saturday June 23, 2018
Old 06-01-2015, 03:35 PM   #176
KNS Brakes
NASIOC Storefront Vendor
Member#: 125739
2007 1500HD
Need Brakes? 919.420.0021
Hawk 5.0 pads are more expensive.
Initial bite I would say is similar, Hawk has more linear bite.
Dust is less with the 5.0 pads.
I had the STSP pads on my car as well, I enjoyed having them on the car. I didn't mind the dust, they did have a great initial bite, but they were lackluster with linear brake modulation.
Life is about right, I got 30K out of the front STSP pads. Tried Hawk HP+, then went to the Hawk Street/Race and now back to HP+.
-Nick
KNS Brakes is offline   Reply With Quote
Old 06-04-2015, 12:25 AM   #177
4ister
Member#: 38648
2006 Forester XT
Default 06 FXT Brake and Suspension Upgrade
Front and Rear Suspension –
1. A-Arms
a. Subaru STi, rubber bushings removed and black powder coated prevent corrosion)
b. Bushings - Poly-carbon, except the large A-Arm bushings
c. Perrin PSRS large A-Arm bushings (Positive Steering Response System)
i. Note: Perrin provides six 4 inch bolts for installation. The FXT requires the front bolt next to the A-arm on each side to be 4.5 inches long. (I purchased these from a supplier)
d. H&R Camber Bolts (From Perrin)
2. GTSpec Front Roll Center Adjustment Kit
a. Bearings
b. Tie Rods
i. These are super heavy duty and are designed to handle lowered suspensions.
3. Struts and Springs
a. Tien Basis for Forester STi (Japan)
i. Tien Japan website, shipped from Japan. N/A from Tien US
ii. Includes everything, including top mounts and silencing rubber.
4. Front Suspension Tower Bar
a. Perrin
i. This will clear the STi and other aftermarket TMIC’s
ii. I split about 6 inches of a ½ inch black rubber hose and used plumber ties to insulate and secure the A/C line to the tower bar.
This prevents rubbing and vibration/rattling between these two items.
5. Sway Bars and Links, Front and Rear
a. Perrin
i. Front bar is 25 millimeter
ii. Rear bar is 22 millimeter
1. Perrin Stout Mounts.
a. Unless you lower the vehicle, the Stout Mounts will NOT FIT the FXT without the bar being at an extreme upward angle to the wheel mounting links.
Perrin fabricated a special set as a project for me. I had these black anodized.
iii. Front and rear links are the polyurethane version. Best for street vehicles.
Modified Stout Mounts
6. Rear Trailing Arms
a. Godspeed with bronze lining pillow ball
i. Powder coated black. The original red powder coating was of poor quality, but the construction of the part is good, although heavier than the OEM.
7. Lateral Links
a. Agency Power clear anodized
i. Poly-carbon bushings
8. Front & Rear Brakes and Lines
a. 2005 STi Brembo Gold 4/2 pot
i. Rebuilt by Goldline Brakes
1. Black polymer paint
ii. Super Graphics F1- http://www.supergraphicsf1.com/Brakes-Subaru.htm
1. These are the best I have found. I got them in white using the current STi font.
iii. Goodyear stainless lines
iv. P.Mu Project Mu NS 400 brake pads
v. DBA two piece front and single piece rear rotors
1. The rear rotors are the STi diameter/WRX parking brake model
Front Brembo
9. Front & Rear Wheel Hubs and Bearings
a. Dorman Front & Rear Hubs
i. Looked better than the OEM in quality when compared at installation
b. H&R 5mm aluminum/titanium spacers and wheel studs (to clear Brembo’s)
i. H&R spacers reference off the hub not the stud/lug nut (stops balance issues)
c. Subaru rear wheel bearings (packed with additional Subaru grease
10. Rear Caliper Adapter Kit
a. Fastwrx.com, anodized aluminum (Black – Very well made BTW)
11. OEM parking brakes
a. New OEM everything
12. Rear Wheel Bearing Housing and Backing Plate (Splash guard)
a. New OEM (WRX) housing
b. New OEM (WRX) backing plate (See notes below)
The rear Brembo conversion needs some explanation. I researched this ad nausea. First, in pricing replacing OEM wheel bearings on the car vs. buying discounted new Subaru parts, the costs were about the same. Assembling everything off the car provides some additional options. Since so much was changing in the suspension anyway, I decided to go new bearings and hubs
I found a blog which referenced using 2005 STi backing plates on the WRX/FXT rear bearing housing doing the job “right”. (Name withheld to protect the guilty.) Their claim was, no bending, no adapter kit and they should bolt right up. NOT. The STi backing plates have a bolt hole alignment issue. Even though the hub bolt pattern is 5x100, the housing and the bearing OD is significantly larger and bolt locations in different positions. This is translated to the U-joints and axle parts, (and probably the differential) which are also larger. Fortunately, I was able to exchange the 2005 STi backing plates for 2006 FXT plates. The best part of all this is the ability to cut or bend the backing plates off the car. Then you can strip the paint off and repaint the entire backing plate. (I used VHT flat black suspension paint, 250 F). VHT also makes a caliper paint stripping spray, which does a nice job of paint removal and preparation. This should prevent rusting at the bends or cut off edge of the backing plates.
