11-01-2007, 04:03 PM | #1 |
Vendor
Vendor Sales Rating: (0)
Member#: 153108
Rear Trunk Mounted All-In-One Water Alcohol / Methanol Injection Systems
No supercharger or turbocharger system is complete without a water methanol alcohol injection system. Regardless if your running an intercooled system or not, the benefits gained from a water/alcohol injection system on both intercooled and non-intercooled supercharger & turbocharger systems are so significant, you simply won't want to run without one once you realize the further benefits possible using one. 116+ Octane With Water / Methanol Injection! Knock Knock. Who's there... Detonation! Benefits Of the Water Alcohol / Methanol Injection!
The Only Fully Assembled, Pre-Wired & Pre-Tested Water methanol Injection System On The Market! Our all-in-one trunk mount "systems" make it easier than ever before to install. Unlike other competitors water methanol injection "kits", you won't have to worry about assembling the components first and then trying to find space to install the pump, container, controller, hoses and wiring under the hood of your ride (nearly impossible on newer vehicles). This can be time consuming (between 4-5 hours) and costly (most mechanics charge at least $80-100 per hour). Our trunk mount systems are typically installed in 60-90 minutes!! That's because our system comes pre-assembled and pre-wired. So the only thing you'll have to do is install the tank assembly, apply power, mount the nozzle or nozzles and run fluid and boost line. It's that easy! Not only do we assemble & pre-wire each system for you, each system is hand tested before it's packaged to ensure you receive a fully functional system everytime. Our Kit vs. Leading Competitors:
Your water alcohol / methanol injection specialist's. Let us know how we can help. AIS Stage 1 Adjustable Boost Activated Trunk Mount Water Alcohol Injection System AIS Stage 2 Digital Progressive Trunk Mount Water Methanol/Alcohol Injection System
11-06-2007, 02:21 PM | #9 |
Vendor
Member#: 153108
AIS (Alcohol Injection Systems, LLC) originally sought out to create & build a sophisticated, easy to use, versatile water methanol system. After carefully evaluating many of the leading manufactures of water methanol injection systems, AIS found the CoolingMist system to already offer many if not most all the features we were looking for in a water methanol injection system. Together we have worked towards promoting their proucts under our name. Minor upgrades have been made to the product and are continually in the works. In an effort to stay true to our original goals AIS pre-assembles, pre-wires and hand test each system before it's packaged. Thereby insuring the best customer satisfaction and ease of installation everytime. Let us know how we can help you with your water alcohol/methanol injection needs. Last edited by AIS; 11-06-2007 at 09:48 PM. |
SMC water alcohol methanol injection kit SOCAL cheap! | evanevan | Engine/Power/Exhaust | 11 | 04-14-2011 02:51 AM |
Water/Methanol Injection Systems | Labonte MotorSports | Engine/Power/Exhaust | 19 | 05-08-2009 08:50 PM |
Water Methanol Injection systems and failsafe | Coolingmist | Engine/Power/Exhaust | 70 | 07-20-2008 10:53 PM |
Rear Trunk Mounted All-In-One Water Alcohol / Methanol Injection Systems | AIS | Water/Methanol Injection, Nitrous & Intercooler Cooling | 25 | 12-06-2007 04:54 PM |