4ister is offline   Reply With Quote
Old 06-18-2015, 05:00 PM   #178
nicholitis
Member#: 423328
2005 WRX
slotted vs drilled?
nicholitis is offline   Reply With Quote
Old 06-19-2015, 11:20 AM   #179
4ister
Member#: 38648
2006 Forester XT
DBA is both. The slots are not full length radial cuts. So they don't reduce the friction surface a lot, but do get the job done for their intended purpose. I tried posting pics with the write-up, but no joy.
Old 07-30-2015, 06:22 PM   #180
chris de bruin
Member#: 426995
Cool brembo 6 piston pads
Hi i have a 2010 STI with 6 piston calipers.Need to replace the pads.Any suggestions on what pad to use and where can i get them from
chris de bruin is offline   Reply With Quote
Old 07-30-2015, 06:27 PM   #181
GrundleJuice
Member#: 165749
OEM from the dealer or your Subaru parts supplier of choice.
Old 07-30-2015, 08:37 PM   #182
KNS Brakes
Member#: 125739
2007 1500HD
If you are certain it is a 6 piston caliper than we need to figure out which one so we can determine the pad shape.
Old 07-30-2015, 09:00 PM   #183
chris de bruin
Member#: 426995
yes it is a 6 piston caliper as mine is a R205 and the caliper is long
Old 08-01-2015, 04:51 PM   #184
4ister
Member#: 38648
2006 Forester XT
P.Mu Project Mu NS 400 brake pads is what I used.
Look them up, they are a Japanese Company. US they are handled by
http://www.mackin-ind.com/project-mu-brake-pads/
Old 08-04-2015, 04:26 PM   #185
KNS Brakes
Member#: 125739
2007 1500HD
Endless makes them as well -and I ampretty sure sodeos Hawk and Ferodo. I would just need to verify the shape and depth.
Ken
Old 08-14-2015, 10:32 AM   #186
JasonToo
Member#: 355960
2011 WRX
Can anybody help me with a link for what shims go where on rear pads for an '11 WRX?
I'd swear I have more shims than pads.
JasonToo is offline   Reply With Quote
Old 10-07-2015, 10:47 AM   #187
polishspy
Member#: 423113
Hi, I was looking for an upgrade from the OEM brake pads on a 2013 Impreza Sport 5dr. Any suggestions? (I would rather them be long lasting and reasonably quiet, had a bad experience with track pads on another car that sounded like a train stopping at low speeds. Dust is not a problem, really dont mind, I wash my car on the regular)
polishspy is offline   Reply With Quote
Old 10-07-2015, 10:59 AM   #188
SwollRX
Member#: 382191
2006 WRX TR
Daily, Tracking?
Otherwise, you may get mixed responses. I recommend Stoptech Street performance pads, if they offer them for your model. However, you will NEED to be hard on them regularly so to reduce deposit build-up. Otherwise, OEM or stoptech/centric posiquiets.
SwollRX is offline   Reply With Quote
Old 10-07-2015, 04:17 PM   #189
4ister
Member#: 38648
2006 Forester XT
Look up Powerstop. http://www.powerstop.com/
I have a front and rear set of pads from them which fits a stock 06 FXT but I don't know if they would fit your vehicle. I have used both rotors and pads from them. Worked just fine, good performance, low dust NO SQUEEK ever.
Old 10-07-2015, 04:20 PM   #190
KNS Brakes
Member#: 125739
2007 1500HD
Hawk HPS 5.0 pads are going to be a pretty good upgrade compared to your stock pads. They have better initial bite than the StopTechs and you don't have to worry about them cause uneven pad deposit judder.
Haven't had issues with noise on WRX's, Imprezas, etc. Only had issues with STI Brembo calipers.
-Nick
Old 10-08-2015, 08:23 AM   #191
polishspy
Member#: 423113
thanks for the information
Old 10-15-2015, 03:52 PM   #192
polishspy
Member#: 423113
-Nick
Nick, would you suggest changing rotors as well or can those wait? Only have 38000 miles on them.
Old 10-15-2015, 04:09 PM   #193
KNS Brakes
Member#: 125739
2007 1500HD
Depends on what their thickness is. If the rotor is within spec, you can scuff up the rotors with some sand paper and prep them for new Hawk pads.
If the rotors are out of spec, it'll be best to replace them.
-Nick
Old 10-15-2015, 04:26 PM   #194
polishspy
Member#: 423113
-Nick
Do you happen to know the specs for thickness on the rotors?
Old 10-16-2015, 09:33 AM   #195
KNS Brakes
Member#: 125739
2007 1500HD
Minimum thickness for your front rotors are 22mm. They come new out of the box with 24mm.
-Nick
Old 10-23-2015, 06:51 AM   #196
jeffgordonwrx07
Member#: 418882
Default changing rotor and pad on or wrx tr
I have a 2007 wrx and I just bought a set of new rotors and pads for my car. I've seen how to replace the pads on the red front calipers but I can't find anything about how to pull the calipers to put the new rotors on if anyone has info that would help alot. I've done rotor swaps om other cars but this is my first subaru
jeffgordonwrx07 is offline   Reply With Quote
Old 10-23-2015, 09:44 AM   #197
KNS Brakes
Member#: 125739
2007 1500HD
There are two bolts on the back of the calipers, remove them, pull caliper off the knuckle. Support the caliper as not to break the brake line hose.
Pretty much the same way you did your other cars.
-Nick
Old 10-31-2015, 01:04 PM   #198
exist
Member#: 229903
I can offer titanium pad shims if you need.
exist is offline   Reply With Quote
Old 10-31-2015, 01:09 PM   #199
exist
Member#: 229903
I think that 6 pot sti caliper pad is the same pad as comes in brembo 6 piston gt kit.
I just bought a set of GTR35 CL pads and grind 7mm from bottom part. It was easy.Have both pads scan,address if you need to compare.
Old 11-13-2015, 01:13 PM   #200
cwwhite
Member#: 434189
Default 09 STI Front Caliper (Piston Tolerances)
I have had unusual/uneven break wear on my 09 STI from day 1. I don't drive the car much so its not been a priority. I decided to do a caliper rebuild. The LF wheel is the problem. The two 40mm pistons and one of the two 46mm pistons slide nicely into the cylinder. The fourth piston appears to **** as it approaches the seal. I am going to a local machine shop to get the cylinder measured above and below the seal for diameter, out of round, and to see if for some reason above and below the seal are not in line.
Does anyone know the maximum tolerance for the piston seal to work properly in case I have to take material out of the cylinder? I know it will be greater than 46MM but I can not find it anywhere online.
cwwhite is offline   Reply With Quote
NEW AMS Brake kit, Brake bleeder. BRAKES BRAKES AND MORE BRAKES! AMS MWSOC Vendor Classifieds 10 09-10-2007 10:43 AM
NEW AMS Brake kit, Brake bleeder. BRAKES BRAKES AND MORE BRAKES! AMS Suspension/Brakes/Handling 10 08-13-2007 01:43 PM
Brakes Brakes Brakes cool13b Legacy Forum 2 03-22-2002 05:08 PM
Brake Lines, Brake Lines, Brake Lines: Rate malaki Brakes, Steering & Suspension 0 05-03-2001 06:55 AM
brakes! brakes! brakes! greg Mid West Subaru Owners Club Forum -- MWSOC 16 12-07-2000 08:36 AM
